Welcome to the North American Subaru Impreza Owners Club Thursday October 20, 2016
Old 08-20-2012, 12:34 AM   #1
Member#: 124705
2001 Outback Sport
Default Low compression on #4, buy new engine?
Engine: '01 EJ22
I swapped the engine in my Impreza Outback Sport only to find the new engine has bad compression on cylinder #4.
I adjusted the valve lash to .008 on intake and .010 for exhaust which didn't make any difference. I did a dry/wet test for cylinder #4 but there was only a 10-15 psi difference. I have not done a leak down test to find out exactly where I'm losing compression.
I can return the engine to the seller and get my money back or proceed with this one to find out where the problem is and how much effort it will take to fix. Do I even bother repairing or just find a new engine?
Ptero is offline   Reply With Quote
Old 08-20-2012, 03:09 AM   #2
Member#: 310744
02 WRX
If the guy sold you a bad engine go after him.
Tdaz250 is offline   Reply With Quote
Old 08-20-2012, 07:13 PM   #3
Member#: 318411
17 WRX
klaus_b2 is offline   Reply With Quote
Old 08-20-2012, 07:15 PM   #4
Member#: 294461
2006 San Remo Wagon
Under construction
#4 is the notorious cylinder for burning valves.
cal_look_zero is offline   Reply With Quote
Old 08-20-2012, 08:19 PM   #5
Member#: 216984
1996 Impreza outback
My 96 impreza wagon has lower compression in cylinder 4 as well by about 35 points or so. Stupid cylinder 4....
But yeah, go after the person you bought the engine from.
subi400 is offline   Reply With Quote
