Old 08-27-2012, 01:27 AM   #1
BrakeSTI
Member#: 291286
2008 STI
Spark Silver
Hello all,
I recently installed a blitz fatt advance + turbo timer and harness from rallysportdirect.com I have everything hooked up according to the directions but all it does is read the battery voltage when I shut my car off it doesn't stay on the turbo timer turns off as soon as the car does. Any help is much appreciated.
BrakeSTI is offline   Reply With Quote
Old 08-27-2012, 02:52 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
why???
never heard of a fatt advance...wtf is that??? and a turbo timer is pointless and useless unless you have a turbo that has an oil only cooled center cartridge
Old 08-27-2012, 11:19 AM   #3
BrakeSTI
Member#: 291286
2008 STI
Spark Silver
http://www.rallysportdirect.com/Blit...r-FATT-Advance
Here's a link to it, I track my car on a monthley basis and noticed that after running it hard for a while then immediately turning it off when I started it back up it would put out some white smoke vs letting it sit for a while then starting it back up it wouldn't put out smoke. I've had the car looked at compression test is good and it barley burns any oil over 4k mile oil change intervals.
Old 08-27-2012, 02:40 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
if you track the car...then maybe...but overcomplicating something that you could do without much forethought seems.....overcomplicated
Old 08-30-2012, 05:36 PM   #5
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
If the timer is hooked up, you will just simply need to scroll through some options on the timer to enable the timer to run when you pull the key.
Also make sure that the E brake wire is hooked up, as that is needed as a safety device so someone cant hop into your car when the car is running and just drive off.
Kirill
RallySportDirect.com
RallySport Direct is offline   Reply With Quote
Old 05-24-2013, 04:45 AM   #6
JLHK
Member#: 322967
Can I lock the car with the remote control while the turbo timer is running?
JLHK is offline   Reply With Quote
