Alaskan Impreza Club
Old 11-01-2013, 03:48 AM   #2801
TheRedBarron
Member#: 353434
2013 WRX Premium 4D
Ice Silver Metallic
Originally Posted by _davin View Post
The silver looks a lot better than I thought it would.
Is that with the winter tires on? If so they don't look too scrunched lol
TheRedBarron is offline   Reply With Quote
Old 11-01-2013, 05:16 PM   #2802
_davin
Member#: 260501
2003 miata SE
Blurple
Yeah, sorry I forgot to pm you back.
Not much room left, lol. Haven't heard any rubs yet though.
_davin is offline   Reply With Quote
Old 11-01-2013, 05:18 PM   #2803
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
I should snap a pic of mine. It rubs over hard bumps and sharpish turns. I have to drive more like a truck (read: sane person) now.
Old 11-01-2013, 06:00 PM   #2804
TheRedBarron
Member#: 353434
2013 WRX Premium 4D
Ice Silver Metallic
Yeah, sorry I forgot to pm you back. Not much room left, lol. Haven't heard any rubs yet though.
Looks alright. What size were those again? Think a 27.5"x9.5 is doable?
Old 11-01-2013, 06:19 PM   #2805
_davin
Member#: 260501
2003 miata SE
Blurple
Upon further inspection on the other side after Chano pointed it out, it definitely is touching when turned in slightly.
225/55-17
I believe the diameter at full tread is 26.9", so you may have to modify your Fender liner. I'm guessing that's a wider tire though and you'll be lifted, so it sounds like a guinea pig situation.
Old 11-01-2013, 06:30 PM   #2806
chanomatik
Member#: 159474
SNOSLO
Ain't no room to play right thurr!
Old 11-01-2013, 09:02 PM   #2807
TheRedBarron
Member#: 353434
2013 WRX Premium 4D
Ice Silver Metallic
Upon further inspection on the other side after Chano pointed it out, it definitely is touching when turned in slightly. 225/55-17 I believe the diameter at full tread is 26.9", so you may have to modify your Fender liner. I'm guessing that's a wider tire though and you'll be lifted, so it sounds like a guinea pig situation.
According to interco tire company and a tire sizing calculator my swampers are only .5" bigger in diameter and only .5" wider than the stock Dunlop tires that come with the wrx. I will be on about 2" of lift total and hopefully if the tires fit I'll get another inch or so. If I have to take the dremel to the fender liner and make a few small cuts to prevent rubbing than so be it
Old 11-01-2013, 11:40 PM   #2808
kingfuzz
Member#: 354354
I kniw I'm a soob noob but I wish I wasn't driving out in january. I would offer a straight trade for suspension setup. I'm assuming since yours fits mine that mine would fit yours with some added room of course
kingfuzz is offline   Reply With Quote
Old 11-02-2013, 04:22 PM   #2809
_davin
Member#: 260501
2003 miata SE
Blurple
The OEM WRX Dunlops are 25.4", so if yours are 27.5 that's over 2 inches larger diameter...
Old 11-02-2013, 05:01 PM   #2810
TheRedBarron
Member#: 353434
2013 WRX Premium 4D
Ice Silver Metallic
Yep so essentially just 1" extended out in any direction (radius). From what I can see it shouldn't cause too much trouble if there'll be an extra 2" in suspension and stiffer springs. Only place I could see rubbing is on the bottoms of the fenders, and possible when fully turned to one side or another. Honestly the only way I'll probably find out I by pulling the trigger and giving it a shot. I'll see what some shops around here think, and hopefully they won't give me too much crap about it haha
Old 11-03-2013, 01:05 AM   #2811
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Fitting together some things before sending out a package for chroming.
Big-Sexy907 is offline   Reply With Quote
Old 11-03-2013, 02:35 AM   #2812
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
Nice. It's strange to see things painted or coated, that are usually bare plastic or aluminum. That's gonna look good.
Dominator is offline   Reply With Quote
Old 11-04-2013, 04:19 PM   #2813
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Thanks, hopefully after I get the stuff back from chroming I can put it back together one last time. By then I should have the engine bay and trunk finished and painted so I can work on the brake lines, then after all that's said and done I'll be able to start on the exterior.
Old 11-04-2013, 04:41 PM   #2814
insane_one
Member#: 301431
2005 Evolution VIII
putting an end to this identity issue.
insane_one is offline   Reply With Quote
Old 11-04-2013, 04:55 PM   #2815
chanomatik
Member#: 159474
SNOSLO
Are you seeing red?! Kevin ==>
Old 11-04-2013, 05:11 PM   #2816
khann23
Member#: 302662
Finally got around to painting my 06 tail lights. Been rockin the 04-05's for the last few years figured id try something different.
khann23 is offline   Reply With Quote
Old 11-04-2013, 05:16 PM   #2817
chanomatik
Member#: 159474
SNOSLO
Those look so throwback!
Old 11-04-2013, 05:18 PM   #2818
AK_GT
Member#: 275567
2010 WRX
I've been lazy... Weekend before last I finally swapped out the summer tread for some winter goodness. Went ahead and changed the oil, checked my brakes (still a 1/16th left on the passenger pads...) replaced my cracked fog light, and installed the Grimmspeed heat shield I've had laying around for almost a year. Maybe if I'm not too lazy, I'll snap a picture of the winter setup.
AK_GT is offline   Reply With Quote
Old 11-04-2013, 07:22 PM   #2819
insane_one
Member#: 301431
2005 Evolution VIII
.... sometimes..
Old 11-04-2013, 10:28 PM   #2820
_davin
Member#: 260501
2003 miata SE
Blurple
OMG new clutch...
Old 11-04-2013, 10:29 PM   #2821
kyletakahero
Member#: 185030
2008 FXT Sport
Aspen white
OMG new clutch...
Is it beautiful?
kyletakahero is offline   Reply With Quote
Old 11-04-2013, 11:04 PM   #2822
_davin
Member#: 260501
2003 miata SE
Blurple
Originally Posted by kyletakahero View Post
Is it beautiful?
It's like learning to drive a new car, I had no idea. I stalled it leaving element.
Old 11-04-2013, 11:52 PM   #2823
insane_one
Member#: 301431
2005 Evolution VIII
i know that feel bro.
Old 11-05-2013, 01:00 PM   #2824
Frmrbob
Member#: 290921
2010 Impreza WRX prm
WR Blue
Just Ordered The KSTech CAI Big MAF 83mm planing on getting a meth kit next then getting retuned this month. Should be Awesome with my Build
Frmrbob is offline   Reply With Quote
Old 11-05-2013, 03:02 PM   #2825
chanomatik
Member#: 159474
SNOSLO
I second this, plus feel of fixed transmission. Nothing quite like it. Sex.
