Alaskan Impreza Club
Old 09-27-2012, 06:31 PM   #301
White_Rice
Member#: 160049
My heads/valves/block/crank just got picked up from ADB. 3angle/back cut/laser hone/polish FTW!!!
White_Rice is offline   Reply With Quote
Old 09-27-2012, 08:51 PM   #302
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
Pics or it didn't happen...lol
tribalwrx is offline   Reply With Quote
Old 09-27-2012, 09:03 PM   #303
White_Rice
Member#: 160049
Pics on completion. And then some......
Old 09-27-2012, 10:26 PM   #304
QwikEVO
Member#: 44172
2006 Lancer Evo 9
Plasti-Dip is for TOOLS
Not a Subaru, but Todd replaced my serpentine belt today.
It's blue.
Now my car is hella fast.
QwikEVO is offline   Reply With Quote
Old 09-28-2012, 12:34 AM   #305
furtive
Member#: 320658
2015 S3
Daytona Gray
Installed a rear backup cam!
furtive is offline   Reply With Quote
Old 09-28-2012, 12:51 AM   #306
AK-Okie
Member#: 270850
2011 WRX Hatch
Spark Silver
On your BRZ or pilot...?
AK-Okie is offline   Reply With Quote
Old 09-28-2012, 01:32 AM   #307
furtive
Member#: 320658
2015 S3
Daytona Gray
BRZ ! you still need to hear my sexy exhaust LOL
Old 09-28-2012, 02:14 AM   #308
Getagrip
Member#: 2045
BRZ
On the BRZ I took off my StarSpecs and mounted some all-seasons on as intermediate tires before the studs go on.
Aligned the toe since I had maxed out my front camber with some crash bolts. Got -1 degree from having zero. Not bad for spending $8.
Had Katelyn customize my BIU settings (Thanks!)
All in an evening's work.
Getagrip is offline   Reply With Quote
Old 09-28-2012, 02:32 AM   #309
Rookie J
Member#: 281747
2005 Legacy GT Wagon
Element Sponsored
Got my new license plates in thesis today.
I also got retuned by Paul over at retraC Engineering.
Rookie J is offline   Reply With Quote
Old 09-28-2012, 02:48 AM   #310
rnguyen
Member#: 330498
2002 wrx
Finally done.. Kinda rushed it, could of used more sanding but here is the finished project! Gauge pod under 40 bucks!
rnguyen is offline   Reply With Quote
Old 09-28-2012, 03:09 AM   #311
05GDF
Member#: 281488
2005 STi
Awesome job man!
05GDF is offline   Reply With Quote
Old 09-28-2012, 07:52 PM   #312
White_Rice
Member#: 160049
Ok proof
Old 09-29-2012, 12:19 PM   #313
Nomadgene
Member#: 22923
2002 EJ207 V8 1.5xtr
TWIN-SCROLL Black Bugeye
Tire change over…so I can get out of my driveway. A good six inches on the ground up here on the hillside and it is still coming down.
Earliest I've seen it snow this much in the 15 or so years I've been here.
Nomadgene is offline   Reply With Quote
Old 09-29-2012, 10:25 PM   #314
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Finally got my saggy butt spacers installed. Thanks Chad & Mike!
Old 09-29-2012, 11:21 PM   #315
Bgross129
Member#: 291696
2005 sti
obp
Spun a rod bearing new bottom end in the works maybe a 2.7 Stroker this time
Bgross129 is offline   Reply With Quote
Old 09-30-2012, 12:36 AM   #316
White_Rice
Member#: 160049
tHAT sucks/rocks.
Old 10-01-2012, 03:13 AM   #317
Racer Dubya
some old guy
Member#: 112225
1985 78 HP of Rage!
hammered, sanded, mud, glaze, sanded... etc. My garage has a layer of dust on everything.
Racer Dubya is offline   Reply With Quote
Old 10-01-2012, 11:57 AM   #318
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
Powertrain Warranty don't fail me!
I bought Rory's snow tires for the BRZ. 16" steelies wrapped in 205/55R16 studded Hankooks. Now I just gotta get the car this week, get the autostart installed this weekend or so and clear bra when I get paid on the 15th and I'll be good to go!
Old 10-01-2012, 02:35 PM   #319
insane_one
Member#: 301431
2005 Evolution VIII
I bought Rory's snow tires for the BRZ. 16" steelies wrapped in 205/55R16 studded Hankooks. Now I just gotta get the car this week, get the autostart installed this weekend or so and clear bra when I get paid on the 15th and then order the Greddy Turbo kit and I'll be good to go!
thats a solid plan! hope it all works out
insane_one is offline   Reply With Quote
Old 10-01-2012, 02:44 PM   #320
chanomatik
Member#: 159474
SNOSLO
lol No turbo for me! At least not as a main engine. On a secondary engine just for tuning fun I'd give it a try. Already talking with a shop to see what can fit in there. I'm thinking a rebuilt EJ20, personally, just to go with something tried and true. The issue is weight. It's already heavier up front at 53%. All the plumbing for turbo and such won't help the case concerning weight.
This is my benchmark.
Old 10-01-2012, 03:44 PM   #321
AK SloPok
Member#: 56464
12 Ram
Sadly I worked on the Forester on Saturday to get the spool out. Went very smoothly thanks to two things, one a lift (thanks Seth) and two, Mike for being Captain Wrench-a-lot!
AK SloPok is offline   Reply With Quote
Old 10-01-2012, 05:44 PM   #322
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
i here ya loud and clear, my friend kept laughing everytime i started clean because dust was everywhere and id get done and we would start sanding again
Alaskan EJ20 is offline   Reply With Quote
Old 10-03-2012, 01:41 AM   #323
kayetealynn
Member#: 253304
2001 Impreza 2.5RS
Plus MOAR
Drove all three cars today - LOL.
Tomorrow will be a busy day for the WRX...need to install a new oil pump - the 11mm one is not working for me...The oil pressure has started hanging out at 15psi down from 20-25 at idle which is not good. I'm hoping to avoid teardown...but I guess we'll see. Dale did a leakdown on Monday and found it totally normal - also replaced the spark plugs which were of course fuel fouled because the car has been running wickedly rich at idle.
Also going to try and swap the stock injectors in to see if that is the mysterious problem that has been holding the car back even though they tested out fine 3 weeks ago. May also test fuel pressure to rule out the pump and FPR. And we're probably going to check for vacuum leaks...for the third time.
kayetealynn is offline   Reply With Quote
Old 10-03-2012, 02:06 AM   #324
granny
Member#: 283145
1997 LEGASTi Wagon
[email protected]
Man I want to see this thing. Just been too busy to swing by.
granny is offline   Reply With Quote
Old 10-03-2012, 04:25 AM   #325
tribalwrx
Member#: 32993
vf39 Best trap 110
Your welcome Chad, it was actually alot of fun
