Old 08-16-2012, 10:14 PM   #1
turbo970
Member#: 325644
1992 legacy
Default 1992 subie needs a new heart
so if i cant find a reman'd ej22t what would be a good replacement long block. the local engine shop said they might be able to rebuild the old one. all i know is all 4 cylinders are reading 30 psi
turbo970 is offline   Reply With Quote
Old 08-17-2012, 12:11 AM   #2
RallyColtTurbo
Member#: 16819
No reason not to rebuild the EJ22T unless there is physical damage. If it's just 'wore out' at the end of a normal service life, the EJ22T can normally be rebuilt.
IMHO, Use a shop that is familiar with Subaru rebuilds or thye WILL make mistakes.
RallyColtTurbo is offline   Reply With Quote
Old 08-17-2012, 12:33 AM   #3
turbo970
Member#: 325644
1992 legacy
103,000 on it and only 30 psi on all 4 cylinders and the shop isnt sure why
Old 08-17-2012, 08:27 AM   #4
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Must be faulty measurement, very unlikely all cylinders will read that low.
Get it rebuild with oversize pistons and rings, but as said above, only let an EXPERIENCED Subaru engine builder touch your engine.
Marnix is offline   Reply With Quote
Old 08-17-2012, 10:04 AM   #5
turbo970
Member#: 325644
1992 legacy
thats who found out the compression was low. he recommended a new long block. but i have a feeling we'll end up getting this one re built if the block and heads are still good
Old 08-17-2012, 11:07 AM   #6
nottofast
Member#: 89663
1962 Fuji 350
cerelean blue
Yes that is strange, something else going on. I would not decide a cure until I was sure what the problem was. IMO Good luck.
nottofast is offline   Reply With Quote
Old 08-17-2012, 12:40 PM   #7
turbo970
Member#: 325644
1992 legacy
either way it needs rebuilt or replaced
Old 08-18-2012, 12:24 AM   #8
nottofast
Member#: 89663
1962 Fuji 350
cerelean blue
200k on my wifes 94ss wagon and it still sounds better than the 04 wrx.
Old 08-18-2012, 12:31 AM   #9
turbo970
Member#: 325644
1992 legacy
i think the previous owner ran the crap out of this motor. i'm ordering a long block tuesday. 7 yr 100,000 mile warranty.
Old 08-18-2012, 05:11 AM   #10
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Hmmm. Don't give away your old block, that closed deck EJ22T is worth quite a bit nowadays. The big HP guys are desperate for the block halves. Worth 500-600 just for the casings!
Old 08-18-2012, 06:15 AM   #11
Drewbie
Member#: 309709
99 Rs coupe
**** yeah, you can't even buy those block castings from a dealer anymore (in the us anyways).
Have the block rebuilt.. It will be better than a new longblock! They have less tendencies to fail due to the closed deck design. Just.. When they are rebuilding it, make sure the block is honed with both case halves assembled, and a torque plate installed as well.. It is proven both here, and on other forums that honing a aluminum block without a tq plate oblongs the cylinder when you bolt down the cylinder head (which is necessary in order to operate) so.. Any machine shop who is building any aluminum block, especially a split case design block, without a tq plate is suffering from Intrarectalcranialitis!
Drewbie is offline   Reply With Quote
Old 08-18-2012, 11:01 AM   #12
turbo970
Member#: 325644
1992 legacy
well i would rebuild it but no machine shops around here will touch it. the company has 2 ej22t blocks that are rebuild able. closest machine shop that will do this block is quite a drive away. rather just have a reman block with warranty
Old 08-18-2012, 11:24 AM   #13
Aphex28
Member#: 11506
2015 WRX
Where is "around here"? Please fill out your profile!
Aphex28 is offline   Reply With Quote
Old 08-18-2012, 12:04 PM   #14
turbo970
Member#: 325644
1992 legacy
south west colorado. closest shop that will work on it is a 8 hour drive one way. and thats just hone the block or if needed to bore the block. then i'd have to take to another shop to do the heads and assemble the block. or i can spend the money on a long block with warranty and do a couple upgrades that will assure a long life motor
Old 08-19-2012, 01:24 AM   #15
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Not sure if you can handle a wrench and spanner yourself, but if so... Remove the engine from your car and take the heads off yourself. On the SOHC engines that's really easy. The heads can be resurfaced and valve components reseated by any shop.
You could send the block itself out to a reputable builder. It's recommended to upgrade the connecting rods (or more specifically the rod bolts) to furtehr increased reliability of the engine (bearings). You may also want to install a new oil pump and water pump.
Old 08-19-2012, 01:31 PM   #16
turbo970
Member#: 325644
1992 legacy
i could but dont have the tools nore a place to work on it plus i have some nerve issues in one are. yea i rather do it my self but i cant. but the place i'm getting the long block from does some minor upgrades for engine life. 7 yr 100,000 warranty
Old 08-19-2012, 02:48 PM   #17
RallyColtTurbo
Member#: 16819
Originally Posted by turbo970 View Post
........ does some minor upgrades for engine life. .........
On a Subaru, these are very scary words. It's been my experiance that the best stock rebuilds are the ones that follow every rebuilding 'rule' with extreme attention to detail. Not the ones who 'tweak it'.
Subarus *need* to be bored and honed with the case halves bolted and torqued together and with torque plates installed in place of the heads. Most non-Subaru shops (even excellent ones) are simply not set up to do that.
There is also some expertise needed when assembling the case halves together the final time. (proper sealant, amount and placement, etc.)
The warrentee is good, but make sure they can, and will, stand behind it.
Old 08-19-2012, 04:08 PM   #18
nottofast
Member#: 89663
1962 Fuji 350
cerelean blue
Warranty? Never know until they are tested. Was wondering if you are just going to driving it or are a race car driver? (you know beat the hell out of it)
Old 08-19-2012, 06:10 PM   #19
turbo970
Member#: 325644
1992 legacy
its a family car. gonna carry me and my daughter and our bikes. the company i'm getting the long block does all the machining needed to do a rebuild. and they use upgraded bearings and rings.
