Old 10-07-2013, 10:14 AM   #501
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
FYI... non-IWG housing w/EWG>IWG housing w/EWG>IWG housing w/IWG.
Nothing beats the performance of a smooth round (expanding) shape as gasses exit the turbine/wheel. I can't think of any argument where a turbine outlet with features in it offers improved performance.
KillerBMotorsport is offline   Reply With Quote
Old 10-07-2013, 10:19 AM   #502
Leafy
Member#: 330625
2006 WRX
I'm not saying its better, but the difference in performance between the efr iwg and an efr with an ewg will be so minimal that it will caught up in the dyno's margin of error. In theory there should be a difference, but IMO it wont be noticeable in real life. BW made a lot of packaging sacrifices with the turbine housing by making the iwg the way they did, they wouldnt have done that without there being a significant benefit.
Leafy is offline   Reply With Quote
Old 10-07-2013, 10:51 AM   #503
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
Full-Race Geoff is online now   Reply With Quote
Old 10-07-2013, 11:03 AM   #504
3mlwhly
Member#: 217648
01 2.5rs
I think we all know that a proper ewg vented to atmosphere is better, by how much idk... Now nobody is arguing that... They are simply saying that iwg is nearly as efficient as ewg plummed back into exhaust... There not saying it's better, just that it is close enough that it's not worth it for the $ in saving and the space it will occupy... Am I right to assume this is what you mean?
3mlwhly is offline   Reply With Quote
Old 10-07-2013, 11:11 AM   #505
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Originally Posted by Full-Race Geoff View Post
I can buy into that! It's got to be the best IWG design out there from what I see.
Old 10-07-2013, 11:27 AM   #506
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Absolutely, but you're assuming it's all performance based benefits. Manufacturing costs, packaging, versatility, etc. were all part of the design process, it wasn't solely performance driven. Housings based strictly on performance only already exist, they are housings with no IWG
Without a before/after true test with the EFR housings it's all a moot point, but what I said is fairly well understood and proven on many other housing style over the years. With the older Garrett housings vs Tial, there was a clear measurable performance edge. As was the continuation of the turbine piping with straight tube, expanding (megaphone) to straight, and/or having straight or a 90 bend shortly after the exit of the turbine. Pre or post turbulence has an effect on efficiency.
Minor difference will show negligible differences in output, but there are (from what we've experienced) measurable/repeatable difference in a housing made for the masses with a built in IWG, and a performance based housing. IMO the EFR housing is certainly an improvement over their previous offering, arguably the best IWG currently on the market right now.
Old 10-07-2013, 11:38 AM   #507
Leafy
Member#: 330625
2006 WRX
I think they weighed much more heavily on performance than you think. They've had problems with the complexity of the housings and having them produced, which is why my housing is a somewhat ugly sand casting rather than one of the beautiful investment cast housings. And the extra length from this iwg setup actually makes fitting these things in an engine bay a major pain in the ass. But still easier than a lot of ewg setups.
Old 10-07-2013, 07:46 PM   #508
PlanetGranite
Member#: 156635
2005 Sti
CGM
I feel like I must be taking stupid pills, because I don't get the EWG vs IWG debate as it pertains to these EFR turbos. Have we yet seen an IWG EFR turbo on a suby 2.5L that hasn't had issues holding boost to redline? Stiff spring and proper preload accounted for, they still blow open it would seem.
PlanetGranite is offline   Reply With Quote
Old 10-07-2013, 08:06 PM   #509
3mlwhly
Member#: 217648
01 2.5rs
I believe that's due to running out of air... not air escaping through iwg
Old 10-07-2013, 09:19 PM   #510
PlanetGranite
Member#: 156635
2005 Sti
CGM
If you're referring to RobSTI89's results, a 53lb/min rated turbo making 408hp/420tq on pump with what looks like stock redline, I would hope that the turbo wouldn't be so out of breath it has to taper 3psi. But, I could be wrong.
There have still been other builds with the larger IWG EFR turbos that have ran into problems holding boost till redline though. So it doesn't appear to be a one time fluke on our 2.5L engines. Or.........no one in the community (Perrin included) knows how to set these IWG turbos up.
Old 10-07-2013, 09:32 PM   #511
3mlwhly
Member#: 217648
01 2.5rs
That's what I though... but I'll have to leave the conclusion to those with more experience with these turbos than I
Old 10-07-2013, 10:36 PM   #512
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
http://www.turbodriven.com/performan...bot/index.html -- this web page can answer a lot of questions, if youre willing to take the time required to read a compressor map. When i started working with BW we demanded they present WAY MORE data for these turbos than anything else out there, so enthusiasts can see numerically what each turbo could do on your engine before making a decision. One fact many turbo enthusiasts dont understand is: if your compresor wheel is out of breath OR if your turbine is at capacity, you cant keep making boost, it will drop. Sure you can overspeed a turbo to a certain limit, but it doesnt matter how stiff your WG spring is (or welded shut with no WG) there will be a wall that gets hit eventually, depending on VE, boost level and RPM.
i encourage you to spend an afternoon with matchbot, it clears up a lot of questions. for example, HERE is a 2.5L Subaru with EFR6758 example i just tossed together:
you can see most of the points are on the map, and only the very topmost red dot #6, 7000rpm, is just over the edge. This EFR6758 is a great combination for a stock STI and 6 speed trans, becuase you are truly using all of the map! its rated 53lb/min at full tilt, and 7000rpm 2.5L and 20psi asks about 54lb/min airflow requirement, so its not a stretch and barely entering overspeed
compare that to the EFR6258 and 2.5L combination @ 20psi
and you can see its off the map above 6000rpm at 20psi even though it tapers to 17psi we would be operating in overspeed at that 7000rpm redline. While this turbo does work wonders on the subaru engines we've tested it on (case in point jager racing is breaking records in their class) you wouldnt want to rev beyond 7000rpm at full tilt or hold it there, however it does get a torque kick so my #1 reocmendation on a 5EAT setup. Try this same comparison on a 2.0L and everything changes of course
Old 10-07-2013, 11:05 PM   #513
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I guess we will see how hard it is to make big boost with the IWG when my new motor gets wrapped up. The last build hit 18 psi pretty easily with very little preload and only about 50% WGDC. Never had problems holding boost flat but I still haven't targeted the big boost yet.
I'm running the 7670 on a Full Race kit. Ran about 7,000 miles on a 2.5L, soon to be a 2.34L and 8K rev limit.
Old 10-07-2013, 11:20 PM   #514
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
^^kelly, read the thread above, this is a great opportunity to look at how compressor maps work. lets look at the matchbot of your 2.34L engine from 3000-8000rpm and EFR7670 combination and a 30psi target since most people consider 2bar 'big boost'
the EFR 7670 compressor wheel is kicking major butt on your motor, until 7000+rpm. at this point you are beginning to run the compressor off the map and enter turbocharger overspeed condition either reduce boost to ~25psi above 7000rpm or dont rev quite as high, let the powerband determine this.
if you are targetting stable power at the higher rpm and higher boost levels the EFR8374 would be the call
all points fit comfortably on the map, with room to spare
Old 10-07-2013, 11:43 PM   #515
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I'm happy with 25 psi on 91 + meth everyday.
Maybe 8374 when I'm bored with that.
Old 10-07-2013, 11:44 PM   #516
PlanetGranite
Member#: 156635
2005 Sti
CGM
Noob matchbot question for you Geoff: Would we want to estimate on the lower side of VE for our head design in conjunction with our miles of pre-turbo manifold track and UEL pulsing?
Old 10-07-2013, 11:50 PM   #517
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
Originally Posted by kellygnsd View Post
I'm happy with 25 psi on 91 + meth everyday. Maybe 8374 when I'm bored with that.
perfect - you will love the 7670 @25psi on your setup. fits great on the map just to be devil's advocate these turbos looove the e85
yes a good flowing exhaust manifold will help VE go up just like a bad one will make it drop. All the data i have collected over the years is with Full-race lower manifolds (we do virtually zero testing on the stockers) so I cant really say what the VE #s would settle at for you. the values i used are pretty accurate for a stock sti motor and header/up pipe/3" exh
Old 10-08-2013, 12:18 AM   #518
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Well I'm headwork + cams and a lot of PnP. How much do you think I can tweak the VE by?
Old 10-08-2013, 12:23 AM   #519
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
some engines can get over 110%, turbo s2000s ive seen close to 113-114%. i can not comment on what your specific engine is capable of, the best way to do that is work backwards once you have results. BorgWarner's turbo shaft speed sensor is VERY helpful in determining this!
Old 10-08-2013, 12:34 AM   #520
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I had ordered the speed sensor but had to send it back because I couldn't get it to fit the way I have the compressor clocked. To bad too, I have sensors to measure FMIC inlet and outlet temperature and pressures so we could get some good FMIC data to work backwards with in matchbot.
Old 10-08-2013, 08:27 AM   #521
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
I was running a 7064 TS IWG and it held boost to redline without issue. Boost was consistently and perfectly controlled. (for reference, I was using the OEM 16-bit ecu and a stock 2 port to control) It can be done.
thefoos is offline   Reply With Quote
Old 10-08-2013, 12:44 PM   #522
Obababoy
Member#: 158888
2011 STi EFR 7163!
07 GT30 WRX sold :/
I am going to forgive BW for the delay on the release of this turbo. They must be victim of the Govt Shutdown!
Obababoy is offline   Reply With Quote
Old 10-08-2013, 04:09 PM   #523
LittleBlueGT
Member#: 96204
2013 STI GR
What really matters is what boost? And 2.0 or 2.5?
W/o the above info holding boost red-line is meaningless.
LittleBlueGT is offline   Reply With Quote
Old 10-08-2013, 06:09 PM   #524
RobSTI89
Member#: 225268
2005 STI
6758 doesn't hold till redline I know that on a 2.5 @23psi
RobSTI89 is offline   Reply With Quote
Old 10-08-2013, 06:18 PM   #525
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
read the post above: http://forums.nasioc.com/forums/show...&postcount=512
max boost at redline on the 6758 for a 2.5L engine is around 19-20psi. its not that "it doesnt hold" -- it's that you are trying to overspeed the turbo... if you want power up there you need a bigger snail #factsoflife
