Old 08-17-2012, 02:56 PM   #1
NeverSummerSubie
Member#: 321114
2011 WRX Premium
Default Flashed to Stage 1 yesterday, here are the logs
I've only been at stage 1 for a day now, not sure how long it needs to "break in". I went onto the Cobb site to read up on where my numbers should be. For both the feedback and fine knock I have some numbers, it said under low load it is normal but this was at full throttle. The run was in 3rd ~2500 RPMs to ~redline. 2011 WRX Hatch full stock except the Accessport, map is the 91 oct.
NeverSummerSubie is offline   Reply With Quote
Old 08-17-2012, 02:57 PM   #2
NeverSummerSubie
Member#: 321114
2011 WRX Premium
Forgot the link -_-, I do this at work with emails all the time!
https://docs.google.com/spreadsheet/...kttdWFYeGNkc3c
Old 08-17-2012, 03:07 PM   #3
subiebosch
Member#: 155548
2015 2500 Dmax
2011 WRX TP STG2 COBB DP
you have slight feedback knock and fine knock and you are seeing low boost for stage 1. I was seeing 15.8psi or so with COBB stage 1, but I was also running on 93 octane. How hot was it out when you took this...I see AZ so I assume it was quite toasty.
COBB will chime in and let you know in better detail.
subiebosch is offline   Reply With Quote
Old 08-17-2012, 03:36 PM   #4
NeverSummerSubie
Member#: 321114
2011 WRX Premium
Thanks for the feedback subiebosch. I guess I'll just wait on COBB to get some more detail. It is actually only 75 here right now, Flagstaff is at 7000 ft so it stays relatively cool here in the summer. I wonder if being at higher altitude has anything to do with the boost pressure??
Old 08-17-2012, 04:53 PM   #5
SouthernWRX
Member#: 321571
2012 WRX Base
Ice Silver
My first few logs after going stage one looked almost identical to yours. Just keep monitoring it. Mine has gone away now, after about 3 tanks of gas. It should start getting less and less pretty much every time. I do see the occasional knock from time to time at the end of my runs, however thats common and is due to letting off the throttle at the end of a run.
SouthernWRX is offline   Reply With Quote
Old 08-20-2012, 06:17 AM   #6
Buldozer
Member#: 329670
Hmmmm i'm having the same problem...Flashed to stage 1 93 octane and getting knock feedback at 2k - 4k then 0 feedback and 0 learn ... :-/ Flashed to 91 oct map because i thought it's gas problem(i'm from Poland btw) and DAM shows 0.6 all the time now...:-/
https://docs.google.com/spreadsheet/...zTGRNTEE#gid=0
https://docs.google.com/spreadsheet/...KcFM3VFE#gid=0
any help for us please??
Buldozer is offline   Reply With Quote
