Alaskan Impreza Club
Old 02-07-2013, 11:48 AM   #1126
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
Counter-steer like a boss
That's outstanding!
Old 02-07-2013, 01:41 PM   #1127
907scoobyrex07
Member#: 296069
07 Rex
wrb
Coolest thing since toaster strudel*
907scoobyrex07 is offline   Reply With Quote
Old 02-08-2013, 12:13 AM   #1128
MrRicH
Member#: 150452
2003 Subaru Impreza
So stoked, getting scheduled to meet with a mortgage representative to finally get on track to buying a house. Finally, after all these years or not dumping money into the WRX are about to pay off... Something about having a nice car sitting outside in the snow breaks my heart...
MrRicH is offline   Reply With Quote
Old 02-08-2013, 12:25 AM   #1129
Akrexak
Member#: 100607
2007 Black swirl STi
'11 Forester Touring-Hers
Congrats on a future house. I wanted to do that when I got based here, because I know we are coming back. But the wife insisted we wait, good call in my book. Find the one you want!
Akrexak is online now   Reply With Quote
Old 02-08-2013, 12:33 AM   #1130
akfmx
Member#: 226059
low and slow
forester
Have a slight dilemma; I just recieved my Subaru oil galley adapter, used for installing an oil pressure sender on top of the block near the crankcase vent. It is supposed to have 1/8th BSPT threads. I also bought this adapter:
Auto Meter 2269 1/8" NPT to 1/8" BSPT Oil Pressure Metric Adapter : Amazon.com : AutomotiveAuto Meter 2269 1/8" NPT to 1/8" BSPT Oil Pressure Metric Adapter : Amazon.com : Automotive
which is a BSPT to NPT adapter. However, I can't even get it to start threading into the galley plug adapter. It's like it is too big. I've checked the packaging of both products multiple times to make sure i received the correct items. Has anyone else had this problem and what can I do?
akfmx is offline   Reply With Quote
Old 02-08-2013, 01:11 AM   #1131
nasiocjunkie
Member#: 80864
97 2.2L OBS
96 2.2L Legacy
Is there anywhere to buy grill mesh material here in Anchorage or in the valley? Checked Home Depot and Lowes but they don't have what I'm looking for. The OP in the thread below says he picked up his material at Home Depot but didn't see any at ours.
Looking for something like what this guy used:
http://forums.nasioc.com/forums/show...7&postcount=14
http://forums.nasioc.com/forums/show....php?t=1807761
nasiocjunkie is offline   Reply With Quote
Old 02-08-2013, 01:13 AM   #1132
MrRicH
Member#: 150452
2003 Subaru Impreza
Thank you sir. We haven't begun to shop the market yet, but we already know the area we want to look into. Thankfully Anchorage has a few newly constructed areas in good locations, new homes, new or 1 previous owner areas, and housing loans are still low. Shoot. They'll still give a house loan to Joe Blow who buses tables at the local restaurant...
Originally Posted by akfmx View Post
Have a slight dilemma; I just recieved my Subaru oil galley adapter, used for installing an oil pressure sender on top of the block near the crankcase vent. It is supposed to have 1/8th BSPT threads. I also bought this adapter: Auto Meter 2269 1/8" NPT to 1/8" BSPT Oil Pressure Metric Adapter : Amazon.com : Automotive which is a BSPT to NPT adapter. However, I can't even get it to start threading into the galley plug adapter. It's like it is too big. I've checked the packaging of both products multiple times to make sure i received the correct items. Has anyone else had this problem and what can I do?
I had some issues when I first installed mine, it didn't seem to seat correctly in the adapter, but I ended up finding a direct oil gallery adapter to sensor as opposed to using the adapter. Just ended up making everything less stressful...
Old 02-08-2013, 02:31 AM   #1133
kayetealynn
Member#: 253304
2001 Impreza 2.5RS
Plus MOAR
Meh. When I needed an adapter.. I just called FATS and got one delivered for $3.15.
Stop by and ask for Tony. If he can't help then you can go to a plumbing store and see if someone can match one up. They're called bushings though in the plumbing world >_>.
kayetealynn is offline   Reply With Quote
Old 02-08-2013, 03:53 AM   #1134
akfmx
Member#: 226059
low and slow
forester
Well, I got it. Decided to check our tap and die set and sure enough, we had 1/8 PT, which I'm pretty sure is the same as BSPT. Regardless, they're both tapered pipe thread. First tried the die on the male part, which helped as It was now starting to thread into the galley plug. But only about a half turn. So then I carefully ran the tap into the galley plug, essentially moving the position of the taper. And all is well now
Old 02-08-2013, 10:59 PM   #1135
akfmx
Member#: 226059
low and slow
forester
Uhh, could someone help me identify the stock up-pipe material? What's puzzling me is that most google results show people claiming it is cast iron. Yet it is welded (or brazed?) from the factory and looks nothing like a true cast iron piece i.e. the stock wrx manifold (NOT including the crossover pipe). Spark test is inconclusive for me. Known mild steel has lots of bright white sparks, the up-pipe has less sparks that are closer to orange, but I wouldn't call them red sparks.
Picture for reference..
Old 02-09-2013, 01:06 AM   #1136
coldfiremx
Member#: 285848
1995 Impreza RaceCar
2007 Legacy SE OBP hers
Mild steel.
coldfiremx is offline   Reply With Quote
Old 02-09-2013, 02:28 AM   #1137
akfmx
Member#: 226059
low and slow
forester
Thanks Taylor. I was basically coming to that conclusion myself, I just needed someone else to say it lol
Old 02-09-2013, 04:16 PM   #1138
kyletakahero
Member#: 185030
2013 STi SWP Ltd.
Slowest STi evaaaar
Does anyone know of any tire shops open tomorrow?
kyletakahero is offline   Reply With Quote
Old 02-09-2013, 05:54 PM   #1139
kayetealynn
Member#: 253304
2001 Impreza 2.5RS
Plus MOAR
To change tires? Alaska Tire in Eagle River is open Sundays.
Old 02-09-2013, 06:08 PM   #1140
kyletakahero
Member#: 185030
2013 STi SWP Ltd.
Slowest STi evaaaar
Hmm, that might work out actually.
Old 02-09-2013, 08:06 PM   #1141
bjcarter2
Member#: 227288
2008 FSXT
Red
A nice video on Ice Racing in NY...
http://www.grid1.tv/videos/featured/ice-racing
F1 Ice Racing in Europe...
http://www.grid1.tv/videos/featured/ice-racing-2
bjcarter2 is offline   Reply With Quote
Old 02-11-2013, 01:53 AM   #1142
Rookie J
Member#: 281747
2005 Legacy GT Wagon
rCE Sponsored
Anyone have a car trailer that I could borrow next week ?
Rookie J is offline   Reply With Quote
Old 02-11-2013, 10:36 PM   #1143
insane_one
Member#: 301431
2010 Subaru WRX
OBP Hatch
i know someone who has a trailer he might rent out...
EMC has some shop time open for rent
http://www.motorsportsalaska.com/for....php?f=4&t=903
insane_one is online now   Reply With Quote
Old 02-12-2013, 07:22 PM   #1144
bjcarter2
Member#: 227288
2008 FSXT
Red
And all this time I thought Jammer had nerves of steel.
I am heart-broken over this news.
From an article on Ice Racing in the March 2013 edition of the Alaska Magazine.
Old 02-12-2013, 08:03 PM   #1145
chanomatik
Member#: 159474
54-years-old?!
Old 02-12-2013, 08:22 PM   #1146
Shaggie 907
Member#: 256102
ah it finally came out eh about time
Shaggie 907 is offline   Reply With Quote
Old 02-12-2013, 08:26 PM   #1147
manda.j
Member#: 249624
1997 Honda Accord
woot! Gonna go pick up a copy for myself after work!
Some of us also knew this was going to be in the magazine ;-) since they reached out to us for it! +1 for the car community
manda.j is offline   Reply With Quote
Old 02-12-2013, 08:50 PM   #1148
cosseywrx
Member#: 276443
2005 Subaru wrx
i hate when i have extra money to spend on parts and idk what to get!
i want a new shift knob
sways/bushings
endlinks
Front strut bar
cosseywrx is online now   Reply With Quote
Old 02-13-2013, 10:51 AM   #1149
Nomadgene
Member#: 22923
2002 Hybrid JDM 2.0L
TWIN-SCROLL Black Bugeye
Nomadgene is offline   Reply With Quote
Old 02-14-2013, 01:58 AM   #1150
_davin
Member#: 260501
2011 WRX 5dr SWP Ltd
http://jalopnik.com/the-2014-mercede...-tha-168817260
I want this, or at least the engine and seats.
_davin is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 04:07 AM.
