Old 08-24-2012, 09:41 PM   #1
MarcoPolo360
Member#: 265006
2011 2.5i 5MT
World Rally Blue
Default Welded Axle-Back Bolts?
I was trying to get the bolts connecting my axle-back to my cat-back off, but they wouldn't budge. Just so I don't go wasting more time trying to twist them off, I wanted to ask; Do these bolts come welded on from the factory?
MarcoPolo360 is offline   Reply With Quote
Old 08-24-2012, 09:51 PM   #2
Gmantanman
Member#: 281840
2011 2.5i 5MT
SSM
No they aren't welded. I use a wrench to hold one side from moving and a ratchet for the other. It is quite a tough spot to work cause you can't use more of your body to get those bolts free (If your car isn't lifted). Start working out your forearms and biceps I guess.
Gmantanman is offline   Reply With Quote
Old 08-25-2012, 12:37 AM   #3
MarcoPolo360
Member#: 265006
2011 2.5i 5MT
World Rally Blue
I'm glad they aren't, but at the same time I'm not looking forward to having to get all that caked rust off. I didn't put too much effort into it, so I'll have to have a good go at it tomorrow.
Thanks for the help.
Old 08-25-2012, 01:17 AM   #4
Bababou
Member#: 280689
2010 2.5i Impreza
Newport blue
WD 40 and liquid wrench are your friends.
Bababou is offline   Reply With Quote
Old 08-25-2012, 11:10 AM   #5
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Use a penatrant and air tools. The hammering of the air tool helps to break it loose without breaking it.
Old 08-25-2012, 12:12 PM   #6
mustardman
Member#: 258718
07 2.5i
WD40...spit...some anger and ohh a ratchet and wrench will help a lot
Mine was impossible to get off...living in chicago the bolts basically rusted onto the flange...**** salt!
mustardman is offline   Reply With Quote
Old 08-25-2012, 04:05 PM   #7
GrundleJuice
Member#: 165749
PB Blaster is far more effective than WD40 and liquid wrench. some heat from a torch will only help, too.
Old 09-24-2012, 03:15 PM   #8
MarcoPolo360
Member#: 265006
2011 2.5i 5MT
World Rally Blue
Forgot to update. Thanks for the suggestions everyone! I ended up getting them off with a TON of penetrant and an equal amount of elbow grease!
