Old 08-31-2012, 12:30 AM   #1
martinez801
Member#: 295702
2004 2004 WRX
Default accesport reading my 04 wrx as an 02-03?
Ive tried 3 different accesports and it keeps reading my 04 wrx as an 02-03? anybody know what the situation might be? would it matter if i plug in the 02-03 maps?
thanks in advance
martinez801 is offline   Reply With Quote
Old 08-31-2012, 05:24 AM   #2
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
Some assumptions I am making here:
You purchased an 04 WRX AP v2(b)
The other AP's you tried were appropriated for an 04 WRX
Your ECU is unmarried to any AP and you are trying to install and OTS Cobb map (stage 1 I am guessing)
Did you buy your car used?
Does it have an 04 ECU? [You can check the designation numbers on the actual ECU under the passenger carpet in the footwell. The number designation will tell you what it is supposed to be but it will not tell you what is programmed on the inside. It would not be the first time someone had to swap an ECU.]
Did a previous owner ruin the original ECU and replace it with an 02/03? [Not sure if this would work though]
Did a previous owner use open source tuning to flash an 02/03 map in the ECU? [Not sure if this would work either, but if so you could do the same to put an 04 map back in the ECU]
Not sure about any differences in the AP's between 02/03 and 04, when Cobb chimes in they can cover the AP specifically.
jebjkey is offline   Reply With Quote
Old 08-31-2012, 08:58 AM   #3
Cobb Tuning
Member#: 4803
thanks in advance
Assuming this is a version 2 AccessPORT, then likely the ECU in your car has been swapped with an 02 or 03 ECU (which is possible in an 04 or 05 WRX). It should not be possible to reflash an 02 or 03 WRX ECU image on to an 04 or 05 ECU.
The AccessPORT checks the ECU identifier before it installs, so this is the only explanation as to why it wants to install as 02/03 ECU on your 04 WRX. As far as I know, others have run an 02/03 ECU in 04/05 WRX before without issue, so you will probably be fine (especially if you've had no issues since you've had the car). If you can take a picture of the top of the ECU and post it, we can confirm what ECU is in the car.
Bill
Old 09-01-2012, 01:35 AM   #4
martinez801
Member#: 295702
2004 2004 WRX
yea i bought it used. not sure if they might of put an 02-03 ecu. will try to get a pic of it. i appreciate your guys input. thanks
