Old 08-31-2012, 09:40 AM   #1
mike20255
Member#: 260085
2009 WRX
Default Will 2008 WRX rims/tires fit on a 2011/2012 WRX?
I searched but couldn't find the answer. I know the 2011/2012 tires are 235 opposed to the 2008 of 225. But will rims from a 2008 fit on a 2011/2012?
Thanks!
mike20255 is offline   Reply With Quote
Old 08-31-2012, 09:04 PM   #2
mike20255
Member#: 260085
2009 WRX
Anybody?
Old 08-31-2012, 09:18 PM   #3
chino_487
Member#: 209156
2009 WRX Sedan
SSM
yes...same bolt pattern 5x100. They arent as wide so they might be set in the wheel well a bit more
chino_487 is offline   Reply With Quote
Old 09-04-2012, 01:09 PM   #4
SparkSilver10NM
Member#: 302438
10 WRX
SS DMrally tuned!
^^^ this, but why would you wanna do this? The newer wheels are much nicer and an inch wider.... plus I have a 2010 and HATE these wheels!!! care to trade? lol.
SparkSilver10NM is offline   Reply With Quote
Old 09-04-2012, 10:13 PM   #5
mike20255
Member#: 260085
2009 WRX
Thanks guys. I was actually looking for winter rims/tires and I saw 2008 ones for sale.
Old 09-04-2012, 10:30 PM   #6
mike20255
Member#: 260085
2009 WRX
So to confirm as I continue to look for winter tires/rims. Can I get steel rims/tires 205/55/16 that were on a 2008 WRX to fit on the 2012 WRX?
Any caliper clearance issues with 16"?
Old 09-05-2012, 03:15 PM   #7
REX8
Member#: 24038
They'll fit fine.
Old 09-05-2012, 03:38 PM   #8
SparkSilver10NM
Member#: 302438
10 WRX
SS DMrally tuned!
^ correct, as long as you haven't done any brake upgrades they'll fit just fine
Old 08-22-2013, 04:15 PM   #9
chevwrx
Member#: 343499
I'm looking to buy a 2002-05 WRX wheelset to fit on my 2012 WRX wide-body for winter. It comes with 205-55-16 studded winter tires.
I've look at the Master thread of OEM Subaru Wheel Specs:
http://forums.nasioc.com/forums/show....php?t=2239019
2002-05 WRX
Offset: +53
Bolt pattern: 5x100
Wheel Weight: 16.5 lbs
OEM-equipped tire size: 205/55R16
2011 WRX
Offset: +53
Bolt pattern: 5x100
Weight: 22lbs (verify?)
OEM-equipped tire size: 235/45R17
Everything looks like it would fit since I have the WRX OEM brakes.
Just want to make sure before I go and buy them.
Thanks!
chevwrx is offline   Reply With Quote
Old 08-22-2013, 10:44 PM   #10
Mach V Dan
Member#: 12029
Yes, they will fit. Note that they would NOT fit over the larger brakes on the 2006-07 WRX.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 08-23-2013, 07:02 AM   #11
chevwrx
Member#: 343499
--Dan
Mach V
FastWRX.com
Ok excellent! thanks a lot!
