Old 08-30-2012, 10:07 AM   #1
ctsquid
Member#: 267105
Default Trouble shooting a lighting issue
I am currently having some problems with a set one of my headlights that I cant seem to figure out. I have v7 HID projector head lights with OEM ballasts and a lightwerkz harness.2 days ago my drivers side high and low beam stopped working. I've check all of the fittings and conectors and everything seems to be okay. This mornig on the ride to work, I saw the reflection on the back of the car and the low beam was flickering. Could this be a problem with the ballast itself? should I buy a new bulb? Any input would be appreciated.
-steve
ctsquid is offline   Reply With Quote
Old 08-30-2012, 10:28 AM   #2
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
How old are the HIDs? Were DRLs disabled when they were installed?
Old 08-30-2012, 10:40 AM   #3
ctsquid
Member#: 267105
The bulbs were brand new 6 months ago. DRL's were not disabled.
Old 08-30-2012, 11:46 AM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The trouble could be due to a number of things. I suggest you get a voltmeter and verify the ballast is getting 12 volts to it while the lights are on. Also make sure the ground connection to the ballast of the bad light has no voltage drop across it. If those things are ok then you might try swapping the lights to see if that makes a difference. If that doesn't help then the ballast would seem to be the trouble.
Old 08-30-2012, 12:24 PM   #5
ctsquid
Member#: 267105
I'll do those checks after work today. If the ballast is indeed bad, what would your recommendations be for replacement? I plan on having them retrofitted to correct the RHD cutoff in the coming weeks so I don't want too expensive of a replacemt, but I don't want Chinese trash either. Does anyone have any experiences with the Phillips ones?
Old 08-30-2012, 09:32 PM   #6
Blktrax
Member#: 220971
2002 WRX 219K Mi.
Original Motor and Turbo
I took a set out for a guy, once the headlight was out of the car, found a poor crimp to ground. Tested it after making a good ground was working again. But he wanted regular bulbs anyway.
Blktrax is offline   Reply With Quote
Old 08-30-2012, 11:55 PM   #7
ctsquid
Member#: 267105
It was the ground. Thanks for the help guys.
