Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Old 08-31-2012, 02:18 PM   #1
vms150
Member#: 172917
2004 WRX
Default Trying To Understand Offset
So I read the Offset Info thread and I am still a bit in the dark. Offset is listed as how far the mounting surface of the wheel is from the center of the wheel, and it is listed in mm. Is this correct? If this is correct the less offset, the more aggressive the fitment is right? So the lower the offset number the more "concave" the wheel will have?
So example. A 9" wheel with 50 offset would be pretty standard and not aggressive but that same 9" wheel with 25 offset will be quite concave and aggressive... is this all right?
Finally is there ever negative offset so the mounting surface is further in past the center of the wheel?
Please don't flame, I searched around and am trying to double check what I believe I understand. Thanks guys.
vms150 is offline   Reply With Quote
Old 08-31-2012, 03:09 PM   #2
sc00by4life
Member#: 97135
Concavity of a wheel is all based on the design of the wheel. Lower offset doesn't always mean concave and big lips.
Yes there is negative offset, but you don't see that on our cars.
Old 08-31-2012, 03:22 PM   #3
vms150
Member#: 172917
2004 WRX
I have stock BBS wheels on mine and they will remain on there for as long as I have it. This is purely for understanding and knowledge.
Old 09-01-2012, 12:25 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Your understanding is pretty much correct. As scooby4life said, though, a more shallow offset doesn't necessarily mean the wheel will be more concave. I used to have '95 Cobra R wheels on my Mustang. Ford made two versions - the original (part number ending in -R58) with a +24mm offset, and a version to fit on the rear of older Fox body cars (-M179) with a +36mm offset. The face of the two wheels was identical, but if you looked at the mounting face from the back of the wheel you could see it was noticeably thicker on the R58 wheel. Thicker mounting face = wheel pushed out farther = shallower positive offset.
You don't see negative offsets that often nowadays (at least, not in my experience), but there are wheels out there with negative offsets. From what I've seen I think that's primarily a truck thing.
Old 09-01-2012, 12:48 AM   #5
SparkSilver10NM
Member#: 302438
10 WRX
SS DMrally tuned!
I have a specific question: I have also searched and gotten some conflicting information so I'd like to get clarification.
I have a 2010 wrx on stock wheels (17x7) +53 offset
I'd like to put a set of 2011 wrx stock wheels on (17x8) +53 offset. But doesn't that mean the wheel is gonna stick out almost an inch? And thus put undo stress on my wheel bearings wearing them faster? O and look kinda stupid too?
SparkSilver10NM is offline   Reply With Quote
Old 09-01-2012, 03:33 AM   #6
Xer0 SiN
Member#: 290271
15 Superduty F350
Caribou Metallic
just a hypothetical question. trying to understand the whole offset thing as well. has nothing to do with rubbing, bearing wear, type of car its going on, etc; simply trying to understand how the number is in correlation to the wheel itself.
say you have two sets of identical wheels (17x7.5 et53 and 17x8.5 et53). now the numbers is the same, except the width of the wheel. to get the 7.5 wheel to sit at the exact same point as the 8.5 wheel, spacers would be required, right? does that in essence drop the 7.5 wheel to a et28?
sorry if this makes no sense at all, it sounds better in my head, i swear!
Xer0 SiN is offline   Reply With Quote
Old 09-01-2012, 01:51 PM   #7
sc00by4life
Member#: 97135
To both - yes wheel width effects face position of the wheel. However you are both sort of off. Wheel width gets added to BOTH sides of the wheel, not just one.
The difference between 17x7.5 +53 and 17x8.5 +53 is only half an inch in terms of the outter position of the wheel.
Old 09-02-2012, 10:35 AM   #8
vms150
Member#: 172917
2004 WRX
Thank you very much for the clarification guys. It was very helpful.
Old 09-02-2012, 04:36 PM   #9
SparkSilver10NM
Member#: 302438
10 WRX
SS DMrally tuned!
Scooby,
So this means if I fit the 8" wheel it'll only carry 1/2" further out from the car? This will not cause any undo strain on wheel bearings? What about turning radius and rubbing when on the terrible Albuquerque streets?
Old 09-02-2012, 04:52 PM   #10
vicious_fishes
Member#: 158864
2003 GD w/EZ30 swap
Scooby,
compared to a 7 inch wheel of the same offset, yes.
vicious_fishes is offline   Reply With Quote
Old 09-04-2012, 01:04 PM   #11
SparkSilver10NM
Member#: 302438
10 WRX
SS DMrally tuned!
f'en sweet! i think i'll look into making sure they won't rub when turning and get the ones I really want instead of compromising! Thanks everyone!!!
