Old 08-24-2012, 05:22 PM   #1
phreakwenci
Member#: 329549
Default 2.2L 95 Impreza.. easy way to fix thermostat?!?
Just bought an 95 2 door AWD impreza 2.2L, and when highway driving it's fine, when city driving she overheats after about 35-45 mins in the summer. So.. I first let her cool all the way down, then popped the hood, took off the radiator cap and turned her on, I saw bubbles for the first 90 seconds, then almost none, so I'm not sure that it's a bad head gasket, since afterwards I squeezed the hoses and they were very squeezable and soft. I'm thinking the Thermostat, I downloaded of the internets all the impreza manuals I could find, but seriously none of them show how to change the Thermostat. I'd buy a manual, but I'm a stereotypical poor (but damn good lookin!) actor in L.A.
So is there an easy how to guide for changing the Thermo on the 2.2L somewhere I can find? Are there any bitch bolts I need to be aware of? Etc?
Any help would be appreciated.
J.D.
phreakwenci is offline   Reply With Quote
Old 08-24-2012, 05:54 PM   #2
thebeephaha
Member#: 248063
2003 Forester 2.5XTi
Supercharged in Gold
thebeephaha is offline   Reply With Quote
Old 08-24-2012, 06:02 PM   #3
phreakwenci
Member#: 329549
Oh wow. THANKS! I was wondering where the hell it was!
Old 08-25-2012, 01:12 PM   #4
thebeephaha
Member#: 248063
No problem.
Old 08-25-2012, 02:41 PM   #5
StealthTL
Member#: 206912
2006 Forester XT
Sad, but I don't think the symptoms fit a bad thermostat.
If the thermostat fails closed, you won't be driving anywhere after 10 minutes of warm up, and if it failed open you have no heat and the gauge never budges off 'cold'.
Your prob sounds like a plugged rad, or worn out water pump.
Look for deposits in the rad tubes....
StealthTL is offline   Reply With Quote
Old 08-25-2012, 02:48 PM   #6
97ej22e
Member#: 327710
1999 Impreza OBS
Green
Hmmm I wonder if my T stat is bad, my car usually stays all the way down at cold and occasionally will come up about 1/4 of the way but then goes back down. I have new head gaskets and it was doing the same before I replaced them too.
97ej22e is offline   Reply With Quote
Old 08-27-2012, 03:09 PM   #7
phreakwenci
Member#: 329549
OMG. Guys... I seriously can't believe this.
This is the old thermo I just took out next to the new one
http://twitter.com/JanDavidSoutar/st...445248/photo/1
The previous owner broke it and then installed it. OMFG.
I'm speechless. I also don't have a clue which way my thermostat needs to be installed! which way does the jiggle pin need to point to? East west north south?
Help!?!
