Old 09-06-2012, 09:34 PM   #1
SubieNubie88
Member#: 325391
2008 WRX
Default Squeaky Belt HELP
I have a stock 2008 WRX hatch.
When the car is cold and I start it up I have a squeaky belt. It squeaks when idle and a little while driving with and without AC ON. Sound does not change with acceleration or engaging clutch. After about 25 min of driving the sound is gone when idling. Any suggestions as to which belt this might be? I'm thinking maybe a serpentine.
Any advice or suggestions would be appreciated. Especially if anyone has experienced anything similar.
Thank You
SubieNubie88 is offline   Reply With Quote
Old 09-07-2012, 09:33 AM   #2
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Sounds like you have a loose belt that needs tightening
Old 09-07-2012, 10:30 AM   #3
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
It will be either your A/c or Power Steering belt. We cannot tell you which belt it is, we're not there to hear it.
Look at each belt, look for cracking on the ribs, or excessive wear all around. I would replace and make sure everything is properly adjusted. Belts are cheap.
Old 09-07-2012, 10:50 AM   #4
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Tighten both of them.... Likely both of them need it
Old 09-07-2012, 01:44 PM   #5
Paidfor
Member#: 267815
Be in awe
dont hate .)
Dont be to quick on jumping to the drive belts tho.........Ive had the same little minor belt squeek before too and i actually had a timing tensioner somehow break loose from the threads in the block and tilt a little. Caused the timing belt to "walk" just a hair...maybe a 1/8 inch or so. Back and forth on the pulley. Squeak squeak squeak.. Made the same damn sound, couldve sworn it was the drive belts, only did it while cold too. Only way i was able to pinpoint it was, well after i noticed that the drive belts were in great condition, made no change in sound after spraying belts with brake clean (Brake clean will temporarily stop a belt squeal if its that particular belt), i pulled the timing cover to see that bastard walkin. Fixed stripped out tensioner and t belt....all good!!!
Paidfor is offline   Reply With Quote
Old 09-07-2012, 06:46 PM   #6
SubieNubie88
Member#: 325391
2008 WRX
Thanks for the advice fellas ... Working on it tomorrow morning ... I'll post what the result is
Old 09-08-2012, 01:03 AM   #7
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Just now noticed you have an 08.... the AC belt on youre car is NOT adjustable, its a Gates stretch belt. They are a PITA to install
The Power steering/Alt belt IS adjustable though.
