Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Old 02-27-2001, 03:44 PM   #1
dbrown
Member#: 620
Post
What do you mean by back up horn? A siren that contains a backup battery? If so, do you want to replace your existing siren or ad it along with it?
-dB
dbrown is offline   Reply With Quote
Old 02-27-2001, 05:25 PM   #2
2yLiTe
Member#: 660
Unhappy
Yeah..it's the battery backup siren.
I want to add it to my existing...I thought that it was a standard wiring thing..but the siren kept going off...I'm just wondering if there are any alarm installer types here that might be able to help...
help?
2yLiTe is offline   Reply With Quote
Old 02-27-2001, 08:57 PM   #3
dbrown
Member#: 620
Post
If you want to give me the wire color coding off of the siren I can most likely help out.
-dB
Old 02-28-2001, 12:36 AM   #4
HoratioCaine
Booty Connoisseur
Member#: 3409
Post
Haa haa haa.. I thought you were talking about one of those "beep...beep...beep...beep" delivery truck backup sirens.
HoratioCaine is offline   Reply With Quote
Old 02-28-2001, 01:23 AM   #5
2yLiTe
Member#: 660
Post Backup Alarm horn
Does anyone know how to install an aftermarket backup horn to a Clifford Sabre II?
Old 02-28-2001, 05:01 AM   #6
2yLiTe
Member#: 660
Post
Hey dBrown,
If you're ever in the Detroit area, maybe we can hook up...I work downtown near Comerica Park. I can always meet up in the burbs too
Lemme know. Otherwise I'll give you the wire colors...
Thanks,
Rommel
Old 02-28-2001, 06:03 AM   #7
dbrown
Member#: 620
Post
I never end up to much farther east than this. If you wanted to come all the way over here I can help you out. I'm about an hour west of of the border. Or I can tell you what to do if I have all of the wire color codes.
-Doug
Old 02-28-2001, 12:04 PM   #8
2yLiTe
Member#: 660
Post
So you want the wiring codes for the alarm AND the backup siren?
I will try and get them later today...
but in advance...the backup siren has only three wires (I think) positive, negative, and trigger right?
Old 02-28-2001, 04:55 PM   #9
dbrown
Member#: 620
Post
Yeah, there should only be 3 wires. Thats what I wanted to make sure of. As long as there is only 3 here is how you hook it up.
Negative - Ground to the chasis of the car.
Positive - Connect to the battery.
Trigger/input - Connect to the siren output of the alarm.
-dB
Old 02-28-2001, 10:41 PM   #10
2yLiTe
Member#: 660
Post
I tried that once...and as soon as I turned the arm/disarm key on the backup siren...it just went off!
I'm wondering if Clifford alarms are picky about aftermarket stuff...??
Old 03-01-2001, 06:17 AM   #11
dbrown
Member#: 620
Post
Hook up the power and ground then turn the siren on. Then connect the trigger wire.
or
Hook up all 3 wire then turn it on and hit the arm/disarm button on the remotes.
Let me know what happens when yo try these.
-Doug
Old 03-01-2001, 05:24 PM   #12
2yLiTe
Member#: 660
Post
ok, I'll give it a try...stay tuned!!!
thanks!
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 07:27 AM.
