Old 08-21-2012, 09:40 PM   #1
chodeman07
Member#: 246896
2013 WRX STI Sedan
Ice Silver Metallic
Default New log interpreted by n00b. Some advice......
Thanks for looking and possibly adding some insight. Here is my log:
https://docs.google.com/spreadsheet/...kUXpUdmc#gid=0
Mods:
-07 Subaru WRX TR
-Cobb Accessport Stage 2 93 octane tune
-Invidia V2 catless Downpipe
-HKS Hi-Power Exhaust
-Forge Motorsport BPV 100% recirculated
-Process West top mount intercooler
-SPT short ram intake (not supported, I know)
Interpretation:
-Boost is low-ish, high humidity, cooling temperatures and weather possibly played a factor(usually boost about 15.1-15.9 on 70 degrees w/ 40% humidity)? Fine knock learn, AF learning 1, DAM and feedback knock are all good. Question is, why did my knock sum sensor while cruising around town and not logging shoot up to 18 in a matter of 30 seconds? Do all cars knock, and a certain amount is acceptable?
Other notes:
-Watched tutorial on youtube for Accessport logging.
chodeman07 is offline   Reply With Quote
Old 08-21-2012, 09:47 PM   #2
SouthernWRX
Member#: 321571
2012 WRX Base
Ice Silver
18? or 1.8? Never seen 18 and had no clue it would go that high. I log all the time, because I'm obsessed with it, and I see random knock from time to time. I've heard the general rull of thumb is, if it's at low load (1.25 or lower) and a single count, it's not much to worry about. However if you saw a count of 18...holy what the knock of ouch.
Someone chime in if my info is way off base.
SouthernWRX is offline   Reply With Quote
Old 08-21-2012, 10:21 PM   #3
chodeman07
Member#: 246896
2013 WRX STI Sedan
Ice Silver Metallic
The specific parameter was called "Knock Sum" and it started at 7 and rose to 18 as I accelerated. I believe it to the be all the knock counts the car encounters. Like I said before though, the items to be concerned about in a datalog like those I logged are all normal. Am I just being a nervous nelly here?
