Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 08-28-2012, 06:03 AM   #1
mcthaniel06
Member#: 238298
1996 Impreza Outback
Navy blue/Slate gray
Default '96 impreza wagon cruise control question.
I've got a '96 Impreza obs that I'd like to fit with an oem cruise control(CC), but it's been challenging finding the Impreza-specific parts at salvage yards. Would the CC from a Forester of a similar year fit my car, or do I need an Impreza wagon-specific CC? I found a Forester with a CC at a salvage yard, but didn't pull it because I wasn't sure about the compatibility.
I have a general idea of the parts I need such as the cable leading to the throttle, the dash-mounted cruise button, the steering wheel accel/decel/cancel stalk, the brake pedal interrupt switch, the vacuum drum(?) on the firewall, and an ECU. Any additions/corrections are welcome, along with any advice. I'm still a bit of a noob, so please keep that in mind when answering. Thanks.
mcthaniel06 is offline   Reply With Quote
Old 08-29-2012, 08:35 AM   #2
mcthaniel06
Member#: 238298
Bump. Anyone? Bueller?
Old 08-29-2012, 10:30 PM   #3
mcthaniel06
Member#: 238298
Bump! Am I in the right forum?
Old 08-31-2012, 11:07 AM   #4
mcthaniel06
Member#: 238298
Bump for one last try before I try a different forum.
Old 09-02-2012, 11:53 AM   #5
avk
Member#: 17252
'06 WX8
59E
Part numbers for add-on c.c. kits were different for almost every model year, but many of the changes were minor. Still, the only way to be sure is to look at the wiring diagrams for both the donor and the recipient. Even though c.c. was not a factory option on US & Canadian Impreza, it is still shown on the schematics. The thing I would worry about the most is the pin-out of the connector between the control unit and the dash harness.
avk is offline   Reply With Quote
Old 09-05-2012, 07:32 AM   #6
mcthaniel06
Member#: 238298
Actually, according to kbb.com, cruise control became a factory option on the Impreza Outback in 2000. That said, thanks for the tips regarding the connector and wiring diagrams.
Bump for thoughts/tips from others.
Old 09-06-2012, 11:49 AM   #7
avk
Member#: 17252
'06 WX8
59E
Yes, they did offer it in 2000-01 and I did forget about it. At the same time, a unit from a 1998-2001 model would be less likely to fit because they no longer had a cable driven speedometer.
