Old 10-01-2013, 02:51 PM   #476
Obababoy
Member#: 158888
2011 STi EFR 7163!
07 GT30 WRX sold :/
How do I get on that reservation list?!
Thanks for the details and sorry for blowin up your PM and Email Geoff.
Obababoy is offline   Reply With Quote
Old 10-01-2013, 04:09 PM   #477
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
How clockable are the compressor housings?
Would I be able to orient the compressor outlet straight up? In stock location (not rotated)
gsrcrxsi is offline   Reply With Quote
Old 10-01-2013, 04:11 PM   #478
Leafy
Member#: 330625
2006 WRX
These things are a piece of ****ing cake to clock, you can spin everything however you like. Just loosen up the v-band clamp on the compressor housing and unbolt the iwg canister bracket and spin it however you like. Then bolt everything back together. And its 4 bolts to do the turbine housing in addition if you need to clock that too.
Leafy is offline   Reply With Quote
Old 10-01-2013, 04:22 PM   #479
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
That's good to hear. I was worried the IWG actuator was locked in to the compressor housing orientation.
Hmm. I have some ideas for the future then
Old 10-01-2013, 04:24 PM   #480
Leafy
Member#: 330625
2006 WRX
Well there is a small section of rotation that isnt possible since the iwg can and the compressor outlet would want to occupy the same space. But beyond that. No problems.
Old 10-01-2013, 04:28 PM   #481
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
So back to what I said. Can I orient the outlet straight up? Vertical. Pointing to the hood.
Old 10-01-2013, 04:32 PM   #482
Leafy
Member#: 330625
2006 WRX
I missed that part of the post, that would be a yes, mine is currently in that config, all be it upside down from it (turbine inlet facing up, compressor outlet pointing down). I believe it did require some specific positioning of the v-band for the compressor housing to clear the iwga, but thats no big deal.
Old 10-01-2013, 05:13 PM   #483
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
No issues with oil drain or what not?
subydude is offline   Reply With Quote
Old 10-01-2013, 05:44 PM   #484
Leafy
Member#: 330625
2006 WRX
Nope. You first adjust the turbine housing so that when its bolted to the up pipe that the oil drain is pointing down. Then adjust the compressor housing.
Old 10-02-2013, 01:39 PM   #485
Obababoy
Member#: 158888
2011 STi EFR 7163!
07 GT30 WRX sold :/
Geoff,
Sent another email. Would like to save a spot in line and purchase the supporting mods asap.
~Chris
Old 10-05-2013, 10:16 PM   #486
VTsuby
Member#: 81369
2007 STI
up-pipe to mate killer b header to this kit would be nice??
VTsuby is offline   Reply With Quote
Old 10-05-2013, 10:19 PM   #487
RobSTI89
Member#: 225268
2005 STI
That made no sense ^^^^ y would a company that makes the best header(full race) on the market make there uppipe work with another company's header lol
RobSTI89 is offline   Reply With Quote
Old 10-05-2013, 10:26 PM   #488
VTsuby
Member#: 81369
2007 STI
cause then i would buy
Old 10-05-2013, 10:47 PM   #489
RobSTI89
Member#: 225268
2005 STI
Full race header is amazing! Sell that killer b and buy a full race complete set up
Old 10-05-2013, 11:00 PM   #490
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
That would be a very stupid move! What were you thinking? clueless : lol:
Old 10-05-2013, 11:03 PM   #491
manitou
Member#: 193757
2006 XTI Limited
Get yourself a good shop that can fabricate if you can't do it yourself and make your own kit. It's not rocket science dude! Think about what you just posted! You have the best header just figure it out!!
Old 10-06-2013, 04:13 PM   #492
'05CrystalGray
Member#: 85793
2005 STi
Crystal Gray
+1 also interested in getting on the reservation list. Please PM with what is required.
Thank you
'05CrystalGray is offline   Reply With Quote
Old 10-06-2013, 06:19 PM   #493
VTsuby
Member#: 81369
2007 STI
each kit comes with an up-pipe maybe they can meet in the middle ...lol I just wonder if a factory location efr with minimal piping on both sides will out perform the best factory location twin scroll setup without complications like ewg's and such
Old 10-07-2013, 08:25 AM   #494
manitou
Member#: 193757
2006 XTI Limited
The problem is still the internal gate and where the gases dump from the gate. Maybe if you increased the size of the exhaust.
Old 10-07-2013, 08:29 AM   #495
Leafy
Member#: 330625
2006 WRX
But the internal gate on the EFR really isnt a downside. I would bet real money that a 6758 running the iwg or an ewg will make the same power and spool up the same. BW intentionally designed that iwg to be the best possible iwg situation.
Old 10-07-2013, 08:44 AM   #496
manitou
Member#: 193757
2006 XTI Limited
It's still dumping into the main exhaust! It's still creating turbulence within the housing! I'll cover your bet and double it!
The other thing I've seen is the swing and angle of their waste gate opening leaves something to be desired.
Old 10-07-2013, 09:12 AM   #497
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
I agree with leafy - these things are REALLY easy to clock with the iwg bracket bolted on the bearing housing.
100% correct - thanks for posting up leafy
Geoff, Sent another email. Would like to save a spot in line and purchase the supporting mods asap.
thanks chris, shot you an email back over the weekend. apologies for the delay, SEMA prep time has been a little hectic for me
just email us your name, contact info (email addy/phone #) and which turbo you are wanting to wait on, we will contact you as soon as there is an update
^^^+1 this
The problem is still the internal gate and where the gases dump from the gate...It's still dumping into the main exhaust! It's still creating turbulence within the housing! The other thing I've seen is the swing and angle of their waste gate opening leaves something to be desired.
manitou, nobody likes misinformation. either learn the tech - or don't click 'post'.
Full-Race Geoff is offline   Reply With Quote
Old 10-07-2013, 09:13 AM   #498
VTsuby
Member#: 81369
2007 STI
Maybe I just haven't seen it but why doesn't anyone make a kit that replumbs the ewg back into the downpipe. I see the dump tubes they sell. I suppose I could dta but that wouldn't be illegal enough for my taste need the antilag too and thats getting exspensive
Old 10-07-2013, 09:19 AM   #499
Leafy
Member#: 330625
2006 WRX
Look at the current ewg setups, there isnt much room in a stock location ewg setup to even add a dump tube, never mind actually getting the ewg tube to merge back with the down pipe at an angle that wouldnt induce more turbulence than an iwg steup.
Old 10-07-2013, 09:51 AM   #500
manitou
Member#: 193757
2006 XTI Limited
Originally Posted by Full-Race Geoff View Post
I agree with leafy - these things are REALLY easy to clock with the iwg bracket bolted on the bearing housing. manitou, nobody likes misinformation. either learn the tech - or don't click 'post'.
Sorry Geoff, I've read the tech and do understand what they're trying to convey. I just do not really believe it and have not seen the results to prove differently. I do like the wheel pairings of these EFR's that aspect of them as well as the SS housings and cartridges seem great!
How many models have the EWG option? That's what I would personally use!
