Old 08-23-2012, 09:26 PM   #1
WRXander
Member#: 321048
2006 WRX Wagon
Java
Default 2006 WRX Wagon Trailer Wiring Install
I'm coming down to the wire on needing this installed and haven't been able to make it happen. I found a six pin connector in the back right pannel of the car but I'm not sure if that's what I need to splice into. I have a Curt convertor kit.
Any help would be greatly appreciated.
WRXander is offline   Reply With Quote
Old 08-23-2012, 11:15 PM   #2
emazz104
Member#: 281811
04 WRX
World Rally Blue
It should just plug right in, if you have the kit they're is no splicing.
emazz104 is offline   Reply With Quote
Old 08-24-2012, 12:31 PM   #3
WRXander
Member#: 321048
2006 WRX Wagon
Java
The kit I was sent doesn't have a connector pre-wired, just loose wires. I supposed I'll snip the wires I've found, connect the converter and see if it works.
Old 08-25-2012, 12:06 AM   #4
hoffmanEstates
Member#: 122043
04 wagonier
psm
Dont snip make shure you have all lamps signal going to the plug. The individual pins should correspond with what your signal is. Pm me ic need further assistance
hoffmanEstates is offline   Reply With Quote
Old 08-30-2012, 11:58 PM   #5
Sleeka
Member#: 326477
The forester trailer kit fits on that connector. I bought that for mine and it worked great. For some reason they don't list the impreza as compatible even though it is, at least on the wagon.
Sleeka is offline   Reply With Quote
