Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Alaskan Impreza Club
Old 10-10-2012, 01:58 AM   #351
Frmrbob
Member#: 290921
2010 Impreza WRX prm
WR Blue
Nice anybody have auto start on there cars curious on how well they work for Subaru I had a person back in New Mexico at a car and audio shop tell me it's not possible for the WRX and that they would have to rig it up and take one of my keys for it to work. No to me that don't sound right and he was pretty shady . Looking to see what people have and what's the best with security.
Frmrbob is offline   Reply With Quote
Old 10-10-2012, 02:42 AM   #352
Rookie J
Member#: 281747
2005 Legacy GT Wagon
Element Sponsored
Did an oil change and put on the studs yesterday at retraC Engineering.
Rookie J is offline   Reply With Quote
Old 10-10-2012, 04:10 AM   #353
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
I use compustar. Has a built in turbo timer which is a plus. Seeing as i use it at times with my oil cooled only turbo.
cosseywrx is offline   Reply With Quote
Old 10-10-2012, 11:23 AM   #354
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
Originally Posted by furtive View Post
What kind of auto start?
A very basic model from Northstart from a Groupon early this year. I think it's Aerostar AS-1272? http://www.northstart.net/ I didn't care to have something more expensive that was integrated into the pre-existing Start/Stop remote features. Plus my BRZ will always be within a few hundred feet of me, either at home or at work.
It'll be my first autostart for one of my cars. So happy!
Old 10-10-2012, 06:10 PM   #355
cosseywrx
Member#: 276443
Manley 2618 stroker pistons
Manley sc h beam rods
79mm nitraded sti crank
Sti oil pump
Arp head studs.
2.1l stroker kit is on its way!!
2 items came in today
Old 10-10-2012, 08:33 PM   #356
Nomadgene
Member#: 22923
2002 EJ207 V8 1.5xtr
TWIN-SCROLL Black Bugeye
Originally Posted by cosseywrx View Post
Manley 2618 stroker pistons….
Start a build thread. Interested in these stroker builds.
Nomadgene is offline   Reply With Quote
Old 10-10-2012, 08:43 PM   #357
cosseywrx
Member#: 276443
It will go in my car thread. Retrac will be building my motor
Old 10-10-2012, 09:15 PM   #358
AKSubieDubie
Member#: 190003
2007 STI EFR 8374
Built a voltage divider circuit for my MAF. A lot of the cobra/lightning guys use the same thing, except in the form of the diablosport Mafia.
Mine was 3 bucks and 30 minutes (including tune adjustment) instead of like $150 .
5 volts is now ~4.7V... now I can bump past 20psi!
AKSubieDubie is offline   Reply With Quote
Old 10-10-2012, 10:34 PM   #359
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
exactly how is this working, is it dividing the voltage after a certain point so you dont loose drivability and idle....??? curious to know thanks, this seems like a good idea for those maxing out their maf.
Alaskan EJ20 is offline   Reply With Quote
Old 10-10-2012, 10:56 PM   #360
White_Rice
Member#: 160049
Wheels came in, now I need winter tires..............and my 2.0/2.5 installed.
White_Rice is offline   Reply With Quote
Old 10-11-2012, 03:13 AM   #361
AKSubieDubie
Member#: 190003
2007 STI EFR 8374
Works via ohms law - Basic physics.
You get 2 resistors (or one and a potentiometer if you want adjustability).
In my case I got a 220 ohm resistor and a 10k ohm resistor (1/2w). You can use ohms law to find the ratio you need to multiply all the voltages in your MAF table by. In my case I ended up multiplying by ~.88 or ~.89 I forget.
So:
Tap into the MAF ground wire with the 10k ohm wire. Leave the other end for now.
Take the 220ohm and put it inline with the wire that the ECU sees (cut the wire and hook each end to each side of the resistor).
Take the other end of the 10k ohm and put it on the ECU side of the 220 ohm resistor.
I can upload a diagram later.
Then you just adjust the MaF voltage in the tune and call it good.
It works because the MAF wire can read over 5V but Ecu is capped at 5, and the resolution is hardly affected if at all since the resistors reduce voltage EVERYWHERE, and you can utilize voltages lower than like 1.2.
Old 10-11-2012, 02:40 PM   #362
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
So:
Good show old boy!!!! I assume you can use stronger resistors so insteaded 5v maf would be 4v ecu or 3.5v ecu so one can run crazy boost safely also.
Old 10-11-2012, 04:28 PM   #363
AKSubieDubie
Member#: 190003
2007 STI EFR 8374
Sort of, You may not need to get too hog-wild crazy.
I had a 5.6k ohm in place of the new 10k ohm before, and after scaling the MAF to where my AFRs were good the 5V end of the scale turned out to be like 550g/sec which is unnecessary in most cases.
The 10k ohm worked great for me, but you would go smaller on that resistor OR bigger on the smaller "inline" resistor. My MAF is in blow through mode in a 3'' OD pipe right before the throttle body if you want to get a comparison idea
Old 10-11-2012, 05:23 PM   #364
_davin
Member#: 260501
2003 miata SE
Blurple
All thanks to Chano for selflessly donating his old bumper and time to help me spray it.
I also finally installed my LED Fogs I've been sitting on for some time, turned out more blue than I wanted, was hoping for white to match my HIDs but oh well. It's tempting to get yellow over-lays now but I don't want them to end up green.
And a mock up before hand just for giggles:
_davin is offline   Reply With Quote
Old 10-11-2012, 05:28 PM   #365
kyletakahero
Member#: 185030
2008 FXT Sport
Aspen white
Now you just need to do the hatch ;D
kyletakahero is offline   Reply With Quote
Old 10-11-2012, 05:34 PM   #366
cosseywrx
Member#: 276443
tomei timing guide
killer b oil baffle
Old 10-11-2012, 05:44 PM   #367
_davin
Member#: 260501
2003 miata SE
Blurple
I think I'm going to, didn't have time last night. Perhaps I'll show up to Rusty's going away party.
Old 10-11-2012, 07:39 PM   #368
_davin
Member#: 260501
2003 miata SE
Blurple
Old 10-11-2012, 08:25 PM   #369
Cscj15
Member#: 292737
2004 Impreza WRX
Before
After-Taillights, mud flaps and wing back on, might take it off again depending on how it looks with my winter wheels
Cscj15 is offline   Reply With Quote
Old 10-11-2012, 10:23 PM   #370
kayetealynn
Member#: 253304
2001 Impreza 2.5RS
Plus MOAR
Ordered ID1000's for the WRX..
They'll be here Monday.. :-D
kayetealynn is offline   Reply With Quote
Old 10-12-2012, 12:10 AM   #371
coldfiremx
Member#: 285848
Damn is that really necessary?
coldfiremx is offline   Reply With Quote
Old 10-12-2012, 12:28 AM   #372
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
Haha hope your ready for her answer for that question...
Oh it's time for a shot of rum lol
tribalwrx is offline   Reply With Quote
Old 10-12-2012, 12:46 AM   #373
coldfiremx
Member#: 285848
Patches O'Houlihan: Necessary? Is it necessary for me to drink my own urine?
Peter La Fleur: Probably not.
Patches O'Houlihan: No, but I do it anyway because it's sterile and I like the taste.
Peter La Fleur: ...Okay.
[while everyone is doing the shuttle run]
Patches O'Houlihan: Come on! I get better runs in my shorts!] (left that in strictly for humor)
Old 10-12-2012, 12:46 AM   #374
cosseywrx
Member#: 276443
im at 650cc and i thinkn of upping to 850cc or so after my build
Old 10-12-2012, 01:40 AM   #375
granny
Member#: 283145
1997 LEGASTi Wagon
[email protected]
Originally Posted by Cscj15 View Post
Before
Looks way better! I would keep the wing.
granny is offline   Reply With Quote
