Old 08-21-2012, 09:42 PM   #1
2011WRX
Member#: 251807
Default Enkei Raijin Gunmetal on 2011 WRX
Just wanted to share some pic of the Enkei Raijin Gunmetal that recently put on my 2011 WRX. 18X8 offset 45, clear Brembo Grand Tourismo kit, Thanks to Tirerack.
The color looked good with SWP.
All the mushy pedal feel is gone with as soon as the Brembo is put in. Performance exactly what I would expect from Brembo.
[IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
2011WRX is offline   Reply With Quote
Old 08-23-2012, 05:11 PM   #2
sc00by4life
Member#: 97135
[/IMG][/IMG]
Brakes have nothing to do with "feel".
Upgrading lines, that does it :P.
sc00by4life is online now   Reply With Quote
Old 08-23-2012, 06:00 PM   #3
2011WRX
Member#: 251807
Wrong, brake caliper has a lot to do with brake pedal feel.
Upgrade the line does improve the feel but only to an extend.
Old 08-23-2012, 06:23 PM   #4
sc00by4life
Member#: 97135
You have that backwards .
Larger pistons allow for more travel and a softer pedal. If you move to smaller pistons, it can increase pedal feel due to shorter travel but not much. Moving from floating calipers to 4 pots will also marginally improve feel. All it really does is change the curve of the force applied.
Kind of like how the floating calipers on the 2011 wrx and the brembo's on the sti have a stopping distance within 3 feet of each other, which can also be attributed to the wider tires on the sti
The largest factor in pedal firmness are the master cylinder, and brake lines (a reduction of flex in brake lines drastically increases firmness of the pedal).
Regardless - wasn't the point of this thread to show us some pictures?
Old 08-25-2012, 10:15 AM   #5
2011WRX
Member#: 251807
Finally got the picture working!!!
These Toyo R1R are really soft compund tire, grip are great. Noisy as usual but performance is priority
Old 09-03-2012, 02:33 PM   #6
2011WRX
Member#: 251807
With 245/40/18, the tire/wheel weight 46lb. Weight the stock tire/wheel with 30% tread left = 43lb. Not super light but decent for the look and price
Old 09-03-2012, 04:23 PM   #7
D.Marino
Member#: 323174
2013 Sti
Looks real good
D.Marino is offline   Reply With Quote
Old 09-03-2012, 04:40 PM   #8
2011WRX
Member#: 251807
Originally Posted by D.Marino View Post
Looks real good
Thanks. Was skpetical when seeing pictures with the hyper silver. But the gun metal looked great with SWP
Old 06-05-2013, 04:50 PM   #9
GregOrz
Member#: 339148
I'm getting these wheels installed, gunmetal, but I am getting 18X8.5 45mm Offset, 245/40 Dunlops. TireRack says they fit, I'm not going to argue.
Any reason why you didn't go with 8.5 width?
GregOrz is offline   Reply With Quote
Old 06-06-2013, 09:12 AM   #10
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I like the Raijins. Sort of an updated classic look.
I was thinking of getting these wheels for my Audi, but they don't offer the gunmetal for my car on Tirerack.
Old 06-06-2013, 11:32 AM   #11
Tire Rack Moderator
Member#: 1215
ext. 4362
I like the Enkei Raijins as well ... here they are in Hyper-Silver on my 2013 Hyundai Genesis Coupe
and as far as the side discussion of brake feel ... a more rigid fixed caliper with firm up the brake pedal as there will be less deflection of the caliper under pressure
Old 06-06-2013, 08:21 PM   #12
RandR
Member#: 292132
2016 Cayman GTS
Racing Yellow
Brake fluid - high performance fluids eg AP600 are harder to compress and improve feel.
Adding a brake stop also makes a difference, as does adding higher coefficient of friction (increases "bite") brake pads
The mantra is tyres (tires) stop cars so to improve stopping distance you change to a better tire with higher static/kinetic friction - in a broad sense this correlates with decreasing UTQG rating (tread wear rating)
Nice wheels
RandR is offline   Reply With Quote
Old 07-23-2013, 10:04 PM   #13
BigTaco425
Member#: 347237
2013 WRX Limited E85
Satin Black Vinyl
I went with gunmetal on my '13 hatch. Hyper Silver was a little too bright for me.
BigTaco425 is offline   Reply With Quote
Old 07-23-2013, 10:06 PM   #14
BigTaco425
Member#: 347237
Satin Black Vinyl
Here is a more realistic, less Photoshop'd pic
Old 07-24-2013, 08:49 AM   #15
GregOrz
Member#: 339148
Cool. When posting pictures don't forget to put wheel and tire size specs.
Old 07-24-2013, 08:45 PM   #16
BigTaco425
Member#: 347237
Satin Black Vinyl
18x8 235/40
Old 07-28-2013, 05:27 PM   #17
GregOrz
Member#: 339148
18x8.5, 45mm offset
Dunlop Direzza ZII 245/40
Bilsteins and RCE Yellow Springs
Centric rotors, Stoptech brake pads, SS brake lines, Perrin MC brace
Old 07-28-2013, 08:52 PM   #18
PRD864
Member#: 363642
2011 SC v6 Camaro
Cyber Grey Metallic
Those look awesome!
PRD864 is offline   Reply With Quote
Old 03-16-2015, 10:46 PM   #19
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
So the 18x8 clears brembos, does that also mean the 18x8.5 does as well?
Also: necrobump.
AcquaCow is online now   Reply With Quote
