Old 10-07-2012, 11:08 PM   #2901
Stickee
Member#: 530
2005 9-2x Aero
FastAr Red
Originally Posted by system60 View Post
Well, Apple is the king of $%^* you pay me
"**** you pay me."
"shut up and take my money."
Stickee is offline   Reply With Quote
Old 10-08-2012, 12:12 AM   #2902
BlackBeastie
Member#: 11846
I maybe need
a break
Old news but, apparently the A6 runs at 1.3GHz
http://www.engadget.com/2012/09/26/a...-overclocking/
BlackBeastie is offline   Reply With Quote
Old 10-08-2012, 12:48 AM   #2903
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Yeah, unlike the past iPhones the i5 is no slouch, and base on benchmark tests, one of the fastest phones available right now.
LIQUIDSK8S is offline   Reply With Quote
Old 10-08-2012, 06:33 AM   #2904
teamjordan23
Member#: 105025
Apple explains purple flare issue affecting camera on iPhone 5 (and other smartphones)
The purple flare phenomenon you're seeing in certain photos taken with the iPhone 5 is perfectly normal, according to Apple, and it's an issue that affects the cameras found in nearly all smartphones. The company today posted a support article seeking to eliminate concerns that the problem is inherent to its latest handset, explaining that the purplish light can in fact be replicated with every prior iPhone model.
Apple says the issue arises when users take pictures with a light source that's just outside the frame. This light "causes a reflection off the surfaces inside the camera module and onto the camera sensor" that results in an unwelcome flare or haze. Apple's suggestion is to simply recompose your shot slightly until the issue disappears or shield the camera with your hand to minimize any flaring.
Immediately after the iPhone 5 launched, users were quick to voice concerns over the device's susceptibility to scratches, scuffs, and other hardware blemishes some even arrived with physical flaws out of the box. Apple's response to the purple haze "controversy" is likely an attempt to head off further doubts about its new flagship hardware. In this case, though, the company's explanation checks out with photo experts. For example, in their quick review of the iPhone 5's camera, the folks at Digital Photography Review told buyers "not to worry" about the issue and to merely avoid composing shots with bright lights at the edge of your frame.
From TheVerge
Not sure if posted already, remember it being cleared up by a member here too.
teamjordan23 is offline   Reply With Quote
Old 10-08-2012, 01:58 PM   #2905
Christoff
Member#: 22758
So my iPhone 4 mic is still wonky. It'll work for extended periods then work intermittently for a while. I've done the hearing aid mode and it didn't change anything. I know it's the noise canceling mic up top since it works fine with any other app other than the phone.I've cleaned it, etc. I feel bad selling it knowing it'll stop working. Any suggestions? I'll be getting the 5 here soon
Christoff is offline   Reply With Quote
Old 10-08-2012, 02:50 PM   #2906
BlackBeastie
Member#: 11846
I maybe need
a break
Does it malfunction in all of the modes like speakerphone and facetime? Does it work with the inline mic on the earbuds? Does it record voice memos? Since you are selling it, I would try a full wipe and set it up as a new phone and see if that solves it (eliminate possibility of software issue). Older software solution. If it is a hardware issue, I would disclose that in the sale of the item. It will still sell pretty well as I am assuming the rest of it works fine.
Support thread.
edit: reading comprehension fail. You said it affects only the phone app. I would definitely do a fresh install.
Old 10-08-2012, 02:56 PM   #2907
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
http://www.ifixit.com/iPhone-Parts/i...-ATT/IF182-015
http://www.ifixit.com/Guide/Installi...r+Cable/4336/1
Old 10-08-2012, 07:34 PM   #2908
Christoff
Member#: 22758
I don't know why there's not really a clear answer on why the mic will stop working during calls (and still work in any other app but the phone app) other than it's the noise canceling mic. I got one of the first iphone 4s (you're holding it wrong!) so I'll attribute it to a manufacture issue and multiple droppings.
That being said I saw this a while ago and finally stopped being lazy and went to Home Depot for the screwdriver.
So far the janky fix works
Old 10-08-2012, 07:46 PM   #2909
thejordan
Member#: 185374
How to fix the iPhone 4 (4s) Mic problem - YouTube
I thought it was due to something when service provider towers are experiencing high usage volume it'll receive but not send info and is specific to the antenna in the iphone. Otherwise it doesn't make sense. When I was travelling and this occurred maybe 1 in 6 calls in areas of high population, a second call would not have the issue.
thejordan is offline   Reply With Quote
Old 10-08-2012, 07:49 PM   #2910
Christoff
Member#: 22758
If you google there's a very common issue with the 4 of what I've mentioned in the above. Not just every couple calls. It's consistent.
Old 10-08-2012, 10:09 PM   #2911
BlackBeastie
Member#: 11846
I maybe need
a break
Microphone issue? I had a 4 for 2+ years and the closest I came to a mic issue was the proximity sensor sucked and sometimes I would mute the phone with my face.
Old 10-08-2012, 10:27 PM   #2912
Christoff
Member#: 22758
Ok, cool? You got the ones that didn't suck?
Old 10-08-2012, 10:35 PM   #2913
rambo lambo
Member#: 173139
mine never had any isues till i cracked the screen. i wont blame apple on that. I bought a replacement and tada, back to perfect condition. I always had signal when others whined, deathgrip didnt do much unless I hulked it. No proximity sensor issues ever, speakers and mics always working. all from a launch day iphone4
rambo lambo is offline   Reply With Quote
Old 10-08-2012, 10:50 PM   #2914
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
No problems for me either.
Old 10-08-2012, 11:15 PM   #2915
Christoff
Member#: 22758
Must be some conspiracy then.
Old 10-10-2012, 01:28 AM   #2916
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
comex the creator of the original jailbreak was given an internship at Apple before the iphone 5 was released. May not see a jailbreak for a while :/
Jubert69 is offline   Reply With Quote
Old 10-10-2012, 02:18 AM   #2917
thejordan
Member#: 185374
there are plenty of jailbreak devs out there...
Old 10-10-2012, 10:45 AM   #2918
scaryfastskier
Member#: 7893
2010 F150 & Iron883
Husky TE449 + TXC250
Well, looks like I will be keeping the iPhone 5. Found a hairline crack on the back bottom glass. No pictures because it's too small to photograph well. I haven't broken glass on any iPhone yet, so it figures this would happen so fast.
Any decent slim cases out there? Too many to choose from without a suggestion. I liked the magpul case a lot for the 4/4s. I prefer slim because I prefer no case.
Thinking maybe I should get that AppleCare after all. It protect against user error?
scaryfastskier is offline   Reply With Quote
Old 10-10-2012, 10:45 AM   #2919
scaryfastskier
Member#: 7893
2010 F150 & Iron883
Double post.
I don't know how it broke. It slipped off my lap once and fell about 10" to padded rubber (work truck) but showed no damage at the time. Only time anything sketchy has happened with it.
Old 10-10-2012, 10:46 AM   #2920
The Dayman
Member#: 84815
2015 water n badass.
badass n water.
The Dayman is offline   Reply With Quote
Old 10-10-2012, 11:10 AM   #2921
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Yeah, but when you have the top guy get hired by apple, most jailbreak openings get closed. Will there be a jailbreak? Yes, but it won't be anytime soon like the iP4/4s
Old 10-10-2012, 11:18 AM   #2922
BlackBeastie
Member#: 11846
I maybe need
a break
Verizon customers: Did you know that they are collecting your personal info (on by default)? They can sell your web history and location data to marketers unless you tell them not to. Check the Verizon iphone app and manage your privacy settings or go to http://www.vzw.com/myprivacy.
Old 10-10-2012, 11:20 AM   #2923
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Yep. Been buying that data for awhile now
DoctorNick is offline   Reply With Quote
Old 10-10-2012, 11:33 AM   #2924
DeusExMachina
Member#: 13485
OMG EJ22T
FTW
I was all like "back glass?" then realized its 90% aluminum, and a little bit of glass.
The word from Magpul (my friend is a dealer) is the 5 case is in development. I am waiting impatiently.
In the mean time, I acquired a silicone case from GameStop for the low low price of free. They had them on the shelf for $10, and it looked decent enough because it was slim and would prevent it from sliding around in my dash pocket. I went to pay for it and it rang up as $0.00, the guy looked at it sideways, then printed a receipt and said, "Have a nice day."
DeusExMachina is offline   Reply With Quote
Old 10-10-2012, 11:39 AM   #2925
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
AppleCare+ is $99 then there is a $50 deductible for accidental damage. I think you get 2 instances...
Jard is offline   Reply With Quote
