Old 08-29-2012, 01:46 PM   #1
andrewprime1
Member#: 263963
2002 Impreza RS 2.5L
Default Passenger Side Window Switch Illumination
So after lots of searching I found... nothing. I am interested in modding the passenger side window control switch in my 2002 Impreza so that it illuminates red. I have seen the old Lightwerkz Thread that offered
Originally Posted by LightWerkz View Post
A custom fabricated lens is cut into passenger window switches to match the driver’s panel buttons. We tap into the power pins on the switch for true plug-n-play operation. The passenger window switches are a nice touch to a complete interior lighting system!
I sent a PM to ProDriven Auto, but they are not able to offer this service.
I also found this thread by soccermom that mentions something about illuminating the passenger side switch, but never follows up.
So does any one have an info, or hopefully a link to a DIY thread about how to do this mod? Or, possibly even better, does anyone know if another MY or even model Subaru is compatible and already illuminated?
andrewprime1 is offline   Reply With Quote
Old 10-24-2012, 04:45 AM   #2
inabysskit
Member#: 255304
I also really want to do this mod if I could. It would really complete the 'red light look' inside the car. I've converted everything else to red already!
inabysskit is offline   Reply With Quote
Old 10-24-2012, 08:34 AM   #3
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
I think prodriven did mine. Basically all you do is cut a opening for the light to pass through(currently its white paint). Make it so its clear. Open the switch and add a led inside the switch, smaller the better. Then use the connection for power mirror for light.
Problem is since their is no illumination cable the light will always be on. I don't really care at least my passenger can see the switch now, but might be bigger deal to others.
talvai is offline   Reply With Quote
Old 02-21-2013, 02:13 AM   #4
inabysskit
Member#: 255304
I think prodriven did mine. Basically all you do is cut a opening for the light to pass through(currently its white paint). Make it so its clear. Open the switch and add a led inside the switch, smaller the better. Then use the connection for power mirror for light. Do you mean use the connection for power window? Does anyone know which wires on the passengers' window switches harnesses provide +12v and negative?
Old 02-21-2013, 02:14 AM   #5
inabysskit
Member#: 255304
[quote=talvai;38341241]I think prodriven did mine. Basically all you do is cut a opening for the light to pass through(currently its white paint). Make it so its clear. Open the switch and add a led inside the switch, smaller the better. Then use the connection for power mirror for light.
