Welcome to the North American Subaru Impreza Owners Club Monday July 27, 2015
Old 08-16-2012, 10:21 AM   #1
wrxadam05
Member#: 84070
2013 Honda Fit Sport
500whp GRB STI
Default GRB STi - ETS GTX3076R Build (FOR SALE!)
To skip the mini-build on stock motor, skip to post #7 for the NEW build with the current modifications list below!
See last page for selling info!
Never really had a build thread for any of my projects just because I don't have enough damn time. Always busy with work and when I'm working on the car I'm usually in a rush so I never have time to stop and take pictures. I hope this time around I can cover most of the progress and keep you guys up-to-date fairly often. I hate it as much as the next person when a build thread goes on forevvveeerrrrr haha.
Current Modifications
Internal Engine
-Newest Subaru Block
-Original D-AVCS Heads with AVCS deleted
-2013 Heat Treated Crank
-ACL Orbit High Pressure Oil Pump
-2008+ Non-Turbo Impreza Water Pump (For OEM Oil Cooler Delete)
-Manley Rods
-Manley 9:1 AB Pistons
-King XPG Series Bearings
-ARP Head Studs
-Saruda Head Gaskets
-Manley Valve Springs and Retainers
-Manley SS Valves
-GSC S2 For 04-07 STi - AVCS Deleted
-GSC Valve Seals
-Brian Crower Adjustable Cam Gears - On EJ20 Centerline + 1.1Degrees
-TigWerks Oil Pickup
-Tomei Slicer/Baffle
-Gates T328RB Timing Belt and new OEM pulley’s and Tensioner
External Engine
-MAPerformance ported intake manifold
-MAPerformance TGV deletes
-Air Pump Delete
-Torque Solution Motor Mounts
-Torque Solution Pitchstop Mount
-Grimmspeed Crank Pulley
-Custom AVCS Pass. AVCS Line with FP inline oil filter
Fuel
-Pump 93 from Sunoco ONLY
-Injector Dynamic 1000cc injectors
-Boomba Fuel Rails
-DW65C In-tank 265lph Fuel Pump
-Fuelab Fuel Pressure Regulator
-Fuelab 40Micron Fuel Filter With Built-in Check Valve (Under Car)
-Fuelab 40Micron Fuel Filter (In engine bay)
-Mocal AHL -6an Nomex Hose and AN Fittings From Tank to Rail
Brakes
-DBA T3 Clubspec Front Rotors
-Stoptech High Carbon Rear Rotors (Blank)
-Stoptech ST309 Pads Front and Rear
-Motul RBF660 Fluid
-Stock Brembo Calipers with low tension piston springs (to prevent knockback)
-APR Carbon Fiber Brake Ducts
-Grimmspeed Master Cylinder Brace
Rollers
-Enkei NT03+M 18x9.5 +27 (Street)
-Hankook RS3 255/35/18
-Vorshlag Extended Studs
-Vorshlag Open Ended Lugs
Suspension
-ISC Coilovers and Camber Plates w/ Thrust Bearings
-Penske Rebuild and Valved
-Swift Coilover Springs (10k/F, 9k/R)
-Whiteline Endlinks (Front) Have rear as well, can be included for free
-Torque Solution Endlinks (Rear)
-Whiteline Subframe Bushings
-Whiteline Diff Bushings
-Whiteline Steering Rack Bushings
-Whiteline Race Rear Sway
-Whiteline Rear Swaybar Supports
-Whiteline Rear Swaybar Mounts
-Whiteline Front Sway
Drivetrain
-Competition Clutch ST Flywheel
-Competition Clutch Stage 2 HD Clutch
-Torque Solution Driveshaft Carrier Bushings
-Torque Solution Shifter Bushings
-Torque Solution Delrin Shift Knob
-Torque Solution Shifter Extension
-Torque Solution Short Throw Shifter
-Torque Solution Delrin Pivot Bushings
Tuning
-Cobb Protuner Software
-Grimmspeed Boost Control Solenoid
-Omnipower 4bar MAP Sensor
-FAST Motorsports IAT
-Speed Density
Turbo Kit, Intercooler Kit, Exhaust
-ETS Rotated GTX3076R Turbo Kit w/ Tial SS V-band In-Out Housing
-ETS FMIC Kit Setup w/ 4" Speed Density Intake and 3.5 Core
-Perrin EL Header
-Tial MV-R Wastegate
-Tial Q 50mm BOV
-JMFabrications Custom Exhaust; Magnaflow Mini Muffler, Magnaflow HFC, Straight Pipe. Muffler and HFC are under the car and just a straight pipe to turn down coming out the back. The Muffler will be removable with v-bands to swap in a test pipe for the track (Sound Decibel Permitting)
-JMFabrications Custom Catch Can
Current Sponsors
Girodisc
ETS
Torque Solution
Competition Clutch
Swift Springs
Deatschwerks Injectors/Pumps
SHOUTOUTS
JNZ Tuning - www.jnztuning.com for the AWESOME powdercoating and random fitting and an line supply!
JM Fab - www.jmfabrications.com for the exhaust and catch can
Cosworth - For the hookup on Pistons
Manley - For the hookup on Springs/Retainers, Rods, Valves, and Pistons (Though we swapped out to Cosworth)
GSC Power Division - For the hookup on the camahfts
Background
My last build on here was a 2002 WRX Wagon. Stock 2.0L, e85, FP 68hta, 411whp/407wtq. I loved the car, but I got wind of a good deal on a CTS-V and had a fire sale on the Wagon and sold it with a TON of mods for 8,000 dollars. I lost my ass out on it but it went to a good guy and it stayed pretty much the same as when I sold it to him. Ever since I sold the wagon, I had the urge to get another Subaru. I have owned over 10 and there was never really a time I didn't own one. Fast forward a year, I got tired of my 600whp CTS-V and sold it. Picked up a Yukon XL for a daily and a future tow rig. Now (August 2010) it was time to get something I want to mod/track that is affordable.
A couple of months goes by and early March 2011 comes around and the company I was working for at the time decided that we are going to expand the company to Dallas, TX. This requires me to pack up and head on out. So end of March I pack up my stuff, load up and move to North Dallas. Between work and scouting out new locations I started to fall back into my old roots and wanted to pick up another Subaru. With all the open track days in this state (Texas) I couldn't help but want to get something newer and track-able. Here what I ended up with;
Bone stock 2008 STi. Had set of Rally Armor mudflaps on it and that was it for modifications. I was just happy I could find a stock GRB that wasn't beat to ****. Seems like everyone gets them and does bolt on's without a tune and sells them back to the dealer when they start having problems. Luckily this wasn't the case.
And then it starts
May 2011; Invidia Downpipe, TurboXS Catback, RCE Yellows, Whiteline Endlinks, Whiteline Rear Diff Bushings, Whiteline Rear Subframe Bushings, Whiteline Steering Rack Bushings.
June 2011;
ETS Intercooler, Cobb Intake, Cobb Accessport, Torque Solution Motor Mounts, Torque Solution Pitch Stop Mount, Torque Solution Driveshaft Carrier Bushings, Torque Solution Shifter Bushings, Torque Solution License Plate Delete.
[/quote]
wrxadam05 is offline   Reply With Quote
Old 08-16-2012, 10:22 AM   #2
wrxadam05
Member#: 84070
500whp GRB STI
July 2011;ISC Coilovers, Enkei NT03+M's, Dunlop Direzza Star Specs, Vorshlag Extended Studs and Lugnuts, Ferodo DS2500's and GiroDisc 1pc Rotors.
*FIRST PICTURES IS WITH RCE YELLOWS AND THE WHEELS, ABOUT 10 DAYS LATER I INSTALLED COILOVERS*
August 2011; ISC Coilovers came off to be revalved with Penske units and the fluid was swapped out for Amsoil shock fluid, Swift springs were then added to the coilovers. No pictures of the progress, just a picture of the springs is all I have. (SORRY!) Then we built an axleback just for the track, however I find myself dinking around on the street with it
September 2011; This is where things started getting a little out of hand. Pulled the tranny, intake manifold, tgvs, turbo, all of the exhaust, and all of the fuel system. Car is going over a major overhaul right now getting it setup for one last event this season then hoping to hit a bunch of track rentals/open track days before Global Time Attack starts next year, and One Lap Of America. We are looking to compete in both event/series next year.
So this is basically where the build thread is technically going to start off. Below is all the stuff that is happening right now and I will try to update daily!
I'm going to throw some recent pictures below with some information, then from then on out I will post new pictures as I take them.
Old 08-16-2012, 10:23 AM   #3
wrxadam05
Member#: 84070
500whp GRB STI
BELOW IS ALL PRE-BUILD, THIS WAS ON THE STOCK MOTOR
The teardown
Tranny out, just cleaning up the engine and bay at this point. Don't mind my sweet outfit, I was in relax mode haha.
Tranny back in, here is a shot at one of our prototype turbos. Ball Bearing, stock location, featuring MAP's EF2 Wheel.
A bunch of goodies waiting to be put on!
My sick stig wannabe helmet.
Old 08-16-2012, 10:24 AM   #4
wrxadam05
Member#: 84070
500whp GRB STI
BELOW IS MY OLD FUEL SYSTEM SETUP WITH SURGE TANK, PRE-BUILD.
All my fittings came in for my fuel system yesterday, started working on it last night.
The surge tank mounted;
How it looks in the engine bay;
Sending unit connections;
Under the car, Fuelab 40 Mircon Filter w/ built in check valve;
Will have some pictures up of the FPR install and final fuel system tomorrow. Hoping to fire up the car tomorrow if everything goes smooth.
Old 08-16-2012, 10:25 AM   #5
wrxadam05
Member#: 84070
500whp GRB STI
Got the car back up and running after being down for 2 months with a bunch of complications.
Shipped a tig welder down from our Minnesota location to me here in Texas. So I could fabricate some new parts we are going to be releasing for the Scooby market. (Catch cans, chassis specific oil coolers, drop in surge tank systems, etc etc etc) So I welded in my wideband bung, made a bracket for my FPR and a bracket for our turbo because I'm running an external wastegate.
Just fired it up two nights ago and went out last night for a little bit of tuning. At 22psi and still running around 11:1 A/F it feels great. Keeping it a little rich during WOT to burn up this tank of gas so I can fill it up with E85. I'm only going to use pump gas for long trips and such, so I have to get the drivability down with this tank and some mediocre power. I'm not going to dyno on pump gas with our turbo, only e85.
Here is some final pictures of the bay and the surge tank installed. Waiting on some steel stock to come in so I can weld up my catch can and get that PCV hose re-routed properly.
After I get tune it on e85 I'll post up some numbers and video. Then going to put on all my brake stuff that has been sitting around.
Cheers,
Adam
Old 08-16-2012, 10:29 AM   #6
wrxadam05
Member#: 84070
500whp GRB STI
Here is a video on the old setup. This was a MAP 20g Ball Bearing on 18psi (low boost) car was making around 425whp on e85 at this time.
http://youtu.be/g-pLy360QlE
Brakes
Old 08-16-2012, 10:35 AM   #7
wrxadam05
Member#: 84070
500whp GRB STI
FROM HERE ON, THE THREAD WILL BE OF THE LATEST SETUP. CURRENT MODIFICATION IN FIRST POST IS UP-TO-DATE AND WILL CONTINUE TO BE UPDATED!
The motor failed on the old setup in January 2012, when starved of oil due to a bunch of issues revolving around the many many many turbo swaps (MAP,FP,OEM). Anyways, got a knock so it was time to build.
Car sat while I saved up money for the new build. I moved to Chalfont, PA at the end of MAY for a new job. So the new build officially started on June 1st, 2012!
My Original 2009 Block and Heads
-2013 "New Part Number" Crank
-2013 "New Part Number" Oil Pump
-Manley Rods
-Cosworth 9.2:1 Pistons
-King XP Series Bearings
-ARP Head Studs
-OEM Head Gaskets
-Manley SS Valves
-GSC Valve Seals
AVCS Deleted
Crank Balanced
Pistons Balanced (Compare left to right bridging/webbing)
Rods Balanced and Deburred
Going Together
Decked and Assembled
Pistons Going In
Ready For Heads
Degreeing
Old 08-16-2012, 10:49 AM   #8
561wrx
Member#: 166427
03 wrx
Why did u do the avcs delete on those cam for?
561wrx is offline   Reply With Quote
Old 08-16-2012, 10:52 AM   #9
wrxadam05
Member#: 84070
500whp GRB STI
Here are the pictures of the motor going together once I got it back to the house.
Grimmspeed Phenolic 8mm Spacers
BrunsonBuilt TGV Deletes
Perrin EL Header
Boomba Fuel Rail and ID1000cc Injectors
ETS Turbo Kit
Omni 4bar MAP
Competition Flywheel (Didn't snap a picture of the clutch)
Motor In
Old 08-16-2012, 10:57 AM   #10
wrxadam05
Member#: 84070
500whp GRB STI
Test Fitting The Core
Test Fitting the Piping
IAT Placement For Speed Density
Got everything together and needed to order some parts for my fuel system so I took all my piping, intake manifold, and a few brackets over to www.jnztuning.com for some powdercoating. The color is Candy Teal and it came out PERFECT, I couldn't ask for a better job. These guys are GREAT!
Filled her up with some fluid and turned it over by hand for 5 minutes, then with the key for about 20 seconds. Plugged in the fuel and ignition fuses and fired it up for the first time in 8 months!
Old 08-16-2012, 10:58 AM   #11
wrxadam05
Member#: 84070
500whp GRB STI
This is how the car currently sits. After the video I loaded it up on the trailer and took it to JMFabrications to get the catch can and exhaust built. Will update next week when I head to JMFab and snap some pictures!
Old 08-16-2012, 11:03 AM   #12
561wrx
Member#: 166427
03 wrx
And nice job.
Old 08-16-2012, 11:07 AM   #13
wrxadam05
Member#: 84070
500whp GRB STI
The motor was originally Dual AVCS. I switched to 04-07 STi camshafts because the pickups for the camshaft sensors are the same as 08+. With the exhaust camshafts from the 04-07 not having AVCS this was to make my AVCS delete process easier.
The reason for deleting AVCS is to keep the motor mechanically simple as possible. This motor was built to take a beating, last as long as possible, and be reliable. AVCS and it's required cam gears are just something else that could possibly go wrong. I'm a fan of static cam timing (except when I build Honda's) and I really won't see any ill effects of not having AVCS when it comes to power and low end power. My compression and cam timing will make up for this.
I'll make sure to post some dynographs and data to backup my claims. Even if I'm wrong, I'll still post up what I collected for information so people can choose to not do it if they are debating it, or do it because its beneficial.
Old 08-16-2012, 11:13 AM   #14
wrxadam05
Member#: 84070
500whp GRB STI
For anyone wondering what the "New part number" crank and oil pump I used. These are supposedly the latest part number from Subaru for the next year STi. The part numbers have changed for both the crank and the oil pump. Visually they don't look any different from previous non-nitrated cranks, but according to Subaru it is the latest and greatest. I didn't do any heavy digging into this, I just like to run the latest part number when doing my builds regardless of any revisions they have done. Its new? Great I want it.
Old 08-16-2012, 11:28 AM   #15
Extreme Turbo Systems
Member#: 194655
08 STI
Build looks great Adam! Glad we could be part of it. Great job on the documentation. JNZ killed it on the powder coating.
Michael
Extreme Turbo Systems is offline   Reply With Quote
Old 08-16-2012, 11:36 AM   #16
liltoua
Member#: 206802
1998 2.5rs
Wow this is an awesome build!!! I would have never thought of deleting AVCS, interesting, but Im sure you know what your doing haha. Cant wait to see numbers.
liltoua is offline   Reply With Quote
Old 08-16-2012, 11:56 AM   #17
wrxadam05
Member#: 84070
500whp GRB STI
Thanks guys!
Old 08-16-2012, 12:11 PM   #18
bugeye1257
Member#: 188598
Nice man I was just reading your old thread. Chalfont is 10mins from me! Haha would love to check it out sometime. Great back roads around here!
bugeye1257 is offline   Reply With Quote
Old 08-16-2012, 12:27 PM   #19
SilverGSX
Member#: 242232
1999 Legacy GT
Glacier White
That car looks like it's coming along awesome. Keep up the good work
SilverGSX is offline   Reply With Quote
Old 08-16-2012, 12:59 PM   #20
wrxadam05
Member#: 84070
500whp GRB STI
I agree about the backroads. When everything is together, I'll drop you a text. Maybe we can drive down to the Tuesday Philly meet together. Shoot me a pm with your cell number.
Thanks for the complements!
Old 08-16-2012, 02:12 PM   #21
danny_d19
Member#: 180748
2013 Scion FRS
Whiteout
love it
danny_d19 is offline   Reply With Quote
Old 08-16-2012, 02:14 PM   #22
wrxadam05
Member#: 84070
500whp GRB STI
Thanks man.
Old 08-16-2012, 11:08 PM   #23
shupe
Member#: 158991
02 Wrx wagon
Charcoal Grey
Sick work as usual..
shupe is offline   Reply With Quote
Old 08-17-2012, 02:06 AM   #24
04wrexsti
Member#: 225937
'10 SE STI '04 FXT
'00 RS race car
literally almost identical build to my gr white sti just a few weeks ahead of me lol, cant wait to see your numbers she looks great!
04wrexsti is offline   Reply With Quote
Old 08-17-2012, 09:28 AM   #25
wrxadam05
Member#: 84070
500whp GRB STI
Did you delete AVCS? Do you have a build thread or pictures? Curious to what we have identical.
