Old 08-17-2012, 07:38 AM   #1
SubieMonte
Member#: 264803
2005 WRX Wagon
Default How to resolve mystery spot on headlight?
I had my car in the repair shop for an extended period of time. When I picked it up I noticed this on my headlight.
Sort of looks like bird doo but it's not. I tried the Meguires head light restore and that did not seem to make it better. I wasn't too aggressive with the sanding. Honestly I'm not even sure this is on the outside. But I have no idea how it would have made its way to the inside.
Any suggestions on how to correct? More aggressive sanding? Replace the headlight?
Thank you!
SubieMonte is offline   Reply With Quote
Old 08-17-2012, 07:51 AM   #2
LiCelsior
Member#: 182551
2004 STi
looks like something dropped onto it when they were working on the car. freon, brake cleaner, something that etched the lens.
LiCelsior is offline   Reply With Quote
Old 08-17-2012, 08:48 AM   #3
bottlenose
Member#: 291768
WR Blue
It's probably on the outside, but you really need to determine that yourself for sure. Theres obviously a small chance it could be inside but I can't think of how that could possibly be. Good lighting will help and look up close at different angles. Once you are positive, then it wouldn't hurt to continue with more wet sanding. I wouldn't quit working on this headlight at all.
bottlenose is offline   Reply With Quote
Old 08-17-2012, 11:40 AM   #4
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
I agree with LiCelsior in regard to it appearing as if the dripped something on the surface of the lens. Personally, I would confront the shop. The fact that you already tried something abrasive seems to indicate the damage is probably more extensive than it may look. It may only be a little deeper and might come out if you try removing more material but the mark could also the result of a solvent/chemical that has penetrated deep into lens. ....possibly requiring replacement.
Old 08-17-2012, 02:17 PM   #5
SubieMonte
Member#: 264803
2005 WRX Wagon
Well it's supposed to be a nice weekend. Guess I'll have to get six pack! Thank you. I will post the results.
Old 08-20-2012, 07:34 AM   #6
SubieMonte
Member#: 264803
2005 WRX Wagon
Used the Meguires headlight restore. Sanded with the #1 pad for about 45 mins and then finished the process. Turned out great!
Message Board Statistics All times are GMT -4. The time now is 10:12 AM.
