Alaskan Impreza Club
Old 04-27-2013, 10:26 PM   #1676
bjcarter2
Member#: 227288
2006 MCS JCW
Pepper White
Originally Posted by kayetealynn View Post
NEED MOAR CAMBER!!!
No...What you NEED is to clean that engine bay on the WRX.
bjcarter2 is offline   Reply With Quote
Old 04-27-2013, 11:48 PM   #1677
_davin
Member#: 260501
2003 miata SE
Blurple
I'm going to go out on a limb and assume this is not safe.
Finally went to throw my new STi wheels on with 15mm adapter spacers, the stock studs are meant to protrude into the pockets in the back of the wheel, but mine appear to be too long.
Does anyone have experience grinding down studs?
_davin is offline   Reply With Quote
Old 04-28-2013, 12:28 AM   #1678
Frmrbob
Member#: 290921
2010 Impreza WRX prm
WR Blue
Originally Posted by Alaskan EJ20 View Post
what turbo and injectors, you want your jet or jets to match 30-50% of fuel flow at wot.
So if your using a vf 39 with 650cc injectors and your at 65% duty at wot:
650 x 4 (you have 4 injectors)= 2600cc (but only at 100% duty) so 2600x.65 (65% duty cycle)= 1690cc (full fuel flow at wot). Then 30-50% or 1690cc would be your jet size. so jets that would flow 500cc-800cc would be ideal.
Now keep in mind boost aswell, alot of these meth pumps flow at 150psi, but if your running 22psi in the intake manifold then that counters the meth pump output, so 150psi-22psi= 128psi, so you have to get a jet that flow 500-800cc when the pump flow pressure is at 128psi.
lmk if i can help.
I'm running a 20g & 1000cc ya I'm still lost on the sizing haha I'm trying to understand it and this is really good info I might head down to underground and talk to nick about it
Frmrbob is offline   Reply With Quote
Old 04-28-2013, 12:53 AM   #1679
Muggsy_Bogues
Member#: 289495
AW
Clay bar and wax!
Muggsy_Bogues is offline   Reply With Quote
Old 04-28-2013, 12:55 AM   #1680
colin22
Member#: 353372
1997 wrx
traded my fujitsobo 3" canister style cbe for a oval type 3" fujitsubo and changed spark plugs.
colin22 is offline   Reply With Quote
Old 04-28-2013, 12:57 AM   #1681
zachary.berrier
Member#: 82476
GOD CREATED TURBO
LAG TO GIVE V8'S A CHANCE
Originally Posted by SQUAD_907 View Post
mini sunroof...
Chris its about time you did a roof vent ;-)
zachary.berrier is offline   Reply With Quote
Old 04-28-2013, 01:00 AM   #1682
zachary.berrier
Member#: 82476
GOD CREATED TURBO
We will just call that overkill, you are safe with that
Old 04-28-2013, 01:01 AM   #1683
insane_one
Member#: 301431
2005 Evolution VIII
@Davin - that looks sketchy. grinding down studds sounds sketchy too
insane_one is offline   Reply With Quote
Old 04-28-2013, 01:09 AM   #1684
_davin
Member#: 260501
2003 miata SE
Blurple
Yeah never mind, I guess i need to get shorter studs or thicker adapters...
Old 04-28-2013, 02:17 AM   #1685
akfmx
Member#: 226059
Icy Silver
Legacy
You can cut off like 1/4inch from the end of the studs using a cutoff wheel on a die grinder. Nothing sketchy about it really.
If you goto the Parts Reviews section of the forums and read the ISC Wheel Adapters review that's what the OP does.
akfmx is offline   Reply With Quote
Old 04-28-2013, 02:33 AM   #1686
_davin
Member#: 260501
2003 miata SE
Blurple
That was my first thought but I'm afraid I'd mess up the thread.
Old 04-28-2013, 03:08 AM   #1687
insane_one
Member#: 301431
2005 Evolution VIII
looking that pic over again it looks like your adapter bolts dont even sit completly flush within the adapter? even if you did shave your studs, would the bolts fit in the wheel "pockets"?
Old 04-28-2013, 03:59 AM   #1688
_davin
Member#: 260501
2003 miata SE
Blurple
looking that pic over again it looks like your adapter bolts don't even sit completely flush within the adapter? even if you did shave your studs, would the bolts fit in the wheel "pockets"?
Yes, the pockets are plenty big enough, just not deep enough for the further protruding stud. And now after mounting my stock wheels again, I noticed the pockets in those are enormous! Stupid STis...
Old 04-28-2013, 10:12 AM   #1689
Racer Dubya
some old guy
Member#: 112225
1985 78 HP of Rage!
I know a few people have been waiting for the first big mod. on the LGT, so here you go...
Bought touch up paint yesterday.
Upcoming mods... Clay Bar and Dent Dude. Is everyone getting excited.
Racer Dubya is offline   Reply With Quote
Old 04-28-2013, 10:16 AM   #1690
Nomadgene
Member#: 22923
2002 EJ207 V8 1.5xtr
TWIN-SCROLL Black Bugeye
I knew it wouldn't take long.
Nomadgene is offline   Reply With Quote
Old 04-28-2013, 11:56 AM   #1691
bjcarter2
Member#: 227288
2006 MCS JCW
Pepper White
Enlarged the pocket with a die grinder and a rotary cutting bit. I've read threads in NASIOC where people have done it.
I have the tools if you want to do that.
Old 04-28-2013, 07:58 PM   #1692
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
12' wrx wheels. Drove it today!!
Alaskan EJ20 is offline   Reply With Quote
Old 04-28-2013, 09:10 PM   #1693
akfmx
Member#: 226059
Icy Silver
Legacy
Those wheels look good on there! Of course, would be a lot better with spacers
Old 04-28-2013, 09:48 PM   #1694
_davin
Member#: 260501
2003 miata SE
Blurple
Oh sorry I didn't read this before hand, I would've talked to you today.
Old 04-28-2013, 10:08 PM   #1695
bjcarter2
Member#: 227288
2006 MCS JCW
Pepper White
I forgot to mention it to you too.
Holler if you want to try it.
Old 04-28-2013, 10:25 PM   #1696
insane_one
Member#: 301431
2005 Evolution VIII
add a 5mm spacer to your wheel adapter. Muffler Shytty has'em
Old 04-28-2013, 11:08 PM   #1697
akfmx
Member#: 226059
Icy Silver
Legacy
A spacer ON TOP of an adapter? Now that doesn't sound safe haha
Old 04-28-2013, 11:28 PM   #1698
granny
Member#: 283145
1997 LEGASTi Wagon
[email protected]
Originally Posted by akfmx View Post
A spacer or adapter? Now that doesn't sound safe haha
Fixed
granny is offline   Reply With Quote
Old 04-28-2013, 11:45 PM   #1699
insane_one
Member#: 301431
2005 Evolution VIII
Originally Posted by granny View Post
Fixed
#YOLO
Old 04-29-2013, 12:14 AM   #1700
JCharron2005
Member#: 180365
2015 STI Limited
Darkness
Installed the 850cc injectors, moved it to the end of the driveway to get picked up and towed away for the tune =).
JCharron2005 is offline   Reply With Quote
