Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 08-25-2012, 05:27 PM   #1
biglittledog
Member#: 192519
Default diagnose my bad engine noise...2.5L DOHC...
Here is the rather nasty noise our 2000 Forester started making when my wife was driving home yesterday. It sounds the same hot or cold and varies with engine speed. Sounds like a T-belt pulley?
The car has 170k and had the belt done back at 90k-ish.
Here is a link to a short video I made so you can hear it at idle...
Please let me know what you think! Any ideas are welcome...
Thx,
Steve in Colorado.
biglittledog is offline   Reply With Quote
Old 08-25-2012, 07:57 PM   #2
jetfan2207
Member#: 61950
2008 Outback
big blue wagon
I'm no expert but I'd say either bad pulley OR possibly worn alternator. My first car was an 88 Chevy pick`em up truck that sound similar to that when the alt. was going.
jetfan2207 is offline   Reply With Quote
Old 08-25-2012, 10:28 PM   #3
tylerd4213
Member#: 328251
2011 Impreza 2.5i
Obsidian Black Pearl
Post
The alternator and every other pulley is disconnected in the video, but it could still be the bearing for the crank pulley. Does it get much louder when you rev it?
tylerd4213 is offline   Reply With Quote
Old 08-26-2012, 12:50 AM   #4
STi Guy 69er
Member#: 82648
2005 Impreza 2.5 RS
Timing belt idler pulley for sure.
STi Guy 69er is offline   Reply With Quote
Old 08-26-2012, 12:56 AM   #5
thefoz98
Member#: 310144
98 Forester
i didn't think the 2000 forester's had the DOHC 2.5
thefoz98 is offline   Reply With Quote
Old 08-26-2012, 08:59 AM   #6
2.5iImpreza
Member#: 234791
2006 2.5i Sportwagon
Crystal Metallic Grey
That is the horrible sound of a timing belt tensioner committing suicide, i just had let go on my 99 Outback 2.5
2.5iImpreza is offline   Reply With Quote
Old 08-26-2012, 12:12 PM   #7
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
Pull off the timing cover and belt before your motor goes t!ts up. Play around with the pulleys and i am sure one or more may need replacing. If they make any noise or spin really freely, replace them. If they only spin a couple rotations quietly, they are still good. My guess is either the water pump or the tensioner.
bugeyetex is offline   Reply With Quote
Old 08-26-2012, 05:27 PM   #8
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
yup, sounds like timing belt idler/water pump. test them out.
Old 08-27-2012, 08:26 PM   #9
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Crank pulley bearing It doesn't exist afaik
geronimo81 is offline   Reply With Quote
Old 08-28-2012, 10:03 AM   #10
subi400
Member#: 216984
1996 Impreza outback
Green
That is bad!!!!!!!!!!
Need to get the crank pulley off and replace all 3 of the timing belt pulleys ASAP! Check the water pump for any small leaks and see if the shaft moves any. If that belt snaps, or it gets out of time by a couple of teeth your engine's heads will need a rebuild.
I know of a site where you can get the good double bearing timing belt pulleys from. I have seen the good ones on ebay as well. DO NOT GET THE SINGLE BEARING PULLEY'S, they are garbage and won't last long, trust me as I need to replace 3 in my car because I had got the cheap ones...
subi400 is offline   Reply With Quote
Old 08-28-2012, 01:25 PM   #11
Mishimoto
NASIOC Manufacturer
Member#: 207954
I am with these guys. Looks like you caught it just in time.
Mishimoto is offline   Reply With Quote
Old 09-01-2012, 10:07 AM   #12
biglittledog
Member#: 192519
Smile
Thanks! Thanks! Thanks!
Sorry about the delay getting back to you guys. I opened the timing cover up and everybody was correct! I'm amazed the shot pulley didn't come all the way off (apparently the plastic cover kept the gear from coming all the way off the shaft). We are very lucky it didn't!
*clickable thumbnails and if you click again after it's open, it will get bigger...
I just finished replacing everything after a really thorough cleaning to get all the metal shards out. Also did the water pump while I was in there.
Thanks for all your advice!
Old 09-01-2012, 10:13 AM   #13
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
glad we could help. thx for following up.
Old 09-04-2012, 03:33 PM   #14
Mishimoto
NASIOC Manufacturer
Member#: 207954
Another subie saved by the folks at Nasioc.
Old 09-06-2012, 07:15 AM   #15
aapstealth
Member#: 327525
Holy cow I had a slight noise when I changed mine but wow yours seems to have really given out. That video should be saved or tagged so others can refer back for the sound and problem.
aapstealth is offline   Reply With Quote
Old 09-06-2012, 02:58 PM   #16
02darkRS
Member#: 80918
02-7 MBP RS/i hybrid
now w/ AVLS!
I'm assuming 5 days later, you're up and running.... but if not, you might want to look deeper before putting it all back together. Mine went in much the same manner. I can't imagine that this happened without bending valves.
http://www.rs25.com/forums/f13/t4998...verywhere.html
02darkRS is offline   Reply With Quote
