Closed Thread
Old 09-07-2012, 01:44 PM   #326
stewb
Member#: 154753
2008 STI
Default Subaru can do no wrong
Originally Posted by Goempie View Post
A chasis that most recembles with the BRZ and the engine lower and more backwords.
Not unless they're doing away with AWD.
Originally Posted by endlesss View Post
I think you are going to be very disappointing if these are your expectations for the next gen WRX/STI... Hopefully I'm wrong.
Maybe someone will, but the Subaru apologists will be here in force spinning everything that is wrong with the STi as positive.
stewb is offline
Old 09-07-2012, 02:45 PM   #327
Snow Drift
Member#: 75071
4 Train - Subway
Past: 05, 08, 11 Red WRXs
They could use the BRZ chassis (which is just a shortened Impreza) for the next WRX, and they should to get it closer to the DS3 in size. The chassis does not prevent AWD, it is the location of the engine/tranny being too far back that does.
The GC had a shorter wheelbase than the BRZ. The 02-07 WRX was very close too.
Snow Drift is offline
Old 09-07-2012, 03:19 PM   #328
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Are you planning to run the front wheels directly off pistons 3 & 4?
Calamity Jesus is offline
Old 09-07-2012, 03:33 PM   #329
RallyColtTurbo
Member#: 16819
....The GC had a shorter wheelbase than the BRZ. The 02-07 WRX was very close too.
IIRC, the GC and GD had the same wheelbase as each other. Technically, the versions with the high castor front arms had a slightly longer wheelbase.
RallyColtTurbo is offline
Old 09-07-2012, 04:01 PM   #330
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
the easiest solution here would be to put the engine in the middle, have cylinders 1&2 connected to cylinders 3&4 via a LSD, and then they are connected via a front and rear output shaft to two 6 speed transaxles at front and rear.
samagon is offline
Old 09-07-2012, 05:16 PM   #331
WRX4US
Member#: 162846
How about moving the engine back completely behind the front wheels and having the drive shaft(s) coming from both the front and back ends of the engine?
WRX4US is offline
Old 09-07-2012, 05:31 PM   #332
Snow Drift
Member#: 75071
4 Train - Subway
You are correct.
GC = 99.2
02 = 99.4
Well this could work for the BRZ to be AWD:
Old 09-07-2012, 05:48 PM   #333
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
Why is there so much crazy talk going on in here?
299WHP WRX with a robust 6-speed manual. Rear LSD.
399WHP STI with a robust SEVEN-speed dual-clutch system. Two doors. One love.
*drops microphone and bows out*
chanomatik is offline
Old 09-07-2012, 05:53 PM   #334
samagon
Member#: 26859
of TXIC
asks why so much crazy talk, promptly talks crazy.
No, no, no. put the engine in the drivers seat, put the driver in the engine bay. and def a bigger wing.
samagon is offline
Old 09-07-2012, 05:58 PM   #335
slimfit
Member#: 90597
2011 WRX Premium
^This
slimfit is offline
Old 09-07-2012, 06:08 PM   #336
neg_matnik
Member#: 132389
2006 WRX Wagon SGM
2003 SV1000S, 2014 DL650
399WHP STI with a robust SEVEN-speed dual-clutch system. Two doors. One love.[...]
As long as the same robust manual 6-speed is offered as well then it's OK. These dual-clutch systems don't do well with heat and it's an issue for us track day / HPDE rats .
We already have to keep an eye on engine oil and water temp and we wouldn't like to have to monitor tranny temp as well .
neg_matnik is offline
Old 09-07-2012, 06:18 PM   #337
Snow Drift
Member#: 75071
4 Train - Subway
Just so you know that diagram is of the Japanese GT300 Legacy race car. That is exactly how it was set up.
Old 09-07-2012, 06:24 PM   #338
Goempie
Member#: 166202
Why do you say that? I could be wrong. But weight saving is the main key. With more horsepower you are faster on the straights. With a lighter
car you are faster everywhere.
Goempie is offline
Old 09-07-2012, 06:32 PM   #339
Goempie
Member#: 166202
And for the AWD system. After all this tumult they had on the BRZ they won't let go on
the symetrical AWD. For years now they are investigating every manner to fit al the diff's and engine different to the setup now. Do you think that subaru, with the devellopment of the BRZ, never had it in mind with AWD?
They raised a bar with a RWD on the first attempt ( with the help from Toyota). They will raise the bar again on this one.
Goempie is offline
Old 09-07-2012, 06:54 PM   #340
Obsessive
Member#: 77302
damn well better
bail me out of this ****
You are correct.
GC = 99.2
02 = 99.4
lol... wtf???!
Are you ****ing drunk?
Obsessive is offline
Old 09-07-2012, 07:03 PM   #341
Obsessive
Member#: 77302
damn well better
I have a better idea...
Old 09-07-2012, 07:24 PM   #342
Derbagger
Member#: 32113
05 Saabaru
Satin Grey
I'm thinking 4 cylinder AWD, with one cylinder powering each wheel. That would leave more passenger room in the middle while balancing weight. And with 4 electric turbochargers sourced from the hair appliance section of CVS, you don't even need complex exhaust piping.
Seriously, I'm expecting a 2.0L turbo in the vicinity of 270hp for the WRX with a LGT 6-speed tranny and CVT option, with the STi making in the 320 range with all the techy racy bits. Maybe a double clutch (although that would likely be alot of engineering to put out at once).
I'm hoping to get a WRX with leather and sunroof, 0-60 in @5.5, MPG of 20/30 ish and a 29k price for that level of option. I don't even want nav now with the sony mirrorlink thingie or whatever. Just range it from 27-32k with the STi being 34-39k.
IF they go with an actual smaller car to make a run at WRC again (I really think that such is a longshot) then they should make both, as there is too much brand equity in a performance car of Impreza size. But they did drop "Impreza" from the UK WRX, so maybe that's what they mean for us.
Derbagger is offline
Old 09-07-2012, 08:08 PM   #343
King Ding187
Member#: 2598
2002 WRX Wagon
Originally Posted by Obsessive View Post
lol... wtf???!
They've already done it on the track, and it even took a win in the GT300 Class of Japanese Super GT. You'll notice in the video that the driver sits pretty far back, but in a hatch back with short rear overhang that would create excellent weight balance. I for one hope Subaru was testing this on track for future production models.
King Ding187 is offline
Old 09-07-2012, 08:13 PM   #344
chanomatik
Member#: 159474
SNOSLO
lolDerbagger is hoping for a WRX that is slower (5.5) than the current WRX! That's very nice of you to expect that already just in case it does happen.
Seriously, though, I'm at least expecting some weight-savings by making the WRX/STI more focused driver's cars. I think THAT'S what they're taking from the BRZ: Driver's car. They're all about carrying over philosophy.
Old 09-07-2012, 08:15 PM   #345
waltah
Member#: 317856
someone change the title to "next wrx drivetrain" caught testing.
waltah is offline
Old 09-07-2012, 08:33 PM   #346
meebs
Member#: 3251
2009 WRX Hatch
I think Ferrari has you beat.
No...they're not drunk.
meebs is offline
Old 09-07-2012, 10:31 PM   #347
Obsessive
Member#: 77302
damn well better
http://youtu.be/tFy1r4Htd6E
Where's the oil magnet, the midget, and the uber driveshaft? That is nothing like my design. That takes power from the front of the crankshaft, my driveshiaft has two 90 degree bends and a 30 degree bend. Plus, it has magnetic motor oil which allows you to mount the oil pan upside down and still have oil within it. This coupled with the midget helps lower CG. They are infringing on my patent.
Actually, you've just proven yourself learning disabled because you took a drawing that labeled items as 'midget' and 'oil magnet' and tried to dispute it. derp....
Old 09-07-2012, 10:36 PM   #348
Obsessive
Member#: 77302
damn well better
HD版/世界最速の新型LEGACY B4がスーパーGTに初参戦!! - YouTube
I can't understand what he's saying, so it's completely BS until I hear HIM say it in english. Plus, he isn't quite a midget and his drivetain is not nearly complex and power robbing as mine. Try to find a rare earth oil magnet. Do it.
Old 09-08-2012, 09:39 AM   #349
endlesss
Member#: 196720
2015 WRX STI
Dark Gray Metallic
I think the outcome will be: A car that is about 150 a 200 kgs lighter than the current one. A chasis that most recembles with the BRZ and the engine lower and more backwords. Output of the engines a little up. of course WRX a 2.0l and sti 1.6.
I think 150kg to 200kg is a tall task. Certainly I would hope they would save some weight, but that much weight is asking a lot. Also, to say that the chassis will most resemble the BRZ also seems ambitious. I expect it being very close to the Impreza, just without the Impreza badge. Perhaps I'm being a bit pessimistic. In an ideal world I certainly hope your predictions are right.
endlesss is offline
Old 09-08-2012, 09:51 AM   #350
WRX4US
Member#: 162846
More impracticability won't sell more cars.
WRX4US is offline
Closed Thread
