Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 08-27-2012, 03:05 PM   #1
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
Default Stage 1 93oct HWG Datalog - Good?
Hey, so I was seeing some fine knocking with the regular stage 1 map I believe because of my K&N drop in air filter.. I put the stock one in and knock went away, but I wasnt hitting target boost +/-0.8, I was peaking at 15.3 not 16.5. I switched to the 93oct HWG map and again knock gone and I hit the 16's for boost.
Is there anything out of the ordinary worth looking into on this datalog?
https://docs.google.com/spreadsheet/...2Ri15Umc#gid=0
Thanks!
MtnXfreeride is offline   Reply With Quote
Old 08-27-2012, 08:57 PM   #2
SouthernWRX
Member#: 321571
2012 WRX Base
Ice Silver
Looks good to me. I take it this was a 1st - 3rd pull? I'm running the regular 93 OTS map and I see the same/just over the amout of boost you are getting with the HWG map. Maybe the Cobb guess can chime in.
SouthernWRX is offline   Reply With Quote
Old 08-28-2012, 08:25 AM   #3
Cobb Tuning
Member#: 4803
Thanks!
Log looks good, but I would get an 3rd gear only WOT run from about 2000 RPM on up (if you can do so safely). That will give us an extended run in 3rd gear to look at.
Bill
