#1 |
Member#: 43038
Vehicle:2002 Forester S Black |
I drained my radiator on a 153000 Forester I bought today. I replaced with a 50/50 Subaru coolant distiller water mix. I also added the coolant conditioner.
After draining my radiator for an hour to where nothing was coming out I filled it back up. It topped out at 1.25 gallons. I thought the capacity was 2 gallons. Did all the coolant not come out?
#2 |
Member#: 312107
NESIC
Vehicle:1998 LowFoz Glacier White |
You didn't get all the old coolant out. And you have to burp the system when draining and filling to get rid of all the air bubbles. Do that and you should be good
#3 | |
Member#: 43038
#4 |
Member#: 271442
Vehicle:2006 Impreza 2.5i CGM |
#5 | |
Member#: 43038
#6 | |
Member#: 273906
NESIC
Vehicle:1831 Conestoga Wagon My oxen all died. |
Also, someone correct me if I'm wrong...but you will never get all of the coolant out by draining it just out of the rad drain **** (it thinks I said slang for penis). Maybe you could have gotten a bit more out, but there always will be some left. I think capacity is like 7.5 quarts. Edit: Pretty sure I've only gotten 1.25 to maybe 1.5 gallons out when I do it. |
#7 | |
Member#: 154586
BAIC
Vehicle:1996 ej22 Outback White |
#8 |
Member#: 220808
SCIC
Vehicle:2005 WRX Wagon Silver |
if you really wanna get it all out you can disconnect your spark plugs and just turn the motor over which will pump out all the old coolant. Then fill it up with just distilled water until you get all the air bubbles out and you have it at maximum capacity. Let the engine get to operating temp and cycle the fan maybe two times or so. Drain all of that out and then add the coolant from subaru and conditioner if you have it.
