Old 08-19-2012, 12:41 AM   #1
eric69cam
Member#: 293407
Default New to tuning, need clarification...
So, I got an AP V2 for my Bugeye and have been misled on a few things somewhere along the way before I bought it.
My problem is when it comes to cel's. I was told I could block/cancel cels for tgv deletes, switching to a manual boost controller etc...
Is this possible or do I have to get someone to create a downloadable map for me?
Currently, I am running the stage 1 91 octane map on my Bugeye. Only mods are tgv deletes, mbc and air intake.
I will shortly be adding an uppipe and down pipe both catless and possibly a tmic. I would like to take care of these previously mentioned cel's when I retune after these next mods.
If any of you could point me in the right direction, I would be very grateful.
eric69cam is offline   Reply With Quote
Old 08-19-2012, 02:50 PM   #2
johnmkv
Member#: 300848
2012 WRX
LR
Ap will only truly work with the mods that are outlined in the stages 1 and 2 most other mods will need a protune thats all
johnmkv is offline   Reply With Quote
Old 08-19-2012, 05:24 PM   #3
eric69cam
Member#: 293407
Ok. Understood. Is this something i need to seek out locally or are there resources here on nasioc that i have not yet found?
Old 08-19-2012, 06:36 PM   #4
addictionsoLA
Member#: 301236
2010 Wrx
Grayish!
There are people that will do e-tunes using maps formatted for the accessport, a couple of well known ones are Clark Turner, Phatbotti, and Eric at Torqued Performance. These guys charge anywhere from 200-300+, if you have a shop with an AWD dyno you can get it pro-tuned on that, which usually will run 400+.
addictionsoLA is offline   Reply With Quote
Old 08-19-2012, 11:56 PM   #5
johnmkv
Member#: 300848
2012 WRX
LR
This^ i feel your best bet is probably seek out locally the reason is if something were to go wrong with your car for any reason you could contact your tunner with help for the problem
