Old 08-01-2011, 12:20 PM   #1
Mayrun
Member#: 189163
2000 Impreza
GC8
Default Dyno Tune: 2.0L + Blouch Dominator 3.0 XTR makes 470whp/404lb-fts on Mustang Dyno
Had the chance to get the car on the dyno last week, weather wasn't playing by our side.
Since we maxed out the 740s, I'm sure better results can be obtained with larger injectors.
Event: Dyno Pull
Dyno Info: Mustang AWD
Ambient Temp: ~86f
Elevation: 82 feet above sea level
Weather: Hot
Peak HP: 415whp @ 6800
Peak Torque: 374 lb/ft@ 5100
Car: Subaru Impreza GC8 Turbo
Transmission: STI 5 speed
Gear: 3rd
Target Boost: 23.8psi
Fuel: pump 93 + Meth
Engine mods:
Blouch Dominator 3.0 XTR Turbo (10cm housing, 2.4 inlet)
EJ207 V7 Engine block & V8 Heads
Brian Crower 272 Camshafts Stage 2
Brian Crower Single Spring/Titanium Retainer Kit
CP Pistons
ARP Head studs
ACL Race Bearings
MRT 2.4 Inch Turbo intake
K&N Round Filter
Tial Q BOV
NGK PFR7B Plugs
STI EJ257 Oil pan
Tomei Equal Length Headers & Up pipe
XS Power FMIC
Driveline Modifications
STI Version 6 Hardened Gearbox (5 speed)
HEL SS Braided Clutch Line (Motul RFB600 Racing Liquid)
ClutchNet Stage 4 Clutch
MRT Lightweight Flywheel
Kartboy Shifter Bushing Front/Rear Combo for 5MT
TiC 5MT Linkage Update
Fuel delivery
Nismo 740cc Side feed injectors
Fuel Lab FPR
Dual Walbro 255lph Fuel Pumps
10AN Fuel Lines
Electronics
Haltech Platinum Sport 1000 (3 Bar MAP Sensor)
Greddy Profec B Spec 2
Defi White Racer Boost gauge
Defi White Racer Oil Temperature gauge
Greddy Oil Pressure gauge
Dyno Plot:
Mayrun is offline   Reply With Quote
Old 08-01-2011, 02:16 PM   #2
Jay Racing
Member#: 100665
Mayrun, Congrat's nice numbers. Do you have any pictures of this car?
Jay Racing is offline   Reply With Quote
Old 08-02-2011, 10:41 PM   #3
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
Why not rev it higher?
Swine is offline   Reply With Quote
Old 08-03-2011, 10:15 AM   #4
ar1five
Member#: 290285
awesome
ar1five is offline   Reply With Quote
Old 08-03-2011, 06:14 PM   #5
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
injectors already maxed out?
also, is your avcs working? looks like no. if not, you might want to try to wire it up. it won't effect the top end, but it'll give you A LOT more below 4,500rpm. i'd look into getting a JDM ecu and the IA avcs harness. either way, in a GC8, this car must fly.
lil'redwagon is offline   Reply With Quote
Old 08-03-2011, 07:00 PM   #6
Mayrun
Member#: 189163
2000 Impreza
GC8
yes the injectors maxed out, rev limiter is set to 7700 rpm.
as far as I can tell, avcs is not working since I am using brain crower 272 cams.
Old 01-26-2012, 10:11 PM   #7
pooster.online
Member#: 120461
2004 WRX STi JBP
ej207s never cease to amaze..
pooster.online is offline   Reply With Quote
Old 02-09-2012, 07:04 PM   #8
daisho
Member#: 304275
2000 GC8
keep it up bro
daisho is offline   Reply With Quote
Old 08-02-2012, 07:25 PM   #9
Mayrun
Member#: 189163
2000 Impreza
GC8
A year after, we hit the dyno again. This time the car was armed with a methanol injection kit and an aluminum radiator.
Peak HP: 470whp @ 6400
Peak Torque: 404 lb/ft@ 5900
Target Boost: 28.7psi
Old 08-02-2012, 07:53 PM   #10
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
That's awesome... 2.0 Power
Kastley85891 is offline   Reply With Quote
Old 08-02-2012, 11:55 PM   #11
lil jon
Member#: 19044
that is AWESOME!!!!!!! Im about to hit the dyno to do the same thing with a ej205!!! I love 2.0 Power!!!!!!!!! So glad to see some 2.0 stuff on here.
lil jon is offline   Reply With Quote
Old 08-03-2012, 09:51 AM   #12
Dr. octagon
Member#: 171127
2015 Subaru
It seems to be spooling earlier than the previous tune, is this attributed to the addition of meth and leaner afr? You stated AVACS is not working correct?
Old 08-07-2012, 02:40 AM   #13
Mayrun
Member#: 189163
2000 Impreza
GC8
that's right, avcs is disconnected.
spooling feels almost the same on the road, but keep in mind that the temperature and the humidity this time were much higher than last year.
Old 08-10-2012, 02:32 PM   #14
Inv1sion
Member#: 322296
2010 IMPREZA WRX
Love it.. Awesome man
Inv1sion is offline   Reply With Quote
Old 08-10-2012, 03:22 PM   #15
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Damnnnnn!!! 29psi? I am not that brave. Sick numbers man.
Old 08-13-2012, 12:49 PM   #16
adamwrxknepp
Member#: 281692
2004 wrx
white
Default 2.0 dom 3xtr
So what brand and size injectors did you switch to? Also what was their duty cycle when u made the 470whp?
adamwrxknepp is offline   Reply With Quote
Old 08-13-2012, 01:19 PM   #17
brutnus
Member#: 257195
2004 WRX
2.1L
Nice. Don't see to many 2.0Ls in the 500WHP ballpark. Congrats
brutnus is offline   Reply With Quote
Old 08-18-2012, 07:28 PM   #18
DaDonDaDaSuby1969
Member#: 156054
03 2.1 Stroker
MBP Bugeye
What brand Rods are you running???
DaDonDaDaSuby1969 is offline   Reply With Quote
Old 08-21-2012, 08:40 AM   #19
Mayrun
Member#: 189163
2000 Impreza
GC8
Thanks guys,
The injectors are 740cc and rods are stock STI, have no idea about the duty cycle that was used.
Old 08-23-2012, 12:44 AM   #20
roof_rack
Member#: 257866
That second torque curve looks so much better, throw some more fuel at it!
roof_rack is offline   Reply With Quote
Dyno Tune: 2.0L + Blouch 16G-XT makes 278whp 280WTQ (Forged Performance) fl4tsc Proven Power Bragging 26 08-08-2013 10:02 AM
WTB : Blouch Dominator 3.0 Xtr mystilexzero Private 'Wanted' Classifieds 3 10-04-2011 05:31 AM
R & H Garage dyno tune: 2.5L + Bouch Dominator 2.5 XTR 347 WHP R & H Garage Proven Power Bragging 7 05-11-2011 12:56 PM
Dyno Tune: 2.0L + Blouch Evo lll 16G makes 302 WHP burtonrider3889 Proven Power Bragging 33 03-26-2010 12:00 AM
Dyno Tune: 2.3L + Blouch GT30 XT-R on E85 makes 587bhp JAKbauer24 Proven Power Bragging 28 11-16-2009 01:49 AM
