Welcome to the North American Subaru Impreza Owners Club Tuesday July 22, 2014
Alaskan Impreza Club
Old 03-11-2013, 01:44 PM   #1401
granny
Member#: 283145
1997 LEGASTi Wagon
- PowerflexUSA - Moore -
Originally Posted by akfmx View Post
[IMG]
[/IMG]
When will the rest be done????
granny is offline   Reply With Quote
Old 03-11-2013, 04:24 PM   #1402
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
GT-86 knee pads installed!
chanomatik is online now   Reply With Quote
Old 03-11-2013, 04:43 PM   #1403
snowdrift86
Member#: 273920
05 Legacy GT
Regal Blue Pearl
Good seein you again as well Dom. I think it's sealed up now
snowdrift86 is offline   Reply With Quote
Old 03-11-2013, 08:14 PM   #1404
akfmx
Member#: 226059
Icy Silver
Legacy
Hopefully within the next couple weeks. Our garage space is tiny and currently being shared with the snowmachines. So that and me being busy is why progress is slow.
akfmx is offline   Reply With Quote
Old 03-12-2013, 12:23 AM   #1405
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Cleaned my iacv today. Hope it makes a difference. Or atleast longer
cosseywrx is offline   Reply With Quote
Old 03-12-2013, 01:25 AM   #1406
Quasimodo_ak
Member#: 310012
Ordered another enkei br7 wheel for a spare. I may or may not sell my stockers with blizzacks... Hmmm.
Quasimodo_ak is offline   Reply With Quote
Old 03-12-2013, 03:37 AM   #1407
cosseywrx
Member#: 276443
Didnt make much of a difference. Hope i get that other iacv to see if it is that or maybe the maf needs a bath or replacent.
Old 03-12-2013, 05:46 AM   #1408
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
Are you throwing any codes for the IACV ?
tribalwrx is offline   Reply With Quote
Old 03-12-2013, 01:10 PM   #1409
cosseywrx
Member#: 276443
No codes. My idle just doesnt stay firm when i put my foot at whatever rpm i choose. It will bounce up and down. Only at idle never while driving. Or coasting with clutch pressed but tranny in gear it will go up and down around 500rpms.
Old 03-12-2013, 02:03 PM   #1410
AK SloPok
Member#: 56464
12 Ram
Check your front O2
AK SloPok is offline   Reply With Quote
Old 03-12-2013, 02:09 PM   #1411
tribalwrx
Member#: 32993
vf39 Best trap 110
Check your front a/f sensor and I'd clean your MAF anyway, every time I've had any issue with my IACV it always threw a code and it would also cause issues while drive as well
Old 03-12-2013, 02:23 PM   #1412
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Do you feel it surge at all while cruising at light throttle? Check for intake leaks or vac leaks first, establish that all the basics are good. A mismatched or aftermarket MAF tube (intake) can cause the trims to go a little whacky as well.
The car is most likely trimming fuel but its happening in larger amounts then the computer can deal with well, its over correcting then under correcting and recycling perhaps. If you are able to check your AFR with a wideband you can log your front O2 sensor and compare to see if they read the same then you can rule out a front O2 failure.
Some basic logging and a learningview.exe screen shot would be helpful to see a little of what is going on and what the car is learning to do over time.
It is somewhat common for the front O2 sensor to go in this fashion around 70k-90k or sooner if the car has been on fuel additives that contain certain chemicals. If the sensors were not $200+ it wouldn't be so bad to just swap it but its usually better to make sure first.
BTW -- Simply disconnecting the front O2 sensor may make your problems seem to go away but this by no means 100% determines a bad sensor. It just makes the ECU blind to the engines AFR and it simply stops trimming fuel(probably the cause of your rev bounce).
--- P3 Import Autowerks 907.355.6655
P3Auto is offline   Reply With Quote
Old 03-12-2013, 02:54 PM   #1413
coldfiremx
Member#: 285848
It's a bad front HO2.
coldfiremx is offline   Reply With Quote
Old 03-12-2013, 03:23 PM   #1414
cosseywrx
Member#: 276443
While driving every things is fine. I have a aem wideband and all is reading normal. Im gonna clean the Maf and change the oring on the iacv on wednesday and will log some if problem persist. The car is over 100k now and most likely the stock front o2 could be bad. I have no rear because i have the wideband.
Thnks guys
Old 03-12-2013, 03:26 PM   #1415
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Log the front O2 sensor AFR and as long as you don't have a catalytic converter in front of your wide band the two sensors should read very close to the same numbers. If they do read the same numbers then the front O2 sensor is NOT the issue.
Thnks guys
Old 03-12-2013, 03:29 PM   #1416
cosseywrx
Member#: 276443
Will do thanks. Yeh no cats
Old 03-12-2013, 06:02 PM   #1417
BLURRZ
Member#: 291227
Only horses.
BLURRZ is offline   Reply With Quote
Old 03-12-2013, 07:19 PM   #1418
cosseywrx
Member#: 276443
Horse meat to be exact
Old 03-13-2013, 03:05 AM   #1419
Quasimodo_ak
Member#: 310012
Just ordered a set of Motive Autowerks composite TGV deletes. Pretty excited to get all my goodies installed soon!
Old 03-13-2013, 03:29 AM   #1420
Racer Dubya
some old guy
Member#: 112225
1985 78 HP of Rage!
Got a new door for my brat enroute... Only took 6 months and 3000 miles.
Racer Dubya is offline   Reply With Quote
Old 03-13-2013, 03:30 AM   #1421
kyletakahero
Member#: 185030
Oh geeze. Congrats on the find Ralph!
kyletakahero is offline   Reply With Quote
Old 03-13-2013, 04:02 AM   #1422
cosseywrx
Member#: 276443
I would like to see these before the install guy
Old 03-13-2013, 04:19 AM   #1423
Quasimodo_ak
Member#: 310012
I'll show them to you when I get back to town. Next meet or something for sure. I'm curious to see them too.
Old 03-14-2013, 03:13 AM   #1424
cosseywrx
Member#: 276443
Idle problem seems to be solved! Cleaned maf looked to be oily from before new build. Iacv cleaned again and idle is normal once again.
Old 03-14-2013, 03:16 AM   #1425
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
^^ Nice! That's great.
Dominator is offline   Reply With Quote
