Old 12-14-2012, 07:55 AM   #1
Boxerscoopy90
Member#: 309974
Default Sway bar installation
Guys i 've installed my rear sway bar on my 07 impreza while the car was lifted and tightned every thing and so far its been two days and everything is fine . I 've read now that i shouldnt have lift the car and that it should have been on ramps so my question is what should i do now ? Is there any thing bad might happened ?
Boxerscoopy90 is offline   Reply With Quote
Old 12-14-2012, 07:57 AM   #2
sc00by4life
Member#: 97135
haha.
it doesn't really matter dude. if it aint makin noise, its fine. people just suggest ramps because its easier to get both endlinks connected on the rear with the suspension compressed.
sc00by4life is online now   Reply With Quote
Old 12-14-2012, 08:22 AM   #3
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
The point of being on ramps is to have the suspension compressed with the weight of the vehicle. This simply ensures that there are no bumps, clunks etc in the system. If you don't have any, you are fine.
Old 12-14-2012, 08:34 AM   #4
1wrxtra
Member#: 316364
2012 WRX
I didn't have mine under load when I did mine and it turned out to be a little difficult to align the bar with the endlinks with the adjustable setting that I wanted. I managed, but that was the only issue I encountered other than the whiteline endlink brackets rattling back and forth inside the control arm. Some washers fixed up that problem and now it's all good.
You shouldn't have any significant issues if the installation went well.
1wrxtra is offline   Reply With Quote
Old 12-14-2012, 08:47 AM   #5
cmiovino
Member#: 134005
2004 WRX Premium
I normally find if you tighten everything up while it's lifted, when you lower it, the endlinks will be pulled and stretched to near breaking, especially if you keep the stock plastic ones.
I've installed 5-6 rear swaybars on various GC/GF/GD models and it's all the same. I now tighten everything up once it's on the ground. If you're concerned, just peak under and see what the endlinks look like. If they look stressed.. like majorly, ready to break... then I suggest tightening them on the ground.
Old 12-14-2012, 10:05 AM   #6
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Ramps ftfw. Just makes things sooo much easier
Old 12-14-2012, 10:41 AM   #7
WRXLTD
Member#: 136314
2014 Grand Cherokee
With your suspension loaded (on ramps), re-tighten all the sway & end link fasteners again just to make sure.
Hope you greased your sway bar bushings!
WRXLTD is offline   Reply With Quote
Old 12-16-2012, 06:02 AM   #8
Boxerscoopy90
Member#: 309974
Thx guys so far there is no noise at all but iwhen i take a look under the car i've fount that the right endlink is slightly stressed but the left is fine so i guess i'm going to loose it and retighten everything again with the suspension being loaded
Old 12-16-2012, 05:37 PM   #9
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
+1.
Having the wheels on that axle loaded just makes it easier to do the bar swap.
If the wheels are hanging, the endlinks can be a PITA to deal with.
Old 12-17-2012, 12:06 AM   #10
Boxerscoopy90
Member#: 309974
Alright i 've another question should i tighten the bolt which connects the sway bar to the endlink ?
Old 12-17-2012, 12:43 AM   #11
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Should you tighten it? Uhhhhh...Yes...
Old 12-17-2012, 09:21 AM   #12
Boxerscoopy90
Member#: 309974
The reason i asked this question is that i've read that if u tighten it too much u might hear some noise from the back thx
Old 12-17-2012, 10:41 AM   #13
chino_487
Member#: 209156
2009 WRX Sedan
SSM
you will hear more noise if you DONT tighten it...
chino_487 is offline   Reply With Quote
