Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 07-28-2012, 05:09 PM   #1
Subie the newbie
Member#: 326172
Have a Nice Day? Passengers power window stuck. GL-10
Hey guy's , my passengers side window is stuck open.
I click the switch on both the drivers side and passengers side to the "up" position. nothing. I click to "down" position I can hear the motor working. Since the GL-10 has no fuse for the power window. There is a relay under the passengers seat for it.
Anyway , how do I remove the whole door panel?? I see a screw under the door handle trim. But that's it. Is it on the side of the door it'self or what?
Thanks.
Subie the newbie is offline   Reply With Quote
Old 07-29-2012, 12:23 AM   #2
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
First remove the "plugs" on the armrest. Under them are screws... take them out and remove the armrest. After its off you can CAREFULLY pry off the whole door card. Try not to break the clips. Once the clips are removed you gently lift up to unseat the window seal on the inside and then the whole panel lifts off. You will likely have to unplug the power window switch from the card so you can set it aside to work inside the door.
Flowmastered87GL is offline   Reply With Quote
Old 07-29-2012, 12:32 AM   #3
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
if you get one of these, it can help save the clips and your fingers
bugeyetex is offline   Reply With Quote
Old 08-26-2012, 10:33 AM   #4
dcdak16
Member#: 213431
04 Forester XT
On my old loyale my drivers side rear window would only go down using the drivers master switch, it would go both up and down using the switch on the actual door. Also there was a factory Allen head tool used to close the windows located on an appulstered pouch in the passenger side rear footwell.
dcdak16 is offline   Reply With Quote
Old 08-26-2012, 01:00 PM   #5
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
I think the allen wrench was intended for the moonroof actually
