Old 08-21-2012, 01:25 AM   #1
Flames4791
Member#: 319172
2003 Impreza WRX
Platinum Silver Metallic
Default V7 JDM HID headlights Leveling Switch?
What exactly is the leveling switch and leveling motor? Do all JDM/EDM headlights for the bugeye come with them?
Flames4791 is offline   Reply With Quote
Old 08-21-2012, 02:01 AM   #2
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
The JDM switch has a 4 spot adjustment. The motors are on the back of the lights. 4 is lowest and 0 is the highest. There is a 6 spot switch. I think it's edm. As I understand it has the same amount of movement. It's worth getting the harness and switch if you have these lights.
I rewired mine to the spot where the dccd would normally be.
Old 08-29-2012, 10:04 AM   #3
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
Is manual adjustment of the headlights possible without the motors?
Old 08-29-2012, 02:39 PM   #4
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Yes, they always have the manual screws to adjust each headlight independently. The motors are another movement "on top" of the manual adjustment. In other words if you dont wire the motors you can still aim your lights with a screwdriver.
frederik is offline   Reply With Quote
Old 08-29-2012, 02:50 PM   #5
azscooby
Member#: 115297
2002 ej207 vf34
There is a write up in scoobymods on how to wire this up.
I've got all the parts and connectors, I just need the time to put mine together.
I bought new Deutsche connectors to make a nice clean install.
azscooby is offline   Reply With Quote
Old 09-20-2012, 04:27 PM   #6
Josebugeye
Member#: 310906
2003 WRX
So with the leveling switch could you basically make them Lhd instead of rhd?
Josebugeye is offline   Reply With Quote
Old 09-20-2012, 04:32 PM   #7
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
No, the leveling motors and switch only allow in-cabin aiming of the headlights on 4 different positions. If your headlings lights the wrong side if the road this will not change that.
To correct that you need to replace or modify the shields inside the headlights, or retrofit a different projector. There are threads on this, search for SHIELD RDH LDH or search for RETROFIT.
