Old 10-03-2012, 02:39 AM   #176
Jdub.csu
Member#: 283784
2013 EVO X GSR
Originally Posted by Phatron
My buddy just tried to smog his car with a high flow cat and failed. Might as well just go catless.
High flow cats are only good 2-5 years. So I agree if you can. That's assuming the tune isn't running super rich
Jdub.csu is offline   Reply With Quote
Old 10-03-2012, 05:04 PM   #177
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
Originally Posted by BoostinChick View Post
I see it on their site now as well. Does the BPV/BOV block off plate not come with? I didn't see it in the kit picture. Also, I see that the downpipe has a hi-flow cat? Will that cause issues for those that will run primarily 93 octane, but occasionally E85?
the BPV/BOV blockoff plate and plug are optional, since some people prefer to use (2) BOV's on these setups.
the kit price includes high flow cat, but a lot of people are requesting cat-less so the price and listing will be adjusted to allow you to select cat or not
every state is different, but we've passed 4/4 cars successfully so far!
Full-Race Geoff is offline   Reply With Quote
Old 10-03-2012, 05:07 PM   #178
Jdub.csu
Member#: 283784
2013 EVO X GSR
What would be the pros vs cons for running dual BOVs on that setup with low boost?
Old 10-03-2012, 05:15 PM   #179
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
the EFR's integrated BOV is all you need, and how i prefer to set the cars up.
Some of our customers have asked to keep their BOV and piping for a couple reasons, whether "vent to atmosphere" sound or they simply dont want to block off the intake tubes recirc or whatever. This would be a con IMO because turbo speed won't stay up as high as the EFR bov only, which vents the high pressure outlet back into the turbo's compressor (low pressure) inlet
Old 10-03-2012, 05:31 PM   #180
jutes85
Member#: 127232
E90 M3
98' Foz
Will there be instructions on how to run all the vac lines? This little kit looks promising.
jutes85 is offline   Reply With Quote
Old 10-03-2012, 05:37 PM   #181
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
sure thing - its REALLY easy:
stock BOV vac line -> EFR BOV nipple
stock WG hose -> EFR WG hose
Obviously you need to have some tools and basic mechanical skill, but the hardware is all in place. We have the photos documenting every step - just need to get them organized and online with the content written up! oct30th is the 1st day of sema and our deadline for the EFR kits and content to be online
Old 10-03-2012, 06:03 PM   #182
praedet
Member#: 56446
Will there be a TS variant stock location for using the JDM TS header?
praedet is offline   Reply With Quote
Old 10-03-2012, 07:46 PM   #183
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
They already said that want going to happen.
Old 10-03-2012, 08:23 PM   #184
praedet
Member#: 56446
Sorry, I missed that in the thread
Thanks for the info!
Old 10-04-2012, 09:41 PM   #185
Mortal2None
Member#: 190077
2006 Subaru LGT BP
I was hoping too Praedet. Can't physically fit due to the larger TS housing.
Mortal2None is offline   Reply With Quote
Old 10-05-2012, 08:17 AM   #186
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
correct - Twinscroll EFR must be used in rotated configuration. The reason is it's a much longer unit than the T25 (measured axial length) and there is not enough space between a Subaru's intake manifold and firewall for this long a turbo + 3" vband downpipe to fit it all
Old 10-05-2012, 08:41 AM   #187
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
this is the info that I needed.
Even without the firewall in the way, you add more and more length to the up-pipe, to line it up by the inlet tube and eventually, that offsets the spool gains anyway.
But if there was an uppipe segment that mates the OEM twinscroll exhaust manifold, rotates the turbo and then a matching v-band downpipe, I could picture in my mind a silicone elbow coupler that would mate the compressor inlet, rotated as it is, to the turbo inlet in stock position.
There are advantages to a twinscroll in a Subaru, it's worth keeping.
Old 10-05-2012, 05:43 PM   #188
NA STI
Member#: 285083
2006 STi
These need small vband exhaust housings bad (for ewg), just like the tial vband housings for garrett turbos. I would buy a 7163 for sure if something like that is released to go on my rotated vband kit. Thats the only thing thats a deal breaker for these turbos now... not many people want to or can nicely fit a super long turbo like this. Also anyway you look at it ewg>iwg, Sure the IWG design on these are MUCH better then normal but id still rather have a more compact turbo and run my ewg setup, its a win-win.
Im hoping for vband-inlet/outlet ewg exhuast housings to be released for these things, anyone else??? Also it looks like theres no need at all for a twinscroll setup with these smaller framed EFRs, our pre-turbo exhaust volume is already high enough with the extra long piping we already have...
NA STI is offline   Reply With Quote
Old 10-11-2012, 07:46 PM   #189
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
here is a dynochart a customer sent in of this kit with EFR6758 on a stock 2004 2.5L:
(ignore the dip, the dyno's rpm pickup was being intermittent)
Originally Posted by NA STI View Post
These need small vband exhaust housings bad (for ewg), just like the tial vband housings for garrett turbos. I would buy a 7163 for sure if something like that is released to go on my rotated vband kit...
If you stop by our SEMA booth this year, you won't be disappointed...
it looks like theres no need for a twinscroll setup with these smaller framed EFRs, our pre-turbo exhaust volume is already high enough with the extra long piping we already have...
the small frame EFR spool SO fast, i agree twinscroll is not nearly as big of a difference. The larger frame EFR's work great as singlescrolls with a T3 housing... But in twinscroll config their spoolup and response is the best ive experienced from any turbo mfg
Old 10-11-2012, 08:05 PM   #190
Jdub.csu
Member#: 283784
2013 EVO X GSR
91,93?
Old 10-11-2012, 08:14 PM   #191
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
91 octane
Old 10-11-2012, 08:35 PM   #192
reid-o
Member#: 103631
2004 STI
Yes a vband version would be great. I may think of switching if this comes out. The results are great for the small frame versions, but the commitment to t25 flange makes upgrading a bit more expensive. If not Id opt for the 7064 just to leave it a bit more modular for upgrades. If there were a vband version in both small and medium frame that would be perfect assuming the outlet for all versions were in the same location and size.
I also like the wheel combos as they fit the suby a bit better with the larger turbine wheel (minus the required pressure ratios).
reid-o is offline   Reply With Quote
Old 10-11-2012, 09:55 PM   #193
NA STI
Member#: 285083
2006 STi
Thanks Geoff. When will I be able to buy a 7163 along with these new vband ewg housings?
Old 10-11-2012, 09:58 PM   #194
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
the 7163 is scheduled to be available for sale Summer of 2013 with that vband ewg option
Old 10-11-2012, 10:58 PM   #195
05bluesti
Member#: 251804
05 WRB STi
Anyway we could get another dynograph of the 04 above?
Maybe one plotted against rpm, with boost plot?
Or am i gonna have to buy one to find out for myself? Lol
05bluesti is offline   Reply With Quote
Old 10-11-2012, 11:01 PM   #196
Nemesis_STI
Member#: 325545
2006 STI
Whats the projected price of JUST The turbo its self? (with all the EFR goodies,NOT the up pipe or down pipe)
-Justin
Nemesis_STI is offline   Reply With Quote
Old 10-11-2012, 11:17 PM   #197
Jdub.csu
Member#: 283784
2013 EVO X GSR
-Justin
According to their site. 2grand roughly
Old 10-13-2012, 01:06 PM   #198
BoostinChick
Member#: 218971
2007 WRX
Was hoping to see you guys @ MOD today! Was going to pick your brains about this kit. Maybe a visit is in order!
BoostinChick is offline   Reply With Quote
Old 10-15-2012, 09:02 PM   #199
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
sorry we were not at MOD eastcoast this year, only made it to the westcoast event. We have a contract with Ford building some ecoboost F150 turbokits for SEMA which has taken up all of our time and resources as of late.
Feel free to post up any questions you have, Im happy to answer. OR if you are in the phoenix area this winter you are welcome to see our 20k sqft facility and the mfg process
Originally Posted by 05bluesti View Post
Anyway we could get another dynograph of the 04 above? Maybe one plotted against rpm, with boost plot? Or am i gonna have to buy one to find out for myself? Lol
sure, Ill email him now asking for the rpm and boost if they logged it. However since you are local to us (gilbert, AZ!) you should probably stop by and get one for yourself
Old 10-15-2012, 09:04 PM   #200
Jdub.csu
Member#: 283784
2013 EVO X GSR
Ohh you guys are in Phoenix hmmm ill be down there for a business meeting next week I might have to check it out (if I get extra time)
