Old 08-26-2012, 09:36 PM   #1
vf22Bugeye11
Member#: 272096
2002 6Speed swap wrx
Function Warrior!!
Default ej22 sohc on 02 forester with ej251 sohc
i bought a 02 forester for 400$ and im planning on putting in a ej22. Mostly for reliability dont care about power haha thats what my rex is for. anyway can i just drop it in and run it with my intake manifold ?
vf22Bugeye11 is online now   Reply With Quote
Old 08-27-2012, 11:31 PM   #2
vf22Bugeye11
Member#: 272096
Function Warrior!!
how about this will a phase 2 e22 work on my phase 2 ej251 with my intake manifold
Old 08-27-2012, 11:32 PM   #3
eg33GC
Member#: 206851
56 Belair
Pro Street
dont put the 2.2 heads on the 2.5 in any car you want to last any amount of time
the 2.2 and 2.5 are interchangeable
eg33GC is offline   Reply With Quote
Old 08-27-2012, 11:41 PM   #4
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
Why not?
And I think you mean the blocks????
bugeyetex is offline   Reply With Quote
Old 08-27-2012, 11:44 PM   #5
vf22Bugeye11
Member#: 272096
Function Warrior!!
i want to swap the long block not the heads i just want a reliable setup
Old 08-28-2012, 09:07 AM   #6
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
That should work from what I've read/heard but I have never tried it myself. I know phase II stuff is pretty much plug and play and that the IM will bolt right up.
geronimo81 is offline   Reply With Quote
Old 09-02-2012, 12:20 AM   #7
vf22Bugeye11
Member#: 272096
Function Warrior!!
Do you guys know if I'll have to swap crank and cam pulleys, and how hard is to to change em
Old 09-02-2012, 01:55 AM   #8
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
it will drop right in place. Just use your intake manifold and wiring and you'll be fine IF you are using a single port ej22 from a 99+ (it might be 98, i can't remember). The valve covers should look the same as your 2.5 and have no writing on them.
You will need to swap to the single port header as well.
be warned, it will be VERY slow.
Zefy is offline   Reply With Quote
Old 09-02-2012, 08:57 AM   #9
vf22Bugeye11
Member#: 272096
Function Warrior!!
The ej22 I got is a phase 2 with single port heads but I got the original exhaust so I'm covered ...do you know if to have to swap the cam and crank pulleys over from the ej25 to the ej22
Old 09-02-2012, 03:27 PM   #10
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
Like I said it should be a direct swap. If you're worried about it, pull the covers off and you can see the crank pulley. If the crank pulley is different then its a good chance the cam is also different. And if they are different, it will be really obvious. The difference in crank pulleys is one has something like 8 teeth while the other style has something like 18.
Like I was saying though, should drop right in. I went the other way in mine. Ej25 from an 03 swapped with my 99 ej22.
Old 09-05-2012, 11:47 AM   #11
jeffsnyder
Member#: 10039
crank sprocket is the correct term
jeffsnyder is offline   Reply With Quote
Old 02-15-2013, 11:12 AM   #12
chris_columbia
Member#: 347123
I put the ej25 phase 2 from a 2001 automatic outback into a ej22 phase 2 1999 legacy manual. Retained intake. Had to change both cam and crank sensing wheels. Not a big deal but definitely they where different. Also had to change the exhaust manifold Y-pipe. Obviously, I had to swap flywheel too due to the transmission differences. I disagree about the power comments on the 22 vs 25. The 22 is slower but not by a lot. Plus fuel economy is around 27mpg average on ej22, and 25mpg on ej25. Other probelm is the computer is delivering fuel for an ej22 for the ej25 engine so there are some minor idle issues, and somethimes throttle jerking due to slightly lean mix and computer trying to make adjustments. These are MAP engines not MAF. If they were MAF I wouldn't expect an issue.
chris_columbia is offline   Reply With Quote
