Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 09-09-2012, 07:35 PM   #126
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
^^^^same technology used in the GM LS motors for their rods.
john 1badSTI is offline   Reply With Quote
Old 09-09-2012, 09:52 PM   #127
karlknaupp
Member#: 60871
04 Wrx & 17 fxt
wow.. figured that would be a machined process.. i guess its working so far..
karlknaupp is offline   Reply With Quote
Old 09-09-2012, 10:30 PM   #128
NateLS1
Member#: 132380
2011 WRX
Spark Silver
The pieces fit perfectly together using this process, better than 2 machined surfaces coming together. The 3.6 liter H6 also uses this process.
NateLS1 is offline   Reply With Quote
Old 09-09-2012, 10:35 PM   #129
Btownmill
Member#: 331673
Nice looking car man!
Btownmill is offline   Reply With Quote
Old 09-09-2012, 11:56 PM   #130
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Dam dudes. Impressive, love seeing the rears spinning ;-)
Kastley85891 is offline   Reply With Quote
Old 09-10-2012, 12:07 AM   #131
Diego-Peru
Member#: 331720
when will it go back to the track?
It's making built Sti's look slow
Diego-Peru is offline   Reply With Quote
Old 09-10-2012, 02:16 AM   #132
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
We took it to the track two weeks in a row.
Really need to switch to SD tuning before we can go back
So maybe 2 weeks
-John
Visconti is offline   Reply With Quote
Old 09-10-2012, 10:24 AM   #133
mtarr07
Member#: 246990
2010 Wrx
Awesome times and keep up the good work! All these results are really making me consider selling my wrx! grrrrrrr
mtarr07 is offline   Reply With Quote
Old 09-10-2012, 11:04 AM   #134
Carbibbles
Member#: 292996
02 wrx
Notice the lack of port holes to install the piston pins, must be able to tighten the rod bolts from the crankcase area now that they are angled.
Carbibbles is offline   Reply With Quote
Old 09-10-2012, 01:26 PM   #135
flystiguy14
Member#: 74416
91 SS leggy
pearl white
Originally Posted by juanmedina View Post
vs EJ257 forged rod
FA20 internals
Is this the motor out of the white one? Did you guys take it out because something failed, or did you take it out to just see what your dealing with?
flystiguy14 is offline   Reply With Quote
Old 09-10-2012, 03:03 PM   #136
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Originally Posted by Visconti View Post
Thanks guys
Yeah going SD very very soon.
Guys at EcuTek are just fixing a few bugs on the latest RaceRom stuff.
Flex Fuel support , 4 maps on the fly, ecu controlled ebcs and of course SD tuning
What's even more exciting is all this stuff will be ported to the other Subies very soon
Check that out!!! Nice job man!! These are looking extremely tempting now. Amazing progress in such a small amount of time! You guys are way ahead of the curve
wgr73 is offline   Reply With Quote
Old 09-10-2012, 03:17 PM   #137
GeneralTJI
Member#: 152680
I took apart an ej205 once that way.... wrist pins were stuck and I didn't want to do a sloppy job grinding on the pistons enough to de-bur them through the wrist pin holes... that was a PITA
GeneralTJI is offline   Reply With Quote
Old 09-10-2012, 03:54 PM   #138
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
That's the point, they are made that way to make the assembly process in the factory easier.
Old 09-10-2012, 05:35 PM   #139
karlknaupp
Member#: 60871
04 Wrx & 17 fxt
i believe these pics are from crawford..
Old 09-10-2012, 06:17 PM   #140
qtr_wrx
Member#: 109567
You'll have to call Accelerated Performance - I'm not sure what the price is off hand..
But today we have new dyno numbers.
Don removed the cat located in the header
Since we're seeing a lot more airflow we lowered the boost to 18PSI.
Couldn't pull it to 8500-9000rpms because the Car is pegging the 3.5inch MAF
How can you make power @ 8500+rpms with stock heads/cams??
but awesome numbers
qtr_wrx is offline   Reply With Quote
Old 09-11-2012, 09:15 AM   #141
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
Originally Posted by GeneralTJI View Post
I believe those rods are "broke" in to two pieces to form the cap....I think
fracture split....this tech has been around for decades, i believe germans did this with their rods in their ww2 planes.
mcu81 is offline   Reply With Quote
Old 09-11-2012, 09:28 AM   #142
flystiguy14
Member#: 74416
91 SS leggy
pearl white
Ahhh. that would make sense....
Old 09-11-2012, 10:20 AM   #143
CatfaceType-R
Member#: 81102
but awesome numbers
Imo, the stock cam is suited for high rpm NA power, slapping a turbo on there won't change that.
CatfaceType-R is offline   Reply With Quote
Old 09-11-2012, 01:37 PM   #144
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
EDIT: Scratch that.
CKxx is offline   Reply With Quote
Old 09-11-2012, 08:38 PM   #145
KurtP
Member#: 44836
1999 Fozzy
looking good. Im still looking forward to seeing what this thing is going to do with 93/ 93+meth, even if it does involve dropping compression down. I dont have e85 readily available in my area....
Originally Posted by CKxx View Post
Part of me is just waiting for this thing to explode like every other Subaru motor. The other part hopes they really did make an effort to design something that can hold some power for more than 15 minutes. It would be exciting if they did design the motor and trans with much greater HP in mind, but it seems doubtful given the usual trends in manufacturing.
wait: you drive a FD RX-7 and you are worried about a subaru's engine failing? :giggle:
KurtP is offline   Reply With Quote
Old 09-11-2012, 08:43 PM   #146
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Originally Posted by KurtP
wait, you drive a FD RX-7 and you are worried about a subaru's engine failing? :giggle:
It doesn't have a rotary in it.
Psychoreo is offline   Reply With Quote
Old 09-12-2012, 09:40 PM   #147
Loscaldazar
Member#: 300007
If this lasts, this might replace the 2.2L for legendary durability. Scratch that, if this engine lasts, the 2.2l never could have touched what this is doing. Not even close.
Loscaldazar is offline   Reply With Quote
Old 09-12-2012, 09:42 PM   #148
jesseber
Member#: 293509
2004 WRX STI
Yeah I'm curious as to how long something like this will last on the street. Time will tell, I guess.
jesseber is offline   Reply With Quote
Old 09-14-2012, 12:34 AM   #149
CKxx
Member#: 33458
93 RX7+09 Forester
No rotary. The replacement setup should be perfectly reliable at ~750whp.
I've had several Subarus, one well over 500whp. I don't think a BRZ needs anywhere near that much, but 170ish seems a bit underwhelming this day in age. I'd like to see that there is some headroom for adding power.
Old 09-14-2012, 09:01 PM   #150
GeneralTJI
Member#: 152680
Even though the liners are thicker, it's still open deck. May not be a problem until insane power levels are reached, but either way, it's not the most optimal design for big power. Though this 2.0 is obviously alot stronger than the old 2.0's
Props to everyone involved for pushing this thing to see where it can go
