Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC > TXIC Private Classifieds
Old 07-11-2012, 02:46 PM   #1
Dasani
Top Scoob 005
Member Sales Rating: (62)
Member#: 58098
10.4 @ 137.46mph
Cosworth, TSR70, MZM Tune
Subaru Stars 2004 STi - 540 WHP - The "Silver Sleeper"
FOR SALE: 2004 Subaru WRX STi - AKA "Silver Sleeper"
Will/Will Not Ship: Will NOT Ship
Status: S O L D
How To Contact: PM
Price: S O L D
After a lot of self deliberation, I'm finally selling this car. I basically have 2 full time jobs and don't have the time to devote it - it's been sitting for the last 3 years with an occasional trip to work, to get inspected, to get the oil changed, etc.
It was featured in D Sport magazine, on the MZM Performance website and was voted Top Scoob on NASIOC. You can do searches on NASIOC and find tons of information about it.
Everything works and no shortcuts were taken in its build.
This thread also covers its history: http://forums.nasioc.com/forums/show....php?t=1545763
Car has just under 51000 miles on it, engine has just over 2200 miles on it. Garage kept its whole life, never driven in the rain. There are two scratches on the rear bumper and one of the wheels has scratches from the rubber lip that used be on the fender lip.
Comes with everything, along with a car cover and an extra set of wheels (same BBS as in the pictures, except silver).
Photos:
Complete Modifcation List:
Engine
- Accurate Machine Works Oil Catch Cans
- APS 3.5in Turbo Back Exhaust
- APS 80mm Cold Air Intake
- APS Billet Aluminum WRX Fuel Rails
- APS Braided Stainless Steel Fuel Rail Lines
- APS Braided Stainless Steel Power Steering Lines
- APS DR725 Front Mount Intercooler
- APS Dual Vent Bypass Valve
- APS Split Pulse Header
- APS Split Pulse Header Exhaust Shields
- APS TSR70 Turbo
- Cosworth 274 Exhaust Camshafts
- Cosworth 278 Intake Camshafts
- Cosworth Big Valve Cylinder Heads
- Cosworth Billet Crankshaft
- Cosworth Billet Timing Belt Guide
- Cosworth Connecting Rod Bearings
- Cosworth Cylinder Head Studs
- Cosworth Forged Pistons
- Cosworth H-Beam Connecting Rods
- Cosworth Main Bearings
- Cosworth Oil Pump
- Cosworth Piston Rings
- Crucial Racing 160 Degree Thermostat
- Crucial Racing Ported Stock Throttle Body
- Crucial Racing Radiator Caps
- Custom Automatic Intercooler Sprayer
- Custom Harmonic Damper
- Denso IKH24 Spark Plugs
- HKS 1000cc Fuel Injectors
- HKS A/F Knock Amp
- HKS F-Con V Pro Engine Management
- HKS Twin Power DLI Ignition Amplifier
- JDM WRX Tumble Generator Valve Deletes
- Koyo Aluminum Radiator
- MZM Performance Braided Stainless Steel Fuel Lines
- MZM Performance Braided Stainless Steel Wastegate Lines
- MZM Performance Brake Line Heatshields
- MZM Performance HKS F-Con V Pro Tune
- MZM Performance Ecutek Reflash
- MZM Performance Fuel Pump
- MZM Performance Turbo Blanket
- Samco Silicone Radiator Hoses
- Sard Adjustable Fuel Pressure Regulator
- STi Kevlar Timing Belt
- System One Fuel Filter
- Tial 44mm Wastegate
- Thermotec Intercooler Piping Heatshield
Drivetrain
- ACPT Carbon Fiber Driveshaft
- Carbonetic Carbon Triple Plate Clutch
- Driveshaft Shop Front Axle Shafts
- Driveshaft Shop Level 5 Rear Axles/Hubs/CV Joints
- Kartboy Front Shifter Stay Bushing
- Kartboy Rear Shifter Stay Bushing
- Kartboy Shifter Lever
- Kartboy Transmission Crossmember Bushings
- SPT Short Shifter Mechanism
- Turn In Concepts Shifter Linkage Bushings
- Turn In Concepts Shifter Pivot Bushings
Chassis
- Cusco Motor Mounts
- Cusco Rear Subframe Brace
- Cusco Transmission Mount
- Happi Motoring Fender Cowl Braces
- Kartboy Billet Aluminum Engine Pitch Mount
- Kartboy Exhaust Hangers
- Kartboy Rear Differential Crossmember Bushings
- STi S204 Front Performance Damper
- STi S204 Rear Performance Damper
- STi JDM Transmission Under Panel
- STi Spec-C Titanium Strut Tower Brace
- Turn In Concepts Rear Differential Bushings
- Whiteline Rear Subframe Locking Bolts
- Whiteline Steering Rack Bushings
Suspension
- Cobb Tubular Front Sway Bar
- Cobb Tubular Rear Sway Bar
- Ohlins 25 Way Adjustable Front Struts
- Ohlins 25 Way Adjustable Rear Struts
- Perrin Front Sway Bar End Links
- Perrin Rear Sway Bar End Links
- Racecomp Engineering Front Camber Plates
- STi JDM Spec-C Front Spring
- STi JDM Spec-C Rear Springs
- STi Group-N Rear Strut Mounts
Brakes
- Goodridge Stainless Steel-Braided Brake Lines
- Hawk HPS Front Pads
- Hawk HPS Rear Pads
- The Brakeman 2 Piece Front Rotors
Interior
- 2004 WRX Black Carpet
- 2004 WRX Katzkin Leather Covered Rear Seats
- 2006 STi Center Console
- 2006 STi Steering Wheel & Air Bag
- 2006 WRX Armrest Extension
- 2006 WRX Limited Leather Door Panels
- 2007 STi Limited HVAC Controls
- Autometer Triple Gauge Glove Box Mount
- Autospeed Billet Dead Pedal
- Bazooka 8in Subwoofer Tubes
- Defi Dash Triple Gauge Mount
- Defi Exhaust Temperature Gauge
- Defi Fuel Pressure Gauge
- Defi Link 2 Gauge Controller
- Defi Oil Pressure Gauge
- Defi Oil Temperature Gauge
- Defi Water Temperature Gauge
- Infinity Kappa Perfect 6.1 Front Speakers
- Infinity Kappa 42.5i Rear Speakers
- Kenwood DDX-7017 Head Unit
- Kenwood KDH-C710 Hard Drive Unit
- Kenwood KNA-DV4100 Navigation Unit
- Recaro Sport Black Leather Front Seats
- Redline Automotive Leather Armrest Extension Cover
- Redline Automotive Leather Emergency Brake Boot
- Redline Automotive Leather Shifter Boot
- Rockford Fosgate Power 851 Amplifier
- Rockford Fosgate Power 1001BD Amplifier
- Solar Gard Window Tint
- STi CDM Black Floor Mats
- STi JDM Automatic Intercooler Sprayer Switch
- STi S204 Hazard Button
- STi S204 Shifter Trim
- STi Spec-C V-Limited Shifter Knob
- Turbosmart e-Boost 2 Boost Controller
Exterior
- 2005 STi Headlight Housings
- 2005 STi Front Emblem
- 2005 STi Rear Emblem
- 2006 STi Rear Diffuser
- 2006 STi Side Under Panels
- 2007 STi Limited Rear Wing
- 2007 STi Limited Trunk Lid
- Autospeed Billet Front Bumper Trim
- BBS RE 18x8 Diamond Black Wheels
- Car Service Hiro Battle Hawk Carbon Fiber Hood
- Carbign Craft Alternator Shroud
- Clearshield Vinyl Front Bra
- Cusco Stainless Steel Hood Pins
- Gruppe-S Carbon Fiber Radiator Shroud
- GT Spec Carbon Fiber Rear Bumper Heat Shield
- Hella Xenon Blue High Beam Headlight Bulbs
- Kartboy Billet Aluminum Battery Tie Down
- STi S203 Wheel Center Caps
- STi Spec-C V-Limited Front Lip
- STi Spec-C V-Limited Rubber Under Lip
- Trust Aluminum Lug Nuts
- Yokohama Advan Neova 235x40x18 Tires
Dasani is offline   Reply With Quote
Old 07-11-2012, 03:52 PM   #2
Jester808
Member Sales Rating: (29)
Member#: 166085
1990 Skyline GTR
Jet Silver Metallic
Noooo
No one is going to take care of it like you have
I'm still jelly of that hood.
Jester808 is offline   Reply With Quote
Old 07-11-2012, 04:06 PM   #3
zentrandi
Member Sales Rating: (6)
Member#: 130577
03 gga WRX 10' LGT
Both silver
holy ish snacks.
zentrandi is offline   Reply With Quote
Old 07-11-2012, 04:15 PM   #4
coffeemillionaire
Member#: 287191
2006 STi
World Rally Blue
Cleaaan! GLWS!
coffeemillionaire is offline   Reply With Quote
Old 07-11-2012, 04:24 PM   #5
SUBIEBOI91
Member#: 294433
2015 sti
white
shes so beutiful man
wowow
SUBIEBOI91 is offline   Reply With Quote
Old 07-11-2012, 04:37 PM   #6
Kastley85891
Member Sales Rating: (57)
Member#: 127704
2015 Boosted Stang
MAP tuned
That is awesome, whats ballpark? PM if you like
Its very nicely done man, Good job
Kastley85891 is offline   Reply With Quote
Old 07-11-2012, 06:01 PM   #7
Jester808
Member#: 166085
1990 Skyline GTR
Jet Silver Metallic
Hey D, you want a 2010 STI Special Edition?
Seriously, good luck with the sale. Sad to see it go.
Old 07-11-2012, 06:33 PM   #8
linetrash
Member#: 296045
09 wrx
wrb
what price rang are you thinking
linetrash is offline   Reply With Quote
Old 07-11-2012, 07:55 PM   #9
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
Thanks for the offer, but I think I want to try something different this time... still undecided...
This isn't the first project car I've sold, so I don't have any unrealistic dreams of getting anywhere near the amount of money I have in it.
I'm actually willing to let it go for a very reasonable price.
-D
Old 07-11-2012, 08:02 PM   #10
HonduHunter
Member#: 28408
2002 vf48ed WRX
beautiful...i hope it sells off the forums...
HonduHunter is offline   Reply With Quote
Old 07-11-2012, 11:58 PM   #11
jawsk2
Member Sales Rating: (3)
Member#: 118991
2007 STi
-D
Probably want to try out a JEEP. [fingers crossed]
jawsk2 is offline   Reply With Quote
Old 07-12-2012, 01:45 AM   #12
Jester808
Member#: 166085
1990 Skyline GTR
Jet Silver Metallic
I am seriously considering selling my STI to get this one
Old 07-12-2012, 10:41 AM   #13
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
I did look at the Cherokee SRT8, but it doesn't have a $60000 worthy interior...
Old 07-12-2012, 10:42 AM   #14
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
Do it! I know it would be going to a good home!
Old 07-12-2012, 10:58 AM   #15
Jester808
Member#: 166085
1990 Skyline GTR
Jet Silver Metallic
Putting everything together now for the ad...
Old 07-12-2012, 01:52 PM   #16
markgsa
Member Sales Rating: (20)
Member#: 255271
2006 STI
AW
Mother of God that's clean. GLWS
markgsa is offline   Reply With Quote
Old 07-12-2012, 10:30 PM   #17
roadtalontsi
Member#: 64572
9310 supra, c63
white, matte silver
whats a ballpark on this. like 25k$?
roadtalontsi is offline   Reply With Quote
Old 07-13-2012, 03:32 PM   #18
Dasani
Top Scoob 005
Member#: 58098
10.4 @ 137.46mph
We could begin a game at that ballpark for sure.
Old 07-13-2012, 08:52 PM   #19
notyet227
Member Sales Rating: (5)
Member#: 58142
2002 WRX/forester
WRB/Silver
I love this car. My bugeye is in excellent shape and I take veeerrry good care if it but I would prolly sell or trade my car for this one. Wow. Super nice. Always loved this car. Very well built!!!
notyet227 is offline   Reply With Quote
Old 07-13-2012, 10:05 PM   #20
Jester808
Member#: 166085
1990 Skyline GTR
Jet Silver Metallic
Someone buy my car so I can get this
Old 07-13-2012, 10:27 PM   #21
txjunglist
Member Sales Rating: (2)
Member#: 11926
2011 Outback Limited
Dark Grey
exceptional build . @25k+/- it wont last long.
txjunglist is offline   Reply With Quote
Old 07-13-2012, 10:34 PM   #22
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
^^^^ This guy knows a thing or two about 500+ hp STi's. Agreed 100% on price. Good luck with the sale, Dasani!
Mika
finnRex is offline   Reply With Quote
Old 07-14-2012, 05:40 PM   #23
distorto
Top Scoob 024
Member Sales Rating: (14)
Member#: 56364
RIP stompr :(
bagged vulvva
if only i could finance it. good luck!
distorto is offline   Reply With Quote
Old 07-22-2012, 05:05 PM   #24
contreras2323
Member#: 268136
2003 WRX
beautiful, just beautiful...
contreras2323 is offline   Reply With Quote
Old 07-23-2012, 09:37 AM   #25
uhl6
Member#: 326048
trade?
uhl6 is offline   Reply With Quote
