Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 08-28-2012, 03:07 PM   #1
bigaltech
Member#: 326193
Default 2012 sti sedan log first time
Hello! I didn't get any response ont he cobbtuning forum, so I'm trying here:
I have a 2012 STI Sedan. I have the COBB SF intake and OTS stage 1 SF+ for 93 octane normal wastegate.
Attached are 4 files.
Two are day 1 pulls (before exhaust)
and the second two are day 2 pulls (after exhaust)
Link to log files:
https://www.dropbox.com/sh/12gacjwm3r25vpk/YlzqyVYSB4
Day 2 mods are the same (cobb sf intake stage 1+ ots map 93 octane) and exhaust is just the nameless axleback (no muffler) version. I'm seeing some knock if I'm reading that correctly.
* I can't safely do a 4th gear pull, best I can do is 2nd/3rd at least right now, but I want to make sure the car runs correctly under load.
Thank you.
bigaltech is offline   Reply With Quote
Old 08-29-2012, 08:55 AM   #2
Cobb Tuning
Member#: 4803
Link to log files:
Thank you.
Can you put these up on google docs? If so, make sure to transfer to google docs format to allow for previews and set the premissions to public. I would try to get a 3rd gear run from 2000 RPM on up if you can do so safely, rather than a 2nd to 3rd gear run.
Bill
Old 08-29-2012, 09:04 AM   #3
bigaltech
Member#: 326193
I believe I have it setup correctly for google docs:
The log files are starting in 2nd gear throughout 3rd gear to redline shifting in between. Is this OK or do you want JUST 3rd gear only?
Regardless, still curious about the knock.. What is considered a LOT of knock compared to what my logs are showing? Thanks Bill!
day1 2nd and 3rd gear:
https://docs.google.com/spreadsheet/...S1FXy1aNGFSS1E
day 1 some knock:
https://docs.google.com/spreadsheet/...nM0Mk9UUGNIaFE
day 2: nameless muffler delete (no muffler) s mode:
https://docs.google.com/spreadsheet/...ThaUDhfWjFDd3c
day2: s sharp same mods:
https://docs.google.com/spreadsheet/...mEtTm5kcEVwbWc
Old 08-29-2012, 11:24 PM   #4
AuthenticAMD
Member#: 212239
2008 Legacy Spec B
QSM (stage 3.5)
You have like 1 knock case in each of the logs, but they are happening at bad times. It's optimal you have logs only in 3rd gear, but only do it safely. You may be getting some knock due to lift off / throttle mashing. This wouldn't occur in a continuous 3rd gear pull.
AuthenticAMD is offline   Reply With Quote
Old 08-29-2012, 11:47 PM   #5
bigaltech
Member#: 326193
Alright thanks, I'll try to get one tomorrow or the next day. 4th gear is hard to pull off but I can manage 3rd getting onto a highway. Is that satisfactory or is there a difference between 3rd/4th gear when it comes to tuning/logging the car?
thanks again
Old 08-29-2012, 11:58 PM   #6
AuthenticAMD
Member#: 212239
2008 Legacy Spec B
QSM (stage 3.5)
3rd gear is fine due to safety concerns. You'd be going into the 100s if you did a 4th gear pull to redline.
Old 08-30-2012, 09:45 AM   #7
Cobb Tuning
Member#: 4803
day 1 some knock:
A lot of the knock seen here is due to hard shifts or mashing the throttle. When you see feedback knock within a few lines of going from lower throttle to WOT quickly (either when shifting or just mashing the gas), this is generally noise and not a concern.
But, you want to try to get an extended 3rd or 4th gear run from 2000 RPM on up if possible (if you can do so safely). This will remove the false shift knock from the middle of the run and allow you to also see how boost control is reacting. In your logs, you are getting a boost spike at times so it may be that you need to run the low wastegate (LWG) version of your map. We'll better know with the 3rd gear run.
Bill
