Old 08-28-2012, 06:28 PM   #1
Pickler
Member#: 301247
09 Impreza 2.5i MT
Default wierd sound under load
when engine is under heavy load at low rpms (1000-3000) it makes a funny rumbling sort of noise. this is made worst if the AC is on or the outside temprature is hot. i use scangauge 2 to monitor engine load mpg etc and i noticed this noise comes up when engine load hits 99% (max load). this doesnt happen under full throttle. anyone experienced this with the 2.5L?
Pickler is offline   Reply With Quote
Old 08-30-2012, 02:24 AM   #2
dirt and road
Member#: 293284
2005 2.5 RS
grey meta
Im pretty sure its normal man mine gets really loud around 3k its just the boxer motor. Its definitely louder with the windows up. Nothing to worry about as far as i know, put an exhaust on it and you'll forget about the engine noise.
dirt and road is offline   Reply With Quote
Old 08-30-2012, 08:45 AM   #3
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
log knock correction or total timing angle or whatever you can monitor as far as ignition timing. It may be knock since knock is more likely to occur when intake air temps are higher and when load is higher (I.e. when the a/c is on)
