Old 08-18-2012, 12:10 PM   #1
Charlton
Member#: 43038
2002 Forester S
Default Marvel Mystery Oil
Anyone adding a few ounces on each fill up? How about a little to the engine? I always get good mileage when I add a few ounces to my motor. Anyone else?
Charlton is offline   Reply With Quote
Old 08-18-2012, 01:48 PM   #2
cmiovino
Member#: 134005
2004 WRX Premium
I actually had to google this stuff:
http://marvelmysteryoil.com/
Hmmmm. Usually this snake oil doesn't work. How much is this stuff? Have any documented fillups?
Old 08-18-2012, 08:17 PM   #3
Charlton
Member#: 43038
2002 Forester S
I usually don't buy additives except this one. I add 4 ounces with each fill up. MMO is pretty cheap.
Old 08-18-2012, 11:01 PM   #4
Bababou
Member#: 280689
2010 2.5i Impreza
Newport blue
I have used it in older cars and had luck bumping MPG and even got rid of a bit of blue smoke on a 91 celica that was on its last leg. Havent tried it on the Impreza yet. What kind of MPG have you picked up useing this.
Bababou is offline   Reply With Quote
Old 08-18-2012, 11:17 PM   #5
Charlton
Member#: 43038
2002 Forester S
Maybe an extra mile or two per gallon.
I used it in a 98 Legacy GT I had once and it does improve fuel mileage slightly and keeps the fuel system clean.
Its also good to add to oil. I would usually put 4 quarts of oil in my Subaru and half a quart of MMO. Its been around forever.
Old 08-21-2012, 04:14 PM   #6
DeanSI
Member#: 329585
Default MMO Top Lube
MMO mixed in the fuel was once used as the replacement in unleaded gas for lead. Lead in old gasoline helped lube the valves. Used it in the harley years ago. Also a great bicycle chain oil.
DeanSI is offline   Reply With Quote
Old 08-21-2012, 04:36 PM   #7
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
MMO is GREAT on hydro lifter cars, especially the old EA82 and early EJ18/22s.
I run a smidge of it in the bikes and the truck to prevent fuel gumming up anything while they sit.
cal_look_zero is offline   Reply With Quote
Old 08-21-2012, 09:39 PM   #8
Ralph47
Member#: 214774
2009 Impreza 2.5i
Dark Grey
I have always run Seafoam in my fuel, it helps my Imp run smoother and bumps the MPG up one or two. Now at ~$10 a can (pint per fill up) it is far from worth it mileage wise but it helps keep the motor clean.
I may try the MMO as it is a lot cheaper and has a great reputation.
Ralph47 is offline   Reply With Quote
Old 08-21-2012, 11:35 PM   #9
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
MMOFTW. I have used it forever and it does help things run smoothly. You really don't need to use very much either. Also makes a great oil for air tools.
Is it just me or does it smell good too?
geronimo81 is offline   Reply With Quote
Old 08-22-2012, 12:49 AM   #10
Ioku
Member#: 164864
95 Impreza coupe
I love the smell of MMO, it has a sort of spearmint smell too it
Ioku is offline   Reply With Quote
Old 08-22-2012, 01:08 AM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
a bit of low sulfur mineral spirits in the gas with a dab of plain dexron atf works great too
cheap
Old 08-22-2012, 08:52 AM   #12
cmiovino
Member#: 134005
2004 WRX Premium
cheap
FYI, no one try this
Old 08-22-2012, 10:27 AM   #13
silver2004impreza
Member#: 127878
2004 Impreza 2.5TS
2004 Outback sedan H6
If anyone is interested, here's a recipe for making Sea Foam yourself. You can buy it for $10 a pint, or you can make your own for $10 a gallon (based upon local prices)
Seafoam Homebrew
1 part Coleman Camp Fuel
1 part hydraulic fluid (such as what you'd use in a floor jack)
1/4 part Isopropyl (rubbing) alcohol
silver2004impreza is offline   Reply With Quote
Old 08-22-2012, 11:12 AM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
i ran that for years with xylene and toluene as octane booster, f00
it only takes a couple ounces of each mixed up in a 3:1 ratio
it DOES work....the mineral spirits is the solvent and the atf is the upper cylinder lube
MMO is nothing special, it just costs a lot more and sea foam used to cost $2.99/can....NOW....**** that
I'm not an idiot and i dont post out my ass
Old 08-22-2012, 04:11 PM   #15
NH8991
Member#: 197937
2016 Golf R
Under the radar silver
I haven't specifically used MMO, but I did try Extralube ZX1 a while back. I never noticed any difference on my own cars, but they were always maintained religously and generally in very good condition.
However, I did get my mom's car to pass the UK emissions test after dumping half a bottle in the engine (the contents, not the actual bottle ). Maybe this stuff does have some merit in vehicles with more wear & tear.
NH8991 is offline   Reply With Quote
Old 08-25-2012, 02:45 PM   #16
97ej22e
Member#: 327710
1999 Impreza OBS
Green
Seafoam is great, my car seems to have more get up and go now that I cleaned it out.
97ej22e is offline   Reply With Quote
