Old 08-16-2012, 04:32 PM   #1
Sheltonmega
Member#: 265204
2009 WRXCobbProtuned
CattedAEMCAIPerrinTMIC93
Default What do you monitor?
Do you have your access port on all the time?
I normally monitor fine knock learn.
Occasionally boost.
What do you monitor to make sure your engine is healthy.
Thanks
Sheltonmega is offline   Reply With Quote
Old 08-16-2012, 06:46 PM   #2
stikboy
Member#: 6697
2011 WRX 5-door
Look-At-Me Red
Occasionally boost.
Thanks
www.cobbtuning.com.
Go there. Check out the videos. Everything you need to know as a Noob is there. After that, ask any question you wish.
Good luck.
stikboy is offline   Reply With Quote
Old 08-16-2012, 09:45 PM   #3
hutch959
Member#: 267463
after you do the full pull stuff (and watch what cobb says), then everyonce in awhile i plug up the ap and watch the feedback knock and the dam just to make sure everything still cool
hutch959 is offline   Reply With Quote
Old 08-17-2012, 12:36 AM   #4
danny_d19
Member#: 180748
2013 Scion FRS
Whiteout
same5
danny_d19 is offline   Reply With Quote
Old 08-17-2012, 02:59 PM   #5
Sheltonmega
Member#: 265204
Thanks.
Old 08-17-2012, 04:45 PM   #6
SouthernWRX
Member#: 321571
2012 WRX Base
Ice Silver
I've been stage one for just over 3 weeks. I monitor Fine Knock pretty much anytime I'm in the car. However if it's just a short trip to the corner store and back, I don't. I would be curious to compare some of my logs to some others. I see some knock "events" in 5th at cruising speed (65 - 80), with load under 1 and DAM at 1. Very speratic and just curious if others are seeing this. My WOT runs are pretty much knock free, the occasional end of run knock from letting off the throttle.
SouthernWRX is offline   Reply With Quote
Old 08-19-2012, 08:20 PM   #7
bacalhau16
Member#: 297565
2011 WRX hatch
Some others here are beginning to look at 5th gear highway cruising speeds, low load and signs of knock. There is a pretty new thread here discussing just that. I will have to do a log or two myself.
bacalhau16 is offline   Reply With Quote
Old 08-19-2012, 08:22 PM   #8
bacalhau16
Member#: 297565
2011 WRX hatch
Lol, looking back, it looks like you actually started the thread.
