Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 09-05-2012, 02:32 PM   #26
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
I think this is going to be too long for a shop day. I'll check though, just to confirm.
No need. Pulling the manifold and everything connected to it will go way over the time allotted. Sticking with my original plan unless this is a freak shop day with an empty shop
imma_stocker is offline   Reply With Quote
Old 09-06-2012, 11:07 AM   #27
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
alright, I do know that the techs have shortcuts and ways to do things a lot quicker and efficiently through practice, you can at the least use the opportunity to buy them a drink and ask them if there are any steps you can take to do the job more efficiently
Old 09-06-2012, 01:17 PM   #28
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
That's a good idea sir.
Might as well bring the parts just in case too.
Old 09-07-2012, 10:05 AM   #29
samagon
Member#: 26859
of TXIC
lol, not a bad idea.
Old 09-10-2012, 09:43 AM   #30
samagon
Member#: 26859
of TXIC
Originally Posted by TX2TH View Post
1. Jason TX2TH
2. 2011 WRX
3. driveline bushings, short shifter, fender rolling if anyone has a roller...
The shop does have a fender roller (actually, it's in parts), you might want to source your own heat gun, just in case the techs don't have one.
Old 09-12-2012, 04:08 PM   #31
samagon
Member#: 26859
of TXIC
still plenty of room guys!
this list is specifically to provide a good idea for how many people are going to be at shop day, and ensure the staff will be able to adequately assist you guys
Old 09-12-2012, 07:17 PM   #32
Pencils
Member#: 152726
The 2003 pwrFAP
thing
curious how it's gonna work if you sign up for the show and also want to use the shop for maybe an hour?
(i want to do a tranny and diff flush)
Pencils is offline   Reply With Quote
Old 09-13-2012, 09:02 AM   #33
samagon
Member#: 26859
of TXIC
I'll talk to the guys and see what they think, I know people have signed up for both in the past, and just ended up in the show all day. I don't think we've had anyone actually do both.
Old 09-13-2012, 10:29 AM   #34
junkb0y
Member#: 162665
2007 Impreza WRX
1. Junkb0y - TJ Tran
2. 2009 Tribeca
3. 60K maintenance and brake job
If time to go home and get my other car:
2. 2007 WRX wagon
3. Timing belt
junkb0y is offline   Reply With Quote
Old 09-13-2012, 02:57 PM   #35
Hozer3.0
Member#: 121535
2007 Impreza STi
Hozer Solis-Hozer3.0
2007 STI
Transmission/diff fluid and coolant flush (possible alignment)
Hozer3.0 is offline   Reply With Quote
Old 09-13-2012, 04:46 PM   #36
mferring
Member#: 81345
2015 WRX
WR Blue
Default Work plan change and questions....
OK, I have changed my plans to....
1. Mark Ferring
2. 2004 WRX
3. Rotors and Brake pads (Use to be transmission ujoint and bushings).
I assume I keep my place in the queue....
So, I have never done a shop day or brakes/rotors before. As brakes are of course critical, I want to make sure I don't screw up anything. Can someone tell me what the basic procedure is to get help from a tech including what a standard tip would be for rotors and brakes? Will they help me the whole time or only when I have questions?
mferring is offline   Reply With Quote
Old 09-13-2012, 05:19 PM   #37
tydirian
Member#: 327669
2012 STI HB
If there is still room I would like to do
1. Ben Thomas
2. 2012 STI Hatch
3. Tire & Wheel install, Fender Roll & Alignment
tydirian is offline   Reply With Quote
Old 09-13-2012, 05:26 PM   #38
Kooshbag
Member#: 308425
2011 WRX-Stage 2
I have to back down from my spot, I will be at the event but I cant do the shop day. Hopefully it can open up to someone who can take advantage of it.
Thanks,
Josh(kooshbag)
Kooshbag is offline   Reply With Quote
Old 09-13-2012, 05:51 PM   #39
samagon
Member#: 26859
of TXIC
2. 2009 Tribeca
2. 2007 WRX wagon
3. Timing belt
recommendation, show up as early as you can for your first one, go home, grab the second and you should have time.
2007 STI
got it.
1. Mark Ferring
2. 2004 WRX
You'll have complete access to a tech who's assigned to assist you the whole time, so no worries there. Depending on how much you want to be involved, they'll either step in and do it all for you, or just give you direction on what bolts to take off, and what steps are appropriate to take and then watch you to make sure you don't break their tools, or yourself
Tip, maybe some of the guys who've done brakes at a shop day can tell you what they tipped, but it's not going to take the full 2 hours (are you replacing rotors, or turning stock?) to get the job done. I'll check around and let you know if someone doesn't chime in before I get a chance.
Old 09-13-2012, 07:20 PM   #40
mferring
Member#: 81345
2015 WRX
WR Blue
Thanks Samagon....
I plan to change both rotors and pads. Will probably go with Centric rotors and Stoptech performance pads from KNS.
Old 09-14-2012, 12:43 PM   #41
samagon
Member#: 26859
of TXIC
Thanks Samagon....
yeah, that should be easy to do in under 2 hrs.
Old 09-14-2012, 04:20 PM   #42
mferring
Member#: 81345
2015 WRX
WR Blue
Also, decided to get some stainless steel brake lines and some ATE Super Blue to replace the old fluid. Been looking at all the installation videos. Looks like it is probably all doable in a few hours.
Still hoping to get a bit of guidance regarding appropriate tip size for the tech helping me, lets say on a per hour basis (or is it for how much help I ask for!).
Old 09-14-2012, 08:06 PM   #43
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
Those brake upgrades are pretty quick with a lift and proper tools. I'll be in the shop helping out too.
Tip techs based on what they do. I've gone thru a busy shop day without any help so didn't tip but I've also paid them for simple advice and using their tools. Keep in mind they aren't getting paid that day except tips.
Old 09-15-2012, 02:32 AM   #44
mferring
Member#: 81345
2015 WRX
WR Blue
Thanks imma_stocker. Very helpful. Do you have any advice on $$$ amounts of tip for say a good bit of help on a per hour basis?
Old 09-15-2012, 09:01 AM   #45
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
PM sent
Old 09-15-2012, 12:29 PM   #46
Davenow
Member#: 23676
Old 09-17-2012, 10:46 AM   #47
lovethebugeye
Member#: 116929
2008 :shifty eyes:
lovethebugeye - Chris
08 STi
Alignment - potentially installing ALK before hand, and lookover brakes, maybe flush brake fluid...i'll have a better idea when it gets a little closer
lovethebugeye is offline   Reply With Quote
Old 09-17-2012, 11:41 AM   #48
samagon
Member#: 26859
of TXIC
08 STi
Gotit!
Thanks for the insight imma_stocker!
Old 09-17-2012, 03:01 PM   #49
imma_stocker
Member#: 97043
08 STI
02 Z28 - project
REMINDER: IF YOU NEED ANY PARTS AT SHOP DAY, CALL GILLMAN AND LET THEM KNOW BEFOREHAND. YOU DO NOT WANT TO BE WORKING AND RUN OUT OF GASKETS, FILTERS, FLUIDS, ETC.
6. Jason imma_stocker
08 sti
Pulley swap, bleed brakes, oil pickup swap, fuel pump swap
Plans changed, rear seats will be removed prior to shop for day fuel pump swap and will adjust for available time. Pulley swap (20 mins), bleed brakes (10 mins), oil pickup swap (30 mins), fuel pump (45 mins incl time to cut bucket). So I need to get there pretty early to knock it all out. One shop day I was pushed down the list then didn't have time to do it, got my refund but still had to do it without a lift (uppipe and headers 10x easier on a lift).
If anybody has an 08+ WRX wagon I've got my stock 08 STI sways taking up garage space. Free for anyone local who'll use them.
Old 09-18-2012, 12:24 PM   #50
samagon
Member#: 26859
of TXIC
Got you updated. I assume with the oil pickup swap you're going to be changing the oil filter and putting in new fluid as well
It is certainly worth mentioning this about 3 or 4 times
Even though the service advisers handing out wristbands mention it when they give out the wristband and have people sign the wavers, there's always someone who ends up at the parts counter for 30 minutes while their car's in a shop bay.
Granted, there's nothing you can do if you put the car up and you see a CV boot is leaking and decide to replace it while you're there, you just didn't plan for it.
Also, remember there's a discount at the parts counter on the day of, so have the parts ordered, but pay for them when you check in at the service area on the day of the Big Event
I will confirm what the discount is on day of, but it's worth not buying prior.
