Old 08-31-2012, 10:06 AM   #1
IH8PVMNT
Member#: 178254
2006 Wrx Limited BUG
2006 Wrx Limited Wagon
Default Headlamp leveling switch help...
I'm looking for a v7 sti headlamp leveling switch.. And possibly help with the wiring if possible... The switch being most important having trouble finding one.. Trying to hook up to my v7 sti hid headlamps.. Any help much appreciated!!
Thanks!
IH8PVMNT is offline   Reply With Quote
Old 09-01-2012, 02:56 PM   #2
IH8PVMNT
Member#: 178254
Help??
Old 09-02-2012, 12:29 AM   #3
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
I have the round knob version, I dont remember the wiring but it is pretty simple and I think I have found the information on scoobymods forum, will look out for the link for you in a minute..
On mine you basically feed +12 and ground to the headlight, and then there are 6 control wires going to the switch to tell the headlight which position it needs to go.
The switch also receives +12 and ground. And it outputs 4 signals on 4 separate wires. Each of the 4 wires corresponds to a position of the switch; the selected position's wire will have 12V and all others will be off (like not connected).
The later switches designed for 06-07 STI had like 3 wires I believe: +12, ground, and a control signal that varied voltage to tell the motor where to go (ex: 12v position 1, 9v at position 2 etc). I just nade up these voltages by the way.
frederik is offline   Reply With Quote
Old 09-02-2012, 12:31 AM   #4
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Old 09-02-2012, 09:36 AM   #5
IH8PVMNT
Member#: 178254
Originally Posted by frederik
You are the best!! Thinking I'll use a 04-05 switch for this
