Old 08-22-2012, 10:12 AM   #1
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Default Old school JDM cluster compatibility?
Have a 93 WRX (RHD) that requires a new cluster. Looking online it appears that v3 clusters are SUPER easy to find, and the plugs appear to be the same as my v2. Anyone know if all early (v3 and older) clusters are compatible with each other?
tenchu is offline   Reply With Quote
Old 08-22-2012, 01:52 PM   #2
seangfy
Member#: 242150
1993 impreza L ej20g
aquafrost blue
They should be the same when I was re wiring my USDM 93 to work with a v3 sti cluster I found only one diagram for the clusters from 93-96 jdm wrx and sti
seangfy is offline   Reply With Quote
Old 08-22-2012, 02:43 PM   #3
RallyColtTurbo
Member#: 16819
'96 is still V2. V3 would be '97 (&'98?)
RallyColtTurbo is offline   Reply With Quote
Old 08-22-2012, 02:45 PM   #4
tenchu
Member#: 64147
1993 STi RA V LTD
Green
So does that mean I'm outta luck?
Old 08-22-2012, 03:20 PM   #5
seangfy
Member#: 242150
aquafrost blue
As long as its a cluster with the teach and speedo in the middle and the other two gauges on the side I think your safe
Old 08-22-2012, 05:28 PM   #6
RallyColtTurbo
Member#: 16819
Not neccisarilly. I just wanted to make sure you were looking at the correct wiring diagrams or seaching with the correct terms.
Old 08-22-2012, 06:30 PM   #7
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Was looking at like the ej20k ones with cf face that are all over (easier to find then v1/2)
Old 08-22-2012, 07:25 PM   #8
seangfy
Member#: 242150
aquafrost blue
Should work mine is the one with carbon fiber face
Old 08-22-2012, 07:41 PM   #9
tenchu
Member#: 64147
1993 STi RA V LTD
Green
You have a v1/2?
Old 08-22-2012, 09:28 PM   #10
69subaru360
Member#: 159682
1995 WRX
2015 F150
What's wrong with yours? I have some parts left over from one of them you can have. I swapped the 9k tach and the carbon face and orange needles into my usdm one.
Old 08-22-2012, 09:29 PM   #11
tenchu
Member#: 64147
1993 STi RA V LTD
Green
The circuit board
Old 08-22-2012, 09:37 PM   #12
69subaru360
Member#: 159682
1995 WRX
2015 F150
The circuit board
On the back? You can have mine if you want, I'm never going to use it for anything.
Pm me your address if you want it and I'll stick it in the mail.
Old 08-31-2012, 07:09 PM   #13
tenchu
Member#: 64147
1993 STi RA V LTD
Green
This guy is my hero.
Old 09-03-2012, 12:44 PM   #14
jdmwrx94
Member#: 211619
94 jdm wrx
red
I have a v2 cluster if you need it!
jdmwrx94 is offline   Reply With Quote
Old 09-03-2012, 12:49 PM   #15
tenchu
Member#: 64147
1993 STi RA V LTD
Green
69subaru360 hooked me up, my cluster works again
