Welcome to the North American Subaru Impreza Owners Club Thursday July 31, 2014
Old 08-28-2012, 09:04 PM   #1
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Default AK's Monster "STIROID" 2006 STI Build-2013 UPDATE- FP GT3794R ((lots of pics))
UPDATE: Part 2 Build underway! Starts on page 7!
Hello Gents
This is my first ever "build log" Car is a 2006 Black Sti with 68k.
I'm assembling my engine this week and I wanted to give a build log a shot. My buddy and I are opening a shop soon and this car is going to be our poster child. I'm aiming for 650 whp on 93+ meth and 750+ whp on C16 and 9s in the 1/4 in street trim! Hopefully will be the fastest STI in Michigan (not sure who is) at the moment. I will be updating the thread with pics as I go along.
The car is being tuned by Aaron Rose(business partner/tuner/builder) , and yours truly.
Engine:
Darton Sleeves, Installed and Line bored by Justice Racing Engines (darton east)
JE 101.5 mm custom pistons
Manley I beam "turbo tuff" rods
Nitrided OEM crank
King Bearings
Cosworth Oil Pump
Killer B Oil Pickup
Grimspeed air/oil separator
BC Stage 3 cams
BC Springs/Retainers
BC SS +1mm valves
Bronze Valve guides
Balanced Roatating assembly
Fluidamper Pulley
Heavily Worked Heads
Cometic 102mm .060" gaskets
AMR EL Header
Custom Up Pipe
Forced Performance GT3794r
TIAL 44mm Wastegate
Custom Downpipe
3.5" Straight back to Invidia N1 Race Muffler
Turbo XS Intercooler w/ modified piping
TIAL "Q" BOV
Stock Ported Intake, TGVs ported
Aeromotive Fuel Rail Kit
DeatschWerks 1300cc top feeds
-6 AN feed and stock return lines, (soon to be -8AN feed and -6AN return)
Twin 255 walbros in tank w/ Full Blown Hanger
Okada Plasma Direct Coils
Gates Timing Kit
AEM Methanol Injection
AEM Series 1 saving for series 2
Mishimoto Radiator
Transmission:
2006 6 Speed (not ideal for drag but works for now)
REM ISF gear coating
Exedy twin disc
DSS Stage 5 Rear axle/Hub kit
Synthetic Tranny/Diff fluids
Suspension:
Whiteline Rear control Arms
Tein Lowering springs
Whiteline Rear swaybar mounts
Body:
Weight reduction
Cage in near future
I'm sure I have forgotten a few things
Will be adding pictures tonight. Thanks for looking
Current tune: 93+meth 30psi
ckyguy68 is offline   Reply With Quote
Old 08-28-2012, 10:09 PM   #2
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
the build looks pretty good but the bc cams are not going to get you there,either custom kelfords or maybe gsc3's.Personally I would have a set of kelfords done and would call and talk to Kevin Ban about your build and goal and let him grind what you need to get there.Trust me it will take a very good combo to get to those c16 #'s let alone those pump gas #'s but good luck and hope it goes well.
john 1badSTI is offline   Reply With Quote
Old 08-28-2012, 10:31 PM   #3
albersondh
Member#: 196882
08 WRX
No E85 tune? Understandable if your trying to avoid injector swaps if your dead set on a c16 tune. I drive from Wayne to Warren on E85 everyday never had a single avaiability problem. I run a GM FFV sensor (-8 pump forward -6 retuen) with dash mounted Ethonal content display. This summer filling up all over the place I have yet to see it drop below E84. Pretty sure dual Wally 465's would hang just fine in place of those 255's.
Why not stroke it and keep some meat on the dartons, not that it would bean issue, but would make a rebore in the event of a failure that chews a bore a bit more fesable and create a more optimal rod ratio. Not sure what max bore on Dartons is? I got my spare block starting to come together now and based off a quick and dirty bore gauge its looking like Ill be doing Dartons as well, but keeping it 99.5 for reasons pointed out above.
What crank? Im building a motor from the ground up so Im looking at a lot of options right now.
Your build sounds nuts man keep the updats flowing.
albersondh is offline   Reply With Quote
Old 08-28-2012, 11:07 PM   #4
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Thanks John, The car made 584 awhp on BC stage 2s and a 35r, then on this same build last fall it made 592 on pump at 26psi on this 3794. before we ran into issues. Both runs on AMS dyno. Though the BCs may not be the best option, I am confident with them. This FP 3794r really moves an insane amount of air.
I've strayed away from E85 for right now because of the injector and pump upgrade, but I will absolutely consider it an option next spring.
As for the bore size I completely agree, it's a really long story but I bought the JE pistons from someone and the sleeves were already maxed out. If I do this motor again, (eventually will) I will be going with a smaller bore to leave room to clean up and order a new set of pistons. I'm sure you can understand my price point seeing as a custom set of JEs is $1200+ dollars and there was nothing wrong with these ones.
Old 08-28-2012, 11:09 PM   #5
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Few pics of the car
Old 08-28-2012, 11:12 PM   #6
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
New carpet
Old 08-28-2012, 11:13 PM   #7
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Changed the gauge setup a little.... missing the oil temp !
Old 08-28-2012, 11:14 PM   #8
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Case halves received from Darton!
Old 08-28-2012, 11:42 PM   #9
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
if you can swing it I would o-ring it if it were mine(btw my 101mm sleeved block is).
Old 08-29-2012, 01:07 AM   #10
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
We've had good experiences with the cometic gaskets and ARP L19s, I have not had a HG failure so far, we shall see how it does in the higher boost numbers and then take it from there!
Old 08-29-2012, 02:49 PM   #11
brandywine050
Member#: 196020
if i'm not mistaken this car had made 590~ on a 3586? and 3 cylinders at ams lol. i look foward to seeing what this can do! keep us updated sir very interesting indeed!
brandywine050 is offline   Reply With Quote
Old 08-29-2012, 03:05 PM   #12
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Haha! You may be correct Brandon. I'm sure you'll be updated on progress!
Old 08-29-2012, 03:11 PM   #13
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Got the case halves cleaned and prepped for the crank
Old 08-29-2012, 03:17 PM   #14
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Pre clearance checking.
Cleaned crank, ready for rods.
Manley "turbo Tuff" I beams.
Installing rods for clearance checking with plastigage.
After clearances were verified, the rod bolts were stretched to spec. I didn't get any pictures during that process because it is rather intense. Stretching the bolts is the only way to make sure they are properly loaded. Here is the proper tool to use.
Old 08-29-2012, 03:26 PM   #15
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Here is the turbo, FP GT3794r, flows around 90 lbs/min, 42r numbers, with the footprint of a 35r. Can you say sneaky??
Old 08-29-2012, 03:28 PM   #16
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Little instragram shot of the intake ports.
Old 08-29-2012, 10:11 PM   #17
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Wish I would have taken more pics while closing the case, but wanted to get everything tight before the sealant set!
Rags on the rods... don't need any scratches!
Old 08-30-2012, 08:44 AM   #18
berdugo
Member#: 163108
07 EuroDM STi 2.5L
Looks great, goodluck on your build
berdugo is offline   Reply With Quote
Old 08-30-2012, 02:20 PM   #19
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Thanks man! I appreciate it!
Old 08-30-2012, 03:55 PM   #20
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Setting ring gaps!
For those who don't know why this piston is upside down- You place a ring on the piston and push the ring being gapped into the bore for a perfectly true ring depth when you are measuring your gap!
Ring filer/beer holder!
And we have pistons installed!
Cosworth Oil pump installed
On the stand, heads are up next!
Old 08-30-2012, 04:04 PM   #21
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
looking good man. good luck.
stretchedk7 is offline   Reply With Quote
Old 08-30-2012, 07:44 PM   #22
dukeduster
Member#: 95789
2002 WRX PTE
6262, hydra, 1100 FIC
Looks really good! I do have a question for ya though. Using plasti gage on the rod bearings? Are they not coated? The reason I ask cause when I tried to do that the plasti-gage wanted to smash into the bearing coating when torquing the rod bolts. Its also very hard to keep the rod from moving while doing this.
dukeduster is offline   Reply With Quote
Old 08-30-2012, 08:37 PM   #23
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
I'm not sure if plasti-gauge has a "shelf life", but I have felt some that is just harder for some reason. I've seen hard plasti-gauge dig into bearings like that. You can try rolling it around in your fingers to soften it up a little bit, but if you dented your coating I would suggest replacing the bearing(s)
As for holding the rod steady, some people use a jig that holds the crank and the rod steady, or you can grab a couple buddies!
<---- Ford Engine Lab Technician and Ex- Subaru WRC Mechanic-------->
Now that's what I call help!
Old 08-30-2012, 09:33 PM   #24
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
^^ nice man!! glad its coming along.
Old 08-31-2012, 03:30 AM   #25
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
After 3 months of waiting, me too Thanks!
