Old 03-18-2013, 12:36 AM   #151
p951951951t
Member#: 276541
1972 Alfa Romeo GTV
Alfa Rosso
Great thread and great work. +1 on JPM being great guys. Hard workers and great CS. I'm local to them, so I decided to drop by and pick up my shifter boot in person. I was impressed with their passion for the work and their attitudes.
p951951951t is offline   Reply With Quote
Old 03-18-2013, 08:33 AM   #152
Overland04
Member#: 293311
2013 FXT 6-Speed
Obsidian Black Pearl
I was able to find these from the install, they are a little bit closer. I didn't roll the edge, just cut it with a sharp razor. It's still holding strong which is why you NEED to use real contact cement for Alcantara.
The reason the edge stays so clean is because Alcantara doesn't fray along the edges and good adhesion from proper gluing techniques.
Cheers!
- Jason
Overland04 is offline   Reply With Quote
Old 03-21-2013, 03:07 PM   #153
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
This made me want to order up similar colors for my '11 STI. Thanks for the inspiration, probably attempt this over spring break~
Tyrial is offline   Reply With Quote
Old 03-26-2013, 04:52 PM   #154
WRX-ERROR
Member#: 83211
2002 WRX - stg4
Oh great another project this spring.. Haha
WRX-ERROR is offline   Reply With Quote
Old 04-17-2013, 01:41 PM   #155
ProJecTxPreLuDe
Member#: 268119
2002 WRX Wagon
Great Job! Can you point me in the direction of a good place to get alacantra by the yard ? I'm Doing my door cards and a couple other thing this summer. Please and Thank you.
ProJecTxPreLuDe is offline   Reply With Quote
Old 04-17-2013, 01:52 PM   #156
Overland04
Member#: 293311
2013 FXT 6-Speed
Thanks man,
I would get the Alcantara directly from JPM Coachworks. You can also get it from Gulf Fabrics but I believe they are the ones supplying it to JPM so your getting the same material.
They'll charge you the same price so I vote for supporting JPM instead of the bigger guys. Plus having Alex's support at JPM is worth it's weight in gold.
Cheers!
- Jason
Old 04-19-2013, 05:42 PM   #157
JPM Coachworks
Member#: 190108
2008 WRX STI
LR
Thank you for your kind words, Jason. As for the Alcantara material, Gulf Fabrics is the only official importer of the material for the United States. Even Recaro NA in Michigan purchases from Gulf
Best Regards,
Alex
JPM Coachworks is offline   Reply With Quote
Old 04-20-2013, 02:36 PM   #158
zenizlev
Member#: 347700
2011 STi
Just what I needed to see. This is now on my to-do list.
zenizlev is offline   Reply With Quote
Old 06-25-2013, 02:28 AM   #159
genetik_defekt
Member#: 360412
Wow absolutely amazing. And so classy but still retaining a sporty feel. Top job buddy.
Few questions. With the door cards, how did you pull the pieces apart. When i had mine off i notice the peices are plasti rivveted together. What was your method to remove them from eachother?
Also what thickness is the alcantara you used.
genetik_defekt is offline   Reply With Quote
Old 06-26-2013, 11:26 AM   #160
Captdonno
Member#: 358459
2013 WRX
WR Blue Pearl Sedan
^^^This, and also, any tips on blade selection for the edge delete? Can you use a low setting on a heat gun to achieve similar results as a steamer? This thread has truly inspired me, amazing work my friend!!
EDIT: Will the DAP Weldwood High Strength Spray Adhesive JPM offers do the job as well as your brushed method? Or would you suggest brushing to control the amount and add texture for the material to grip to?
Thanks!
Captdonno is offline   Reply With Quote
Old 06-26-2013, 11:50 AM   #161
Overland04
Member#: 293311
2013 FXT 6-Speed
Thanks man!
For the door cards, the top pieces are plastic riveted into place and they have to be VERY carefully drilled out. Once you drill them out, you can use large pan head screws to tap into the remaining plastic standoff that you drilled out. The screws can only be 1/4' depth so you may have to use a washer(s) so to not go through the plastic panel and out the front
Thickness of the Alcantara is 0.95mm
Thanks for your kind words, really means a lot!
I use a regular single edge razor blade to cut all of the material and to trim to fit. You can ABSOLUTELY NOT use a heat gun on Alcantara. it will destroy, melt, and shrivel the fibers in the material. Steam only!
Sorry to scare everyone, just would hate to see the results if it happened.
Cheers!
- Jason
Old 06-26-2013, 11:56 AM   #162
Overland04
Member#: 293311
2013 FXT 6-Speed
Thanks!
The glue you can purchase from JPM will be perfect for all the items that you might want to cover. The ease and convenience of the can is great.
The control of the brush was really nice on areas the had little room for over spray. You can tape off areas if you use the spray BUT be cautious of time needed to remove the tape and apply your material. Take too long and it will dry up and not adhere correctly. The only other benefit is the quantity of glue you get from the gallon. To do what I did would take roughly 4-5 cans.
Old 06-26-2013, 12:00 PM   #163
Captdonno
Member#: 358459
2013 WRX
WR Blue Pearl Sedan
Originally Posted by Overland04 View Post
Thanks man!
Cheers!
- Jason
Exactly what I needed to know!! haha
I'd like to start simple by maybe working from the center console out with the silver trimmed pieces covered in dark blue alcantara to coincide with the color of my car
The kicker is I just ordered a steamer from Amazon and it arrived broken...but I have a really nice heat gun! Oh well, I'll make sure I use your steam method then.
Thanks for the feedback!
Old 06-26-2013, 12:07 PM   #164
Captdonno
Member#: 358459
2013 WRX
WR Blue Pearl Sedan
Excellent, the more money I can throw at JPM the better! I figure I will start with pieces I can cover completely (even wrap) such as the trim piece around the shifter and move outward to the dash trim and eventually the door. Reducing the worry of overspray while I get used to working with the material. This is all great knowledge and I'm getting excited!! Thanks again for your insight!!
Old 07-09-2013, 03:53 PM   #165
VanceRacing57
Member#: 355079
2011 Impreza WRX 5dr
LRP
Alright, guy. Youre getting under my skin with this one!
I've got a pile of parts sitting in my storage unit, a whole bunch of finishing touches to buy still, AND NOW THIS!
Seriously. Its because people like you, with your mad skills and what not, that guys like me will NEVER be done with our cars.
But really, this is wonderful. Kudos.
VanceRacing57 is offline   Reply With Quote
Old 07-09-2013, 04:41 PM   #166
Overland04
Member#: 293311
2013 FXT 6-Speed
Haha, if I could have stopped with just the dash I would be fine, now I have more to torture everyone with (full OEM blackout)
Old 07-09-2013, 04:58 PM   #167
Tfivem
Member#: 357454
2013 WRX Limited GR
2015 Impreza Hatch CWS
this interests me .
is there a thread totaling what is needed p/n wise for buying this up?
insane job on your interior by the way, very impressed with your work.
Tfivem is offline   Reply With Quote
Old 07-09-2013, 05:48 PM   #168
Overland04
Member#: 293311
2013 FXT 6-Speed
Originally Posted by Tfivem View Post
this interests me .
Most definitely will be a p/n list added to this thread when I complete the job. For now I have the above items on a list in my thread (HERE)
Old 07-10-2013, 03:49 AM   #169
VanceRacing57
Member#: 355079
LRP
O.o ...
Old 07-10-2013, 08:21 AM   #170
Tfivem
Member#: 357454
2013 WRX Limited GR
very helpful! Thanks!
Old 07-11-2013, 06:31 AM   #171
VanceRacing57
Member#: 355079
LRP
That little hook, at the end of the window cut outs (or whatever the hell theyre called) will be difficult lol. I'm interested to see how you do it.
Old 07-11-2013, 06:06 PM   #172
Luis Franco
Member#: 263782
2011 WRX STi
Satin White Pearl
Would you happen to have a list of the materials you bought to do this?? im very interested but need to buy everything at once.
Luis Franco is offline   Reply With Quote
Old 07-12-2013, 12:46 AM   #173
OSUFlatland
Member#: 355718
Holy cow! That's gorgeous!
OSUFlatland is offline   Reply With Quote
Old 07-12-2013, 12:51 AM   #174
lts
Member#: 208927
Man, that looks good!
lts is offline   Reply With Quote
Old 08-03-2013, 04:33 PM   #175
NickDev96
Member#: 355754
2013 Subaru WRX
how much did it all come out to cost you? im extremely interested in this..
NickDev96 is offline   Reply With Quote
